1971 baja bug
Page: 1, 2, 3  Next
smokey the bear
smokey the bear is offline
PostPosted: Sat Jan 31, 2009 10:34 pm    Post subject: 1971 baja bug Reply with quote
So i am new to the vw world and am learning as i go. but i have a 1971 vw 1600 dp. not a super. i have the baja kit and most of what i need. but i ahve a few questions. I was really thinking of doing an exoskeleton roll cage.but am not sure if that would be to much weight v.s. a 6 point cage. than if i did do the exoskeleton what do you guys think i should tie it into. I was also wondering what should i use for shocks. i have a limited income being i'm only 15 but i would like to be able to get some air and not bust anything. but mostly i would be in the mountons. and beings i'm new to this if there is anything that i should know that might help me in my build let me know thanks. Very Happy
SpenceSuper11
SpenceSuper11 is offline
PostPosted: Sat Jan 31, 2009 11:08 pm    Post subject: Reply with quote
I would suggest an inner roll cage. For one they're cheaper and two you can find many different variations pre fabbed. I saw a couple pictures of a bug with an external cage a couple days ago when I was wandering through the gallery. I'll try to find them again. It's a little ugly in my opinion if not done right.
1600cc '73 Super baja
Opinions expressed in this post are not necessarily shared by anyone who is not intelligent, sexy, well-off financially, and a great dancer.
SpenceSuper11
PostPosted: Sat Jan 31, 2009 11:20 pm    Post subject: Reply with quote
Ah, here we go. Found this on page 552 of the offroad section.
You'd have a lot of fab work ahead of you if you want to do anything like this.
vaderoni
vaderoni is offline
PostPosted: Sun Feb 01, 2009 12:44 am    Post subject: Reply with quote
^^^^Im sorry but that's disgusting Wink
Teach me, I may not know...
runslikeapenguin
runslikeapenguin is offline
PostPosted: Sun Feb 01, 2009 12:46 am    Post subject: Reply with quote
a little bit ugly? surely you jest. thats a whole lot of ugly right there.
to put it quite basically the cars body its self was designed to withstand a decent amount of force in the event of a roll over or crash. a roll cage is a secondary precaution and a key chassis component in most cases involving off road VW's.
most well built roll cages will include small external features to a roll cage, like tied in bumpers, running bars, and sometimes roof racks.
not to mention that there is really no bullet proof way to secure an external roll cage on a bug.
never forget 1-31-07
xirxious
xirxious is offline
PostPosted: Sun Feb 01, 2009 2:35 am    Post subject: Reply with quote
It looke like that was made to be removable? There are wing nut screws at the bottom?
nukeworker
nukeworker is offline
PostPosted: Sun Feb 01, 2009 7:52 am    Post subject: Reply with quote
Looks like somebody likes to weld. Laughing
corradolvr
corradolvr is offline
PostPosted: Sun Feb 01, 2009 9:01 am    Post subject: Reply with quote
Do an inner cage. If you're going to go to long travel eventually an inner cage will be a better option. That exo-cage should be in the abortions section. That thing is hidious d'oh! . You would have to tie the front end in and that would be a mess. That might make things difficult for a one piece front end as well.
I think they started to not divulge whether or not parts are from EMPI. That's probably the only way they can sell that junk. It's unescapable!
My Build Post
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...highlight=
smokey the bear
PostPosted: Sun Feb 01, 2009 9:31 am    Post subject: Reply with quote
ya thats not really what my idea of an exo looked like. it looks like someone never learned to bend pipe. At all. ok so inner is the way to go. so what should i do about shocks. this is going to be my daily driver but i want to be able to go offroad mabey get some air and not have to worry about breaking anything.
jj14u2c2
jj14u2c2 is offline
PostPosted: Sun Feb 01, 2009 11:08 am    Post subject: Exo design Reply with quote
Smokey,
Here are some pics that were posted by Adrenalin Junky awhile ago. I think if you compare these pics with ones SpenceSuper11 posted, it could look awesome. The rear exo on the yellow Baga is tight because it follows the flow of the existing body lines. If you would continue to follow the body line flow forward and over the body properly I think it would be an intimidating sight when you pull up behind someone and they see you in their rear view mirror.
Even though it would take some skilled tube bending it could be done.
jj14u2c2
jj14u2c2 is offline
PostPosted: Sun Feb 01, 2009 11:09 am    Post subject: Reply with quote
smokey the bear
PostPosted: Sun Feb 01, 2009 3:08 pm    Post subject: Reply with quote
ya i dont really have the money for that sweet of a set up. but that bug is B.A. but what do you guys think i should do for shocks? dont mean to sound like a broken record but but that is the one thing that i really have no clue on.[/img]
runslikeapenguin
PostPosted: Sun Feb 01, 2009 3:17 pm    Post subject: Reply with quote
how much do you want to spend? thats all it really boils down to.
smokey the bear
PostPosted: Sun Feb 01, 2009 3:20 pm    Post subject: Reply with quote
well i dont want to spend more than 500 dollars at max.
riNR
riNR is offline
PostPosted: Sun Feb 01, 2009 3:53 pm    Post subject: Reply with quote
That's just wrong man! Who in their right mind would build that abortion?
runslikeapenguin
PostPosted: Sun Feb 01, 2009 4:20 pm    Post subject: Reply with quote
look at a set of bilsteins, something like this.
http://www.eshocks.com/bil_ORsb.asp?Series_Index=Q8&Manf=All&SubChar=Q&Spec=
LSK
LSK is offline
PostPosted: Sun Feb 01, 2009 6:16 pm    Post subject: Reply with quote
with some emulsion 2" FOAs you might be able to keep it under $500
smokey the bear
PostPosted: Sun Feb 01, 2009 9:38 pm    Post subject: Reply with quote
i dont have the money to change out trailing arms ether. so i would be putting these shocks in with other stock things. such as the shock towers and so on. so i really am not sure what to do with the suspension. thanks for alll the ideas i'm not sure if those shocks would fit or not i really have no clue i was looking at these.
http://www.chircoestore.com/catalog/product_info.php?cPath=64_200&products_id=2025
runslikeapenguin
PostPosted: Sun Feb 01, 2009 9:58 pm    Post subject: Reply with quote
those are good to. someone else might want to chime in but theres a part number for some bilsteins that have the right upper mount for a ball joint front end. i cant remember.
smokey the bear
PostPosted: Mon Feb 02, 2009 4:54 pm    Post subject: Reply with quote
i dont have a ball joint front end.
Page: 1, 2, 3  Next
Copyright © 1996-2015, Everett Barnes. All Rights Reserved.
