dgrnga Samba Member
Joined: February 06, 2006 Posts: 224 Location: Macon,Georgia
Posted: Fri Jan 30, 2009 9:05 pm Post subject: Cutting New Rubber Mats (PIC) |
Plan on installing carpet and Mats tomorrow! Could use some suggestions on cutting out Rubber mats for Shifter and emergency brake!! Not sure how to make it look neat and round.
Search came up with little!!
Thanks in advance!
Gordon
youngnstudly Samba Member
Joined: October 21, 2005 Posts: 833 Location: Whine Country (SF Bay area)
Posted: Fri Jan 30, 2009 10:01 pm Post subject: |
Which shifter are you installing? If you use a stock shifter you will have an easier time since the stock shifter is like 5/16" diameter and the base is much bigger. I pinched the mat in the approx. area that I needed to trim and cut a small (1/2-3/4") slit where the crease or folded area was (to start the hole). I used typical household scissors with no problem. Same with the e-brake handle...Just make sure you position the mat where you want it before you slice that nice mat up. I followed the molded lines in the mat to trim my e-brake and it was actually fairly well positioned.
Here is the Wolfsburg mat that I installed with my Hurst shifter. I always install the mat over the shifter since it looks a lot cleaner to me and I don't have to cut the hole as big or be as accurate trimming the base. The fitment of the base took some time to trim tight and it is a PITA to remove the mat everytime I need to service the shifter, do anything inside the tunnel, or clean the floor mat. Notice that I haven't installed the heater knob as that would complicate removing the mat. I have since stitched up a leather boot for the shifter that hides the entire base. Oh, and I finally stitched up the rest of the carpet binding and the door panels but I haven't installed them yet .
_________________ The economy is in a state of disaster, we have NO time for common sense! |
dgrnga Samba Member
Posted: Sat Jan 31, 2009 6:26 pm Post subject: |
:) Thanks for the reply, Got closer today with installing carpet, but I was hoping for some sort of tool to punch out a nice circle for standard shifter. The emergency brake maybe alittle tricky. thinking about making a template and trace on rubber, then maybe a good pair of sissors will do the trick.
Still open for ideas?
Koffer Samba Member
Joined: December 07, 2002 Posts: 186 Location: Hopwell NJ
Posted: Sun Feb 01, 2009 8:50 pm Post subject: |
dgrnga wrote: |
Looking good I need to do this on my old girl too
You may want to look for someone with a cork gasket punch kit , a leather working type punch or you can maybe find a thin copper pipe the right size and use that as a punch ..
Ive used all of these for this type of stuff _________________ Todd
65 ruby red beetle |
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Sun Feb 01, 2009 9:19 pm Post subject: Cutting out the hole. |
X-acto Knife Firmly hold the mat around the area you wish to locate with one hand and pearce the rubber with the x-acto and with a up and down motion keeping the blade in hole you should be able to follow the holes shape, this will give you a very clean starting. you'll need a few blades as rubbing along the steel it will dull. but be carefull those things are sharp and they will bite if your not looking. |
dgrnga Samba Member
Posted: Sat Feb 07, 2009 4:03 pm Post subject: |
Completed cuts on new rubber mats. I wish I had kept the old ones to use as a template. The indentions were close to get me started.
Ended up using a Utility /Razor knife. With a new blade it made a neat cut.
Thanks for all the input!
Next is Uphostery!
codycat Samba Member
Joined: July 18, 2006 Posts: 1165 Location: Mobile, Alabama
Posted: Sat Apr 19, 2014 9:08 pm Post subject: |
re-activating this thread with a question
where do you find the grey e-brake boot and shift boot --- if my mats is supposed to be grey and im getting it from WW -- they do not sell grey boots that i can find---so where do these come from? _________________ Did you ever stop to think, and forget to start again?
Winnie the Pooh
Sometimes the questions are complicated and the answers are simple.
Dr. Seuss |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Sun Apr 20, 2014 3:52 am Post subject: |
They are often on eBay, at least lately |
grandpa pete Samba Member
