Oval 53 from Belgium
Page: Previous  1, 2, 3 ... 5, 6, 7 ... 10, 11, 12  Next
palmgreen57
palmgreen57 is offline
PostPosted: Sat Sep 27, 2014 10:33 am    Post subject: Reply with quote
Hi
some pics of the day,
the heater boxes are painted, all nuts, bolts have been black zinc plated
I received few weeks ago from finland ( thx you Mika ) the NOS head cylinder breather I needed Very Happy
palmgreen57
PostPosted: Sat Sep 27, 2014 10:35 am    Post subject: Reply with quote
the engine in work in progress
palmgreen57
PostPosted: Sun Sep 28, 2014 9:24 am    Post subject: Reply with quote
Hi
today, clean job of the oïl filler,
I didn't know that it could be opened, once done this what I took out
I'm asking if it's was not like something to absorb oïl from engine
there is like metal shaving Inside..... maybe somebody know Question
does exist something to replace it ?
palmgreen57
PostPosted: Tue Sep 30, 2014 3:13 am    Post subject: Reply with quote
Hi,
nobody has ever cleaned it ?
I'm reassemblating my heater boxes, I have a question :
does the flap rod has to go inside or outside ?
I've found differents pics who show both, does somebody know what is the factory way ?
palmgreen57
PostPosted: Tue Sep 30, 2014 11:10 pm    Post subject: Reply with quote
Hi, nobody Question Question
palmgreen57
PostPosted: Sat Nov 01, 2014 12:45 pm    Post subject: Reply with quote
Hi
this week end, I replaced the old "breather" by this kind of material for wash :
it's similar material, I hope it'll work
here the pics :
I also changed the seal of the engine bay
I found the front one with only a single lip ( the old one was double )
what it should be ? does the new one I put is in the good way ?
vwsonmybrain
vwsonmybrain is offline
PostPosted: Sat Nov 01, 2014 7:57 pm    Post subject: Reply with quote
Yes, the front one has only a single lip and I do think you have it in correct.
palmgreen57
PostPosted: Sun Nov 02, 2014 12:18 am    Post subject: Reply with quote
thank you for your help !
so it means that this seal has been changed one time ago by a double lip
will continue one the engine detailling
palmgreen57
PostPosted: Sun Nov 02, 2014 12:53 pm    Post subject: Reply with quote
now the gear box is cleaned and ready to be checked
as the 4th gear is not working fine
all bolts has been black zinc plated, nos boots, nos boots belts, tube and brake sand blasted and époxy painted
palmgreen57
PostPosted: Tue Dec 02, 2014 11:26 am    Post subject: Reply with quote
Hi
here some more news about the 53
le left side spring handle was broken, I received last week NOS springs from finland ( thx mika again )
I cleaned up it and fit perfect, now it's better
I finished also my 53 strap air cleaner, the top needed to be repainted, we do with lazaa my friend "patina" paint who match perfectly with OG paint
now need to check the carb
I received my air tube also Very Happy and oïl reflector, now cleaned
palmgreen57
PostPosted: Tue Dec 02, 2014 11:42 am    Post subject: Reply with quote
palmgreen57
PostPosted: Tue Dec 02, 2014 11:47 am    Post subject: Reply with quote
palmgreen57
PostPosted: Tue Dec 02, 2014 1:06 pm    Post subject: Reply with quote
Peter_N
Peter_N is offline
PostPosted: Wed Dec 03, 2014 7:57 am    Post subject: Reply with quote
all bolts has been black zinc plated..
Love your attention to detail!
Can you enlighten me on the process of black zinc plating. Most plating companies here (in Holland) only offer ugly yellow (cadmium?) plating.
Keep the updates coming
My 1958 PGSG project topic
palmgreen57
PostPosted: Wed Dec 03, 2014 12:54 pm    Post subject: Reply with quote
Hi
Here are the 17mm 4 bolts cylinders Wheel I was looking for
I will clean up them and black zinc plate the bolts
palmgreen57
PostPosted: Wed Dec 03, 2014 1:36 pm    Post subject: Reply with quote
Hi Peter
thank you for your coment Wink yes I like to pay attention to detail Wink
so the process is simple :
when you have brushed all your blots, nuts, washers till arrive to bare metal
you give it to a zinc plater, I have the choice between, gold as you said very ugly render, silver as classic zinc plated, or black zinc plated
I can ask the technical name of that if it can help you
here pics of these parts when plated :
Suboval
Suboval is offline
PostPosted: Thu Dec 04, 2014 9:28 am    Post subject: Reply with quote
palmgreen57 wrote:
Hi Peter
That's beautiful looking!
It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history.
palmgreen57
PostPosted: Thu Dec 04, 2014 2:03 pm    Post subject: Reply with quote
thanks Very Happy
but needs lot of work before , many hours of brushing and don't remember how many fingers hurt !
Peter_N
Peter_N is offline
PostPosted: Sat Dec 06, 2014 2:59 pm    Post subject: Reply with quote
palmgreen57 wrote:
Hi Peter
Hi,
I did some searching on the internet about the plating. I think they use manganese phosphate or zinc phosphate. There is also a method called 'black oxidizing' ( http://www.caswellplating.com/metal-finishing-solutions/black-oxide-kits.html ) which you can do a home but I read it's not durable on exposed bolts and stuff.
I'll search for a company who can do it for me because it looks very nice imo.
palmgreen57
PostPosted: Sun Dec 07, 2014 1:13 am    Post subject: Reply with quote
Hi Peter
yes you're right about the name you said,
the other way called black oxidizing, in french "brunissage" is used for example to protect cannon of weapons, it work and stay nice if you take care of it..... if you have bolt and small parts who are exposed they will rust fast Sad
if you want to send your parts un France, I can help you Smile
Page 6 of 12
