grailoc Samba Member
Joined: March 25, 2004 Posts: 1441 Location: FRANCE and now QUEBEC city
cab2276 Samba Member
Posted: Tue Oct 21, 2014 9:08 am Post subject: |
Salut Jérome,
Je suis depuis longtemps la resto de ton bus qui est superbe et me sers de tes plants de ciel de toit pour refaire le mien
Je n'ai pas le bus sous la main (il est en révision) et il me manque une cote pour finir de couper mes planches
l'as tu noté quelque part ?
et j'imagine que cette partie s'enfonce dans la boite diffuseur d'air ?
peut être as tu une photo du détail de cette partie une fois monté ?
Merci beaucoup pour ton aide
I'm sorry for the french but my english is very bad
Guillaume _________________ Guillaume SO 23 walk-thru
[url=http://i43.servimg.com/u/f43/16/83/88/82/bannie11.jpg]Click to view image/url] |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Tue Oct 21, 2014 9:28 am Post subject: |
Is there a source for the gold trim? _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
sled Samba Member
jjjjack Samba Member
Joined: August 08, 2005 Posts: 1013 Location: Gainesville, FL
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Tue Oct 21, 2014 4:05 pm Post subject: |
cab2276 wrote: |
Salut Jérome,
Guillaume |
If this is a drawing of the subhatch roof wood then the drawing is incorrect. The red piece does exist, the front edge is straight across from corner to corner. |
Posted: Wed Oct 22, 2014 3:45 am Post subject: |
You can see in these photos that the og piece is straight across on the front edge. I found that the grill on the fresh air vent had to be put on after the wood was in place to allow it so sit right. |
Stocknazi Samba Member
Posted: Wed Oct 22, 2014 5:27 pm Post subject: |
buseric wrote: |
cab2276 wrote: |
Salut Jérome,
Guillaume |
Has someone with an og ceiling panel comfirmed that the deminsions posted above are correct? _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
bubba Samba Member
Posted: Wed Oct 22, 2014 5:58 pm Post subject: |
grailoc wrote: |
let`s say 5 meter required by bus,
5000/5 = 1000 bus |
Sounds like a lot of footage.. But at .15 foot.. Is still worth it... I'm down for a set to do all three tables _________________ ***WANTED***
SO-23 Cargo net hooks...
for sale
curtain Bungee cords for SO23, 22, 33 ,34 ,35
http://www.thesamba.com/vw/classifieds/detail.php?id=1587591 |
Clara Samba Member
Posted: Fri Oct 24, 2014 6:27 am Post subject: |
StockNazi wrote: |
buseric wrote: |
cab2276 wrote: |
Salut Jérome,
Guillaume |
If this is a drawing of the subhatch roof wood then the drawing is incorrect. The red piece does - not -exist, the front edge is straight across from corner to corner. |
Has someone with an og ceiling panel comfirmed that the deminsions posted above are correct? |
I have found that whole the so42 has the notch for the fresh air vent , the earlier Westys do not have the notch.
Also, the cab roof panels for the so-42 are slightly shorter. The earlier Westys use stock for Kombi length cab roof panels.
The seam between wood and grey for the so42 falls in the middle of the metal brace. While the seam for the earlier westy falls at the back edge of the metal brace and the screws go into the wood bow.
This means the middle large roof panel for an so42 is slightly longer than the so23 version.
X2 on what buseric said
I have used several slightly different patterns for the roof panels. There is some wiggle room there.
That Limba looks lovely and really pops! |
Posted: Fri Oct 24, 2014 7:15 am Post subject: |
Clara wrote: |
Thanks providing clarification and differences between roof panels. As I said earlier, since back in the time I did not have any original master to start from, I used pictures information and measurements I was able to find and deduct, which in the end made my roof restoration work well. _________________ My 59 low light ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=452128
My 56 beetle convertible: http://www.thesamba.com/vw/forum/viewtopic.php?p=7796259
My 60 SO23 westy: http://www.thesamba.com/vw/forum/viewtopic.php?t=341539
My oldspeed 36hp autotechnik express build: https://www.thesamba.com/vw/forum/viewtopic.php?t=670827
My garage build: http://www.garagejournal.com/forum/showthread.php?t=199438 |
