swanlakers Samba Member
Joined: July 17, 2005 Posts: 370 Location: Lost in space
Posted: Wed Jan 28, 2009 4:46 pm Post subject: Maico disk brakes |
I have a set of Maico disk brakes that have ALUMINUM roters, not steel. I haven't been able to find out anything about this version of maico's. The five pointed rings look just like the steel ones, only they have casting marks on the edge. I am afraid to use them, I think they would be bad news on a long down hill. Anyone know anything? _________________ https://www.thesamba.com/vw/archives/lit/56ghia/cover.jpg |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76897 Location: Sneaking up behind you
Posted: Wed Jan 28, 2009 4:47 pm Post subject: |
I'd never seen aluminum rotors and certainly would not use them. _________________ Glenn
Member #1009
#BlueSquare |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Wed Jan 28, 2009 6:48 pm Post subject: |
The concept is there, Aluminum tends to radiate heat, not hold it like steel, which is why engine blocks are made outta it. It would have to be some seriously hardened aluminum to use for rotors though! Sounds scary to me too. |
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2521 Location: Australia
Posted: Wed Jan 28, 2009 9:32 pm Post subject: |
I have had them on my '59 for nearly 20 years with no problems.
They were also on the VW's in the Mobil Gas Trials in Australia.
There were the steel sets also. I don't know why, but in Australia, we got the alloy sets, and in the USA the steel sets are more common.
Ate also made sets for 356's
_________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 726 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Wed Jan 28, 2009 10:27 pm Post subject: Maico Brakes / German Manufacture |
Maico brakes were made in Germany SPECIFICALLY for VW's, Porsche 356 and Peugeot cars. Im sure they have done all the R&D and would offer a product that was not going to endanger peoples lives. Porsche was using their "annular" brake system that was similar to Maico. Porsche also use 60mm wide brakes on their race cars for increased braking power.
Posted: Fri Jan 30, 2009 11:29 am Post subject: |
Just to be clear, its the part that the calipers grab thats aluminum, not the part that contains the wheel bearing. Even the Porsche drums are lined with steel. Has anyone ever heard of the part that the caliper or shoe touches being aluminum? _________________ https://www.thesamba.com/vw/archives/lit/56ghia/cover.jpg |
Posted: Fri Jan 30, 2009 12:07 pm Post subject: Maico Brakes |
The caliper is mounted on the spindle as it should be for holding strength. The caliper "grips" the steel ring as it passes through the pads. The hub is made from high quality aircraft forged aluminum and has the wheel bearings and supports the weight of the car. The steel ring is bolted to the hub and goes along for the ride until the brake is applied......then it grips the steel ring and slows the car down. Simple technology! Cheers! Mr. Okrasa |
IN2VWS Samba Member
Posted: Sat Jan 31, 2009 8:34 pm Post subject: |
Are you sure they are Maico?
What does the caliper mount to?
FYI, this is what Maico pads look like.
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
Posted: Sat Jan 31, 2009 8:47 pm Post subject: |
pretty sure.
There is a mounting bracket not shown in the picture.
Perhaps I wil;l mount them on my 62 convert. The would be pretty cool with a Judson supercharger. _________________ https://www.thesamba.com/vw/archives/lit/56ghia/cover.jpg |
IN2VWS Samba Member
Posted: Sat Jan 31, 2009 9:08 pm Post subject: |
Here is a catalog pic of the other version. These were sold by Poly Pad Products in the USA, I think Empi sold them also....not sure..
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
IN2VWS Samba Member
Posted: Sat Jan 31, 2009 10:55 pm Post subject: |
No disrespect, but they do not look like Maico brakes.
The Vesrah name you mentioned, are used on japanese motorcycles, and is a japanese company.
The slots on your brakes look way different than any of the Maicos pictured in this thread.
This is what Maico calipers look like:
http://www.thesamba.com/vw/forum/viewtopic.php?t=173015 _________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Mon Feb 02, 2009 1:50 am Post subject: |
If the actual disc is aluminum, it is not original. Someone replaced the steel/iron disc with aluminum.
Notice the inch bolts too? Maiko would never use such a screw. _________________
Herbie3Rivers Samba Member
Joined: May 07, 2001 Posts: 1271 Location: Pittsburgh, PA
Posted: Tue Feb 03, 2009 2:18 pm Post subject: |
How on earth do you find replacement rotors for these? are they available? _________________ Yeah I like Herbie AND New Beetles. Got a problem with it? Tough.
2010 New Beetle Final Edition
2009 Ford Mustang Bullitt
1999 New Beetle GLS
1983 Mercedes 300D
1974 Karmann Ghia
1972 Super Beetle
1970 Beetle Sunroof
1959 Original Herbie #6
1956 Oval
Three Rvers VW Club
Pittsburgh Vintage Grand Prix
Visit Herbie the Love Bug at LoveBugFans.com |
IN2VWS Samba Member
Posted: Tue Feb 03, 2009 4:02 pm Post subject: |
Herbie3Rivers wrote: |
How on earth do you find replacement rotors for these? are they available? |
The rotors should be easy to get made up. Laser cut maybe.
They are just a flat ground piece of steel. The pads are more difficult to make or buy. _________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
Richard Roth Samba Member
Posted: Tue Feb 03, 2009 7:41 pm Post subject: |
swanlakers wrote: |
here is apicture of the
maico's with aluminum rotors:
I bought these from the late Dave Mayes a few years back.
I remember when David bought them.
The seller said that he didn't have the original calipers and was trying to adapt the ones pictured.
Original Maico calipers have the Maico logo stamped in them. _________________ The problem with reality is that there's no background music !
1966 Empi GTV MKIV
1954 Kabriolett Beetle
1953 Porsche 356 1500S
1957 Cable brake standard model
1962 cable brake standard model
1956 23 window Samba
1960 Austin Healey 3000
1961 Corvair Greenbrier |
Simon uk Samba Member
Posted: Thu Feb 05, 2009 12:27 am Post subject: |
maico's are so cool looking, if you have alluminium rotors you could polish them up before installing them!
I would have thought that the caliper parts would be relatively straight forward to find - I always figured they were very similar or the same to the versions used on maico motorbikes?
Si. |
IN2VWS Samba Member
Posted: Sun May 16, 2010 3:39 pm Post subject: |
I found another set of Maicos recently. These are the steel version, but they are different than all the other steel versions I have seen. These have studs and not the holes for the wheel bolts.
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
IN2VWS Samba Member
Posted: Sun May 16, 2010 7:52 pm Post subject: |
I just cleaned up the rusty/dirty Maico shown in the previous pic. It has a goldish coating on it, that doesn't come off easily. I wonder if its the same coating that the 36hp engine cases had. Here is the after pic.
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
