Drtbug1 Samba Member
Joined: February 09, 2009 Posts: 4 Location: San Diego
Posted: Mon Feb 09, 2009 7:03 pm Post subject: New to the forum |
hey guys im new to the forum, and im just getting my '67 back together and on the streets and dirt again. Just a young guy trying to have some vw fun =D . i noticed we like pics on here so heres some pics from my build for you guys. i also would like to know what i can do for the front end it has ball joint beam and i've heard of people putting thing beams on. are they any higher or wider than a stock bug beam?
tell me what you think. |
Shawng_88 Samba Member
Joined: August 16, 2008 Posts: 37 Location: Poway, CA
Posted: Mon Feb 09, 2009 7:07 pm Post subject: |
I have a thing beam, arms & spindles on my car....it is wider and taller than stock, stronger too...it was on the car when i bought it...
_________________ '71 Standard Baja
1914, 002, Thing beam |
Posted: Mon Feb 09, 2009 7:16 pm Post subject: |
Does it bolt up to a ball joint pan head or does it need to be changed? |
Posted: Mon Feb 09, 2009 7:38 pm Post subject: |
from what i understand yes it is a straight bolt up deal _________________ '71 Standard Baja
Posted: Mon Feb 09, 2009 8:11 pm Post subject: |
Is yours a stock thing beam? I like the height of yours. Mine sits stinkbug and I would like to bring the front up and wider but don't think I'm capable of replacing the pan head for a link pin. |
runslikeapenguin Samba Member
Joined: August 07, 2005 Posts: 4674 Location: Federal way WA
Posted: Mon Feb 09, 2009 10:11 pm Post subject: |
thing parts are a direct bolt up, you can get a whole beam or just the arms and spindles and load them onto your existing balljoint beam. _________________ never forget 1-31-07 |
DesertBob Samba Member
Joined: February 09, 2004 Posts: 1245 Location: Goodlettsville, Tennessee
Posted: Mon Feb 09, 2009 10:29 pm Post subject: |
Welcome to the Madness. Your car looks great. I am running with Thing Spindles and Arms on a Type 1 Beam.
_________________ All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business
74 Super Beetle (German Look Project)
Full Flow 1776 with 36 Dells, 4 wheel drilled and slotted disc brakes, Porsche 7x17 Turbo Twists, Topline Maxx Struts, Camber kit, 7/8" Front Sway bar, Rear Sway bar, Urethane bushings all around. |
Posted: Mon Feb 09, 2009 11:28 pm Post subject: |
is there an advantage to having the thing parts are the arms, or the beam or anything higher or longer?... is it worth doing? will it bring my front up any? or widen it? |
Lotrat Samba Member
Joined: December 08, 2007 Posts: 2528 Location: Vista, CA
Posted: Tue Feb 10, 2009 12:19 am Post subject: |
Drtbug1 wrote: |
The beam is beefed up a little, but it's heavier. Thing spindles are different. The bottom ball joint is facing the correct way so it won't pull apart. The ball joint are bigger and have more travel. You get lift without stiffening up the ride. You can always cut and turn the beam for even more lift.
Stole these from somewhere...
T1 on top, thing on bottom:
T1 on the left, thing on right
T1 near, thing far
