billybeamer Samba Member
Joined: September 07, 2008 Posts: 33 Location: VIRGINIA
Posted: Sat Jan 24, 2009 10:58 pm Post subject: replace floor pan |
i need to replace the floor pan in my 71 ghia coupe would it be best to take the body off the chassie to do it right |
swhitcomb Samba Member
Joined: November 05, 2003 Posts: 5673 Location: Inwood WV
Posted: Sat Jan 24, 2009 11:54 pm Post subject: |
It is possible to do it without removing the body. However much easier if you do. Where in va are you? Perhaps i can help. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Sun Jan 25, 2009 7:34 am Post subject: |
There are benefits and drawbacks to doing it either way.
With the body on you have to work around the car removing the old pans and fitting the new. However, once you get the old pans removed and the new pans fitted, it is almost easier to install the pans with the body on as you can bolt the heater channel side in place. |
hpw Samba Member
moon-dawg Samba Member
Joined: April 25, 2006 Posts: 102 Location: So. Lebanon, Ohio
72Ghia Samba Member
Joined: November 11, 2007 Posts: 1253 Location: Baltimore Maryland
Posted: Sun Jan 25, 2009 12:11 pm Post subject: |
It took me about 10 hours from start to finish with the pan off.
Most time consuming was getting dimmensions of bolt holes & getting the old remaining pan off the lip of the frame. Lots of chiseling ,grinding &
removing bits of metal from the spot welds. You want to grind them down flush for a good fit. One benefit of pan on would probably be lining up the body bolts you can trim & test fit. I would remove or protect as much of the interior as possible if you are welding in new pans.
Its not rocket science , but the vidoes do point out some good tips which make it a worth while investment before doing the work. Then you can always sell it when you are done.
With body on there are some small areas in the back of the pans you may not be able to cut out. _________________ Bill
WTB- Billet center caps with Wolfsburg logo
72 Ghia Vert project
Bodywork http://www.thesamba.com/vw/forum/viewtopic.php?t=303542&highlight=
Re-assembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=4762737#4762737
72 Beetle Weekend Driver, restored in the 90's
http://www.thesamba.com/vw/forum/viewtopic.php?t=353424
www.airsuckers.com |
chewy Samba Member
Joined: January 01, 2009 Posts: 17 Location: TULSA, OKLAHOMA
Posted: Sun Jan 25, 2009 5:56 pm Post subject: pan replacement |
I would recommend -"bug me video", money well spent. I have repaced '70 pan. Build the saw horses so you can jack up body, and roll chasis out. It is staight forward, if you have sawzall, grinder and mig welder,(and you can use them!) DO IT! |
Posted: Sun Jan 25, 2009 8:56 pm Post subject: pan repair |
i live in nathalie va close to lynchburg va and danville va i basically dont know shit about volkswagons so i would like to pay someone to fix floor pans for me at a good price i can deliver the car but i do want it done right the first time also show pics what you have done please [email protected] |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Wed Jan 28, 2009 6:36 am Post subject: |
The closest I know to you is Northside Automotive in Madison:
http://northsiderestorations.com/ _________________ Ghia Owner Emeritus |
ddwbeagles Samba Member
Joined: May 12, 2009 Posts: 507 Location: Stephens City, VA
Posted: Wed Aug 19, 2009 3:09 pm Post subject: Good comes at a cost |
If you use Grant's shop "Northside Automotive, they do outstanding work but you better take out a 2nd mortgage. It will NOT come cheap. Just had some work done on my car there. Saw some restorations they had going on.... impressive work for sure. So I'll give this advice and I'm not bad mouthing them, if you get something done, get a quote for the specific job(s), do not pay by the hour.
Or option B, go to the search mode under classifieds, select "services", put in your zip code and the distance you're willing to travel to take it to get worked on. You'll see many shops in MD, PA and NC. Two guys down in NC actually give quotes in their add for both pan on and pan off and it's by far the cheapest I've ever seen. _________________ David W - from Chesterfield, VA / Jefferson SD / Stephens City, VA in that order.
71 Ghia Coupe autostick
78 Westy
86 Vanagon Weekender
hazetguy wrote: |
i'm going to stock up on search buttons |
Posted: Wed Aug 19, 2009 4:13 pm Post subject: Re: Good comes at a cost |
ddwbeagles wrote: |
Or option B, go to the search mode under classifieds, select "services", put in your zip code and the distance you're willing to travel to take it to get worked on. You'll see many shops in MD, PA and NC. Two guys down in NC actually give quotes in their add for both pan on and pan off and it's by far the cheapest I've ever seen. |
I would agree he is not inexpensive but his prices are reasonable for the quality of the work...plus he is a nice guy and a true VW enthusiast. _________________ Ghia Owner Emeritus |
ruschejj72 Samba Member
Joined: May 11, 2009 Posts: 38 Location: Greenwood, SC
Posted: Thu Aug 20, 2009 2:35 pm Post subject: |
i'm doing the same thing on a '72. I just finished the front suspension rebuild. Now the pans, both of them.
I have the bug me videos and it does take the intimidation out of it but getting the bolt holes right and the width right does worry me a bit.
I also am stressed about the seat rails.
And another thing, seam sealer and is POR 15 really the best thing to use? I have to learn to use an air sprayer too! Makes us better people, right?
I could not begin to imagine doing this with body on. There are only 13 steps to removing the body. As you see in my avatar, I do have some tools handy to make it easier though. Heh, heh. |
slafa Samba Member
Joined: December 29, 2008 Posts: 944 Location: Where getting a real beer is like winning the lotto
Posted: Thu Aug 20, 2009 2:52 pm Post subject: |
ruschejj72 wrote: |
I am told on the Volksrod site that Master Series is better and cheaper than POR 15.... I used POR 15 on my car and it seems bomb proof but they say over there that if your POR see's UV rays it will deteriorate and that it sticks great to rust but to raw steel it will start pealing off.... _________________ '63 KG Roadster proj.
1973 Mercury Montego MX Brougham
1977 Dodge Tradesman 200 "shorty" Van
1983 Ford 350 Econoline Ambulance
1997 Mercedes S500 W140
1976 BMW 75/6 bike
various Honda, GMC daily drivers |
c21darrel Samba Member
Posted: Thu Aug 20, 2009 2:55 pm Post subject: |
I used MasterSeries, came out great. Used only small rollers and foam brushes...no need to spray. |
Posted: Fri Aug 21, 2009 6:48 am Post subject: |
You should read through this link. While its long, its very informative.
http://www.thesamba.com/vw/forum/viewtopic.php?t=1...mp;start=0
I have never used POR-15 but have used Eastwood's Rust Encapsulator. I was happy with the results.
After reading the link and seeing how well Rustoleum did, I have been using it in certain places on my car. It has held up well and is much cheaper than some of the other products. _________________ Ghia Owner Emeritus |
