bon2198 Samba Member
Joined: August 04, 2008 Posts: 1969 Location: Nashville, GA
Posted: Sat Mar 07, 2009 5:33 am Post subject: Jaycee Push Rod Tube |
Ok, the big metal washer obviouselly goes on the piece without the spring. now, on the washer it says on one side "this side down". does the side that says "this side down" face the seal or the push rod tube? i'm guessing the push rod tube side.
also does the spring go towards block or head? _________________ 1970 VW Beetle 1776cc MOFOCO w/hydraulic lifters, 042 heads and dual dellorto's
"It's better to be hated for what you are than loved for what you are not"
At the end of the day it's YOUR car so do what YOU want to it. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5593 Location: 37.5N 77.1W
Posted: Sat Mar 07, 2009 8:09 am Post subject: |
Quote: |
Ok, the big metal washer obviouselly goes on the piece without the spring |
It wasn't to me. I put one on both sides. Long story.
Quote: |
"this side down" face the seal |
That's how I put them on. BUT as you can tell from above, I don't let not knowing what I'm doing hold me back. |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Sat Mar 07, 2009 12:30 pm Post subject: washer |
It doesn't matter which side the washer faces on the pushrod tube.
I believe those are just shims from another application-eg. rocker arms (at least my JayCee's were similar), that also happen to fit the tubes.
I put the "writing" away from the seal, just in case the indentations of the letters caused a leak... _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
john7 Samba Member
Joined: August 06, 2003 Posts: 1542 Location: Garden grove ca
Posted: Sat Mar 07, 2009 1:43 pm Post subject: |
neil68 is correct
the washer is a modified valve spring shim for a V8 you can put it on either way.
jaycee reccommends puting white grease on the o-rings and rtv on the seals. i have installed them with and w/o rtv and the ones with rtv dont even thing of leaking. with out rtv it seeped a little. _________________ Jesus Saves
Slot Mag King!
I accept Paypal, CASH, GOLD, SILVER, COINS, GUNS & money orders. |
Posted: Sat Mar 07, 2009 4:33 pm Post subject: |
cool thanks... yeah, i always put rtv on seals, and i use grease on my valve cover gaskets, so i have some laying around... thansk for the help!! _________________ 1970 VW Beetle 1776cc MOFOCO w/hydraulic lifters, 042 heads and dual dellorto's
