dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Thu Apr 18, 2013 5:17 pm Post subject: |
that thing is so badass
doesnt look quite street legal
cant wait to see it painted |
northstarbeetle Samba Member
Joined: February 06, 2009 Posts: 160 Location: golden co
Posted: Thu Apr 25, 2013 5:02 am Post subject: |
dirtkeeper..
colorado is pretty lax on open wheel and none dot parts.. already been regisered... so i dont need an inspection in colorado..ill just try not to draw unwanted attention.. lol
plates are either gonna be ..
V8BEETL
or V8 VW
finished window scoops..
LOOK WHAT I GOT!!!
have to do a few mods to get them on..should be on and charged by the end of the week!!!! _________________ GRIP IT AND RIP IT!!!
Heres my build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=344748&sid=43494cd783cdc3787d870e8b8aba65d6 |
bajamike560 Samba Member
Joined: December 11, 2009 Posts: 544 Location: Vancouver WA
Posted: Thu Apr 25, 2013 2:11 pm Post subject: |
Like the scoops.
Drooling on the shocks.
Mike _________________ Jackpot motorsports |
Darthdaddy Samba Member
Joined: December 22, 2012 Posts: 4 Location: San diego
Posted: Fri Apr 26, 2013 1:50 pm Post subject: |
OMG That is bad ass! I've been reading this thread for two years. Since i had my baja. Keep it up and dont give up. you havent so far. needless to say i'm jealous. |
riNR Samba Member
Joined: June 28, 2006 Posts: 1223 Location: Whitby, Ontario, Canada
Posted: Sun Apr 28, 2013 5:45 am Post subject: |
I think what I admire the most about this build is that you're thinking outside of the box. This vehicle really has some creative "one off" touches that set it apart from most high dollar baja builds I've seen. I know if someome told me they were going to build a super Beetle baja with a whale tale I would have thought they were nuts but you did an awesome job of it.
The other thing I like about this build is that while it has a pretty complex drive train it doesn't look like a super complicated vehicle. Everything looks simple to repair / replace and everything seems so accessible to get at.
You obviously have an incredible "mechanical" mind, and it surely shows in this masterpeice you have created. Keep up the awesome work. This is an inspirational build, and don't be suprised when others copy some of the aspects of your build.
Kudos!
riNR |
Posted: Mon May 06, 2013 9:33 pm Post subject: |
Thanks for all the great comments on my build.. It's my baby!!! Love it!!
I finally got to take it for a ride last week!! It was a blast to drive.. everything worked out really good .. It shifted nice.. gearing seems to be awsome!! the shocks seem to be set up really Perfect... It handled great on the pavement.. No pulling or tracking of any kind!! Tons of power .. But handled it well.. No problem running super charger next year!!
steering was a little stiff to turn.. and Brakes are a little weak.. Reblead them and they got a little better.. Do u think I need to mess with different size master cyl bore?? Or just better brakes!!
Also the fuel pump was making some bad noise at one point.. shut it off and it went away.. i was wondering if the foam in tank is restricting flow??? Do I need some sort of tip in the tank hose? It Could just be a bad pump..
But all in all I was very stoked on the first run!! l
Ill get some new pics posted with shocks... Also installed some mirrors can't see anything behind the car!!
I'm now building a trailer to haul it!! Bought a cheap beat up car hauler, Raising and widening the deck so i can drive over tires.. _________________ GRIP IT AND RIP IT!!!
Heres my build:
riNR Samba Member
Posted: Tue May 07, 2013 7:00 pm Post subject: |
If you're running one of those little anodized in line fuel filters they will kill the electric fuel pump as their flow rate is to low for the pump. |
Bad_chopper Samba Member
Joined: August 15, 2012 Posts: 295 Location: Portland, or
Posted: Wed May 08, 2013 10:10 pm Post subject: |
Since your running a v8 are you using power steering? If so run a hydro boost brake set up. Then you can have a power rack and pinion also. Its been a while since I read threw the whole thread so I don't remember all the specifics.
Everything else on this build is cool as heck, power breaks and steering would just add to it lol. _________________ my build page http://www.thesamba.com/vw/forum/viewtopic.php?t=536267 |
Posted: Mon May 27, 2013 4:00 pm Post subject: |
i just got back from first breakin trip,we went down to s. rampart range... tore up some dirt roads and trails!!
I cleaned out all the foam lint from fuel filters and the car ran great the whole trip.. v8 has tons of power!! the northstar motor just purrred .. the car handles great! I love the mid engine!!!! shocks seemed perfect... on the stiff side!! no problems at all!! the car was sooo much fun!! i really couldnt be happier with the build... it so awsome to finally get to ralley it after all the hard work, research, sweat, blood and tears i put into this car !!
no heat in cockpit from motor.. and everything was very quite and smooth... a little work to turn.. but the v8 will turn it quick!!
Heres my build:
JabaDubRider Samba Member
Joined: June 02, 2012 Posts: 341 Location: Highland Mi
Posted: Mon May 27, 2013 5:43 pm Post subject: |
Wierdly enough right before you posted in your build thread I thought of you and your build. I came across a new car coating. I know you said that your weren't going to tear it apart and do any refinishing till this winter but you might be able to get some color on that thing for the summer because the best thing about this stuff is it is temporary. When you are tired of the color you just peel it off, and you don't have to tear the thing apart. It is getting a lot of good reviews. I think your baja would look sick with a flat Black coating on it. Give it a go. It seems relatively cheap for enough to do the whole car. Give it a look, It is called Plasti Dip.
https://www.dipyourcar.com _________________ America, everybody is in too big a rush. Lay back, take a sip of tea, mow a little grass. Then if you get tired, take a nap.
http://www.thesamba.com/vw/forum/viewtopic.php?t=536093 |
Posted: Tue May 28, 2013 12:44 pm Post subject: |
Great to here about the drive. How about some action shots, or should we just call it a trailer queen??? Just a hard time there. Most of the photos of my car are taken by me, so not many action shots here.
Island Bumpkin Samba Member
Joined: April 22, 2013 Posts: 332 Location: Whidbey Island, Washington
Posted: Wed May 29, 2013 10:41 am Post subject: |
This sir, is an incredible build. I'd love to see some pictures and videos of this thing in action. Hell, even just videos driving down the road would be sweet. _________________ Vehicles:
1971 Baja Bug, 1600dp, summer/winter/summer project
Follow my progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=556996
1988 F250 SC/LB 7.3 IDI/ZF5/Dana 50 front, Sterling 10.25 rear. 4" lift -Daily-
1976 F250 Reg cab/LB Stock 300/NP435/NP205 -Long Term Project-
Axitech wrote: |
My rail is basically my "I can't take civilized life anymore this month, so I'm going camping" vehicle |
Posted: Mon Jun 03, 2013 12:46 pm Post subject: |
Looks good and sounds good.
Posted: Sat Jun 08, 2013 7:06 pm Post subject: |
had to show the new addons....
finished pull back top .. made some slider bars for the top... bent them around my air compressor tank to get the arc to match the top of the beetle..
welded tabs for slider.. measured out had local boat cover shop sew me new vinyl.. i then pulled it tight.. pinned the corners... and installed all the buttons!! came out real nice under 100 dollars total!
also added some soft belt pads!!
Heres my build:
stever70 Samba Member
Joined: October 30, 2009 Posts: 302 Location: california
Posted: Tue Jun 25, 2013 8:06 am Post subject: |
posting some pics of my fathersday trip to walden dunes co..
first day was awsome.. car did great ..except for me trying to roll it off the dunes.. some bad ass jeeps from wyoming pulled me out.. I need paddles bad!!
i got one tire over the lip back side of dune just sucked me in!!!
hit some jumps .. tons of fun!
then on sunday!!!
trailing arm gave out at hiem joint..shreaded metal not weld... need to gusset inside like i did outside arm!! broke shock.. did some other damage to fender and body...
endobear helped me get my trailer to the dunes got car loaded.. blew trailer tire getting car out of dunes.... i had no spare so i headed to wyoming to get a trailertire ... walmart couldnt mount ..tire machine broke... head back to dunes to mount with spoons..van breakes down..... fixed with some black tape and crazy glue in a wind rain storm!!(rotor failed)... thanks endobear for mounting my tire while i got the van back together and loaded up.. ended up being a lonnng day...but tons of fun... now time to fix all the damage!!! _________________ GRIP IT AND RIP IT!!!
Heres my build:
Last edited by northstarbeetle on Tue Jun 25, 2013 8:20 am; edited 1 time in total |
Posted: Tue Jun 25, 2013 10:33 am Post subject: |
Glad to hear that you had a great time
Sorry to hear that you had so many problems at the end
But at least I know that you have the skills to make it even better than before. _________________ my build log
http://offroadvwbus.blogspot.com/ |
Posted: Tue Jul 09, 2013 9:00 pm Post subject: |
i fixed arms ..i also did 3 extra support tubes tieing the two arms together around shock mount ..tubed the bungs together and gusset top and bottom of inside bungs like outside arm.. these things should hold up to some jumping now!!! beefy!!
im also gonna gusset the front arms around the lower hiem bung and shock mount... just for extra support!
old arm
new arms
Heres my build:
