KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Mon Oct 13, 2014 7:27 pm Post subject: |
It may or may not need replacing. But I'd definitely remove and clean it, and check the balls and races for signs of wear. If none are found, pack it with a good moly EP grease, a new seal, and you should be good to go.
With the arm out, check your inner diagonal arm bushings. Rubbers are NLA, just urethane. If you use the latter, get some good urethane grease and use it generously. If you don't, they'll eventually squeak and drive you nuts. |
Bobnotch Samba Member
Posted: Mon Oct 13, 2014 8:32 pm Post subject: |
W1K1 wrote: |
That's just what's left of the seal that needs to be replaced, although if you're in there I would replace the ball bearing and all the lube in there since you're in there anyways |
Yup, same here. You can use a punch to knock the old bearings out (after removing the snap ring), clean the garbage out, install new bearings and reinstall the snap ring and install a new seal. Then finish putting it back together. This was what I did along side the road on a car I bought 10 years ago. I also suggested this above (previous page).
Remember, these cars were designed to be serviced, and removing, cleaning and packing the bearings were something that's supposed to happen every 30,000 miles (but doesn't). Most will just run them until they fail, then replace the bearings, add grease, and continue to drive. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
skorchindustries Samba Member
Joined: August 06, 2012 Posts: 20 Location: Granada Hills
Posted: Mon Oct 13, 2014 9:32 pm Post subject: |
You guys are fantastic!
This is a breath of fresh air for me. I've driven this squareback about a total of 3 miles since the day I bought it a few months ago.
I didnt like the shiny metal showing in between the bearing carrier and the axle shaft, so I tore her down, and posted up a nasty greasy picture.
I cleaned up what I was looking at, and took a few more pictures to give you guys a better idea of what I'm working with.
Looking forward to installing new bearings and grease! |
the north wind Samba Member
Joined: August 23, 2007 Posts: 102 Location: Portland, OR
Posted: Thu Oct 16, 2014 11:07 am Post subject: |
Getting a new windshield and seal installed today. Added new sunvisors and clips, and hope to get a new passenger side mirror installed this evening. Hoping the new seal takes care of the leak coming in through the front passenger area, but regardless, the window was super hazy in the corners and had multiple cracks and such. Excited! |
72bajasquack Samba Member
Posted: Sat Oct 18, 2014 9:47 pm Post subject: |
Today i bolted my kadrons and tins on and took it down the block
j2004r1 Samba Member
Joined: August 18, 2009 Posts: 34 Location: Temecula, CA
Posted: Mon Oct 20, 2014 1:51 pm Post subject: |
Drove her out of my driveway for the 1st time after 3 solid years of restoration. UNREAL feeling!! _________________ -Jay
'65 1500 S Notch "Insomnia" |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Thu Oct 23, 2014 4:51 pm Post subject: |
Took delivery today
First drive was to the car wash to knock the nasty off
Cleaned up and tucked away for the night
Got some small stuff to do, it's pulling to the side when breaking, horn not working, trunk light, small small stuff. |
JeeJeeJason Samba Member
Joined: May 23, 2014 Posts: 234 Location: Bay area, CA
Posted: Thu Oct 23, 2014 5:09 pm Post subject: |
That thing is NICE! |
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
Miguel Parot Samba Member
Joined: February 09, 2014 Posts: 23 Location: Macon, France
Posted: Sun Oct 26, 2014 11:38 am Post subject: |
Cleaned the car, and drove it to a place that I like very much, near my home.
It is called the Solutre Rock, a prehistoric site, and the vines behind the car produce the delicious pouilly-fuisse white wine.
When fall comes around the vines will turn yellow - orange - red, it will be magic !
Erik G Samba Member
Posted: Mon Oct 27, 2014 2:12 pm Post subject: |
Enjoyed driving around this weekend
Posted: Mon Oct 27, 2014 2:50 pm Post subject: |
After 2 show weekends in a row, I now finally get to address little gremlins today like horn short, alignment and vent window adjustments, whew!! I have to say...it was so cool to get the reactions when I took my beloved little "German chick" out to a predominantly American-Muscle car show and shook up the crowd a bit.
chaosisme Samba Member
Joined: August 29, 2005 Posts: 1256 Location: Orange County, Ca
Posted: Mon Oct 27, 2014 4:14 pm Post subject: |
Finally found a nice original steering wheel to replace the one in my car and I installed it today. _________________ '65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's |
Slow 1200 Samba Member
Posted: Wed Nov 12, 2014 6:03 am Post subject: |
Slow 1200 wrote: |
thought I had dirty idle jet on the left carb, it was clear, on reassembling and testing realized the carb is dripping fuel when running, and with engine stopped it dumps gas like it's no ones business!! pretty sure my brand new oil is loving that
time to check float, needle and seat....it's not even funny anymore how many times I've had to take this carbs apart |
well, after changing gaskets, needle and seat and checking everything it still dripped gas...then I changed the fuel pump and it worked flawlessly!
turns out the rebuild kit I used for the fuel pump had too strong of a spring and it's basically worthless |
Beechboy90 Samba Member
Joined: November 11, 2006 Posts: 67 Location: Bradenton, Florida
Posted: Sat Nov 22, 2014 4:39 pm Post subject: Shining up Gertie... |
I finally had my "Gertrude" Registered and insured, so of course she needed to have the Oxidation knocked off, and is quite the little time capsule.
Even has the original POLYESTER tires..
now I have to knock out a big cleanup job on the interior.. _________________ --Jason--
I have been putting off my quest to be the perfect procrastinator. But Someday.... maybe... |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Sat Nov 22, 2014 5:14 pm Post subject: |
Yes! and it has factory Disc Brakes, Fuel Injection and Automatic. The three things old VW's aren't known for.. one owner (73K) before the guy I bought it from, and he just cut off the heat exchangers and sold it to me..
A lot of components are in great condition, so anyone needing photos of anything of "how it was suppose to look" originally let me know!
--Jason _________________ --Jason--
Posted: Sun Nov 23, 2014 4:48 pm Post subject: Dash Clean up day!! |
I know it doesnt look like there is that big of a difference, but I was able to magic eraser the snot out of the dash and gauges.
It got dark so quickly so sadly the pics aren't as clearly noticeable as possible.
Anyone know the best method for cleaning the white headliner without tearing it up? I know I will have to be so careful as it feels strong, but it is over 45 years old...
AREN Samba Member
Posted: Fri Nov 28, 2014 4:27 pm Post subject: |
take off body from pan, now i wait for sandblast and next metalwork
Posted: Fri Nov 28, 2014 6:24 pm Post subject: |
Got home last night to see a little puddle of gas under the front of the 71...fuel pump had developed a leak. So, today I put on an Airtex E2000 and all new fuel lines and clamps under the tank. _________________ 71 Elm Green FI A/T Squareback |
