wicked450r Samba Member
Joined: April 12, 2007 Posts: 132 Location: Sunny Tucson, AZ.
Posted: Tue Mar 10, 2009 6:58 am Post subject: |
I hear you....I will be taken this weekend off from working on it...Will be back on it next friday....I hope like hell i can atleast trailer it home and finish the wiring here at my house....
I need:
Oil filter adt.
Oil hoses
Fuel tank bigger bungs welded on
mount fuel pump and filter
make 1 fuel hose
shifter to transmission connected
hoses to the remote breather
....And drive it..... _________________ Chris
2332 F.I. 60mm Turbo rail 351hp
TRX545R
My Rail Build
http://www.thesamba.com/vw/forum/viewtopic.php?t=339279 |
vwrides.com Samba Member
Joined: January 31, 2006 Posts: 191 Location: Central MS
DirtGhost Samba Member
Joined: September 19, 2007 Posts: 547 Location: Greensboro,NC
Posted: Tue Mar 10, 2009 7:22 am Post subject: |
wicked450r wrote: |
I....And drive it..... |
Me too !!! I miss mine . Almost getting ready for body work
_________________ Orange Boxx Design and Fabrication |
manxbuggyman Samba Member
Joined: November 04, 2005 Posts: 195 Location: Baldwin City KS
Posted: Tue Mar 10, 2009 9:21 am Post subject: |
The car looks great. I think you should put a support from the engine cage to the muffler. I have seen many crack with out support.
my .02 |
Posted: Tue Mar 10, 2009 8:15 pm Post subject: |
manxbuggyman wrote: |
my .02 |
Im not so sure i like the exhaust, I may redo it....I guess i should let my wife say yay or nay or the tip _________________ Chris
TRX545R
My Rail Build
xirxious Samba Member
Joined: November 12, 2007 Posts: 665 Location: Seattle
Posted: Wed Mar 11, 2009 1:14 am Post subject: |
Does those beams not require the torsion tubes to hold them on? I looks like a threaded nut goes through there? Do you have to turn the inside of the beams for an inch or 2 to fit? I looks like they've been machines, but it could just have been ground or something. |
Posted: Wed Mar 11, 2009 5:41 am Post subject: |
xirxious wrote: |
My front has no torsions in it, and those are a thru rod the coil overs hold the car up....The beam is made out of Chromoly tube _________________ Chris
TRX545R
My Rail Build
Posted: Thu Mar 12, 2009 6:51 am Post subject: |
wicked450r wrote: |
Man you gotta lot to do to yours.....I was at that stage |
I am way past this stage. I am now dry fitting all parts. Mirrors. upper eletric box. Head lights upper lower. Gas tank is made and straps welded in. All shocks on it. we are moving along pretty well. Body work coming up soon. _________________ Orange Boxx Design and Fabrication |
Posted: Sat Mar 14, 2009 7:12 pm Post subject: |
Got most of my Gauges, still need to get the Boost gauge (Its on back order for 4 weeks). The fuel tank should be welded up and the shifter should be ready to install...Hoses and Remote oil filter housing, and fuel lines. and i should be able to fire it up _________________ Chris
TRX545R
My Rail Build
nukeworker Samba Member
Joined: September 21, 2005 Posts: 490 Location: Area 51
Posted: Sat Mar 21, 2009 9:57 am Post subject: |
That thing is SWEEEEEET! |
KrAzY-BaJa Samba Member
Joined: May 22, 2008 Posts: 1409 Location: Sacramento CA.
Posted: Mon Mar 23, 2009 5:40 am Post subject: |
Thanks guys...I got almost all th ewires ran yesterday and I need two steel Braided hose made up from my fuel filter to pump and from pump to fuel rail....I will make the oil lines tonight when i get home from work and drop the oil add new oil and should be good to go _________________ Chris
TRX545R
My Rail Build
Posted: Tue Mar 24, 2009 11:37 am Post subject: |
Still looks very nice, how much did you have to upgrade the motor for the turbo? Just forged pistons or the whole HD lower?
On the Cro-mo tubes you used for the beam, was there a standard wall thickness that fits the bushings or did that need machining on the ID (I thought I saw marks on the inside of one) or do you just match the bushing to the tube? I'm looking into doing the same idea and it seems like I can just start with 1-3/4"? tube and .120 wall and custom fit the bushings. I was going to do some work to get the gap as small as possible on them. I have some 10" travel shocks, butthe springs were made for something lighter. |
Posted: Thu Mar 26, 2009 6:29 am Post subject: |
xirxious wrote: |
Thank you very much....The motor is a Built motor H beam rods forged pistons,
The Chromoly beam is standard wall size (.095) we put the bushings in the fit. you can always get a different weight springs for those shocks _________________ Chris
TRX545R
My Rail Build
Posted: Wed Apr 01, 2009 10:37 pm Post subject: |
Ok i got it home and took all the wiring outta the car, started from scratch...I just fired it up a few minutes ago...WOW...what throttle response it has. now i just need to wire loom th ewires and build a center console from the gauges and the ECU _________________ Chris
TRX545R
My Rail Build
