The Phil Samba Member
Posted: Tue Jul 09, 2013 9:50 pm Post subject: |
What a bad ass car!
Now I have a question for your Northstar.
Why dont you box in your arms? I wouldn't think it would add much weight, especially if your arms are aluminum? even if they are steel, 1/16" plate shouldn't be tremendous especially considering the engine pushing this beast.
Unless you want the arms to be the weak point? _________________ "In case I don't see you, good afternoon , good evening, and goodnight."
My '66 Baja Build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=456365
Free from the evils of facebook Dec 2012. No other Social Media. |
bajamike560 Samba Member
Joined: December 11, 2009 Posts: 544 Location: Vancouver WA
Posted: Wed Jul 10, 2013 1:12 pm Post subject: |
Version II looks good.
Hope you were not hindered by the fires recently.
Keep us the great progress.
Mike _________________ Jackpot motorsports |
northstarbeetle Samba Member
Joined: February 06, 2009 Posts: 160 Location: golden co
Posted: Sat Aug 03, 2013 7:07 am Post subject: |
thought id update a few videos...
car has been running great tons of fun!!!
i did cut the last trip short ..
had a fuel pump relay fail, kept blowing ecu fuces..
im gonna attemp to ruber mount relays and ecu..
has anyone ever had relays fail.. do they make high vibration relays? the one that failed was a hella... u would think it was ment for offroad..
if your want to check out my new videos you can now see them on youtube by searching northstarbeetle one word!
http://www.youtube.com/watch?v=8c3Dd3Tb-B0 _________________ GRIP IT AND RIP IT!!!
Heres my build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=344748&sid=43494cd783cdc3787d870e8b8aba65d6 |
Posted: Mon Aug 05, 2013 1:35 pm Post subject: |
Great video. Next run can you mount the camera to view the suspension working? That would be great to see also.
Posted: Sat Aug 24, 2013 2:25 pm Post subject: |
headed to the dunes next week... ill give that a try mike.. not sure where i can mount it..
thought id show a few pictures of the push bar i build this week..I add 2 ,24" 120w led lights to help light up the dunes..
it all pulls out of reciever hitch with one bolt and wire clip.. for easy removal..
i installed HID headlights and i also made a led whip for 15$
Heres my build:
Hondub Samba Member
Joined: March 27, 2012 Posts: 57 Location: United States
Posted: Sun Jan 12, 2014 9:53 pm Post subject: |
I had a little trouble at the last dunes trip broke a few more parts... so I decieded im gonna rebuild rear arms totally.. upgrade to 1 1/4 heim with uniball.. go to center mount gear one hub.. and set up for bypass shock..
sooo... im collecting parts again...... saving money... car is parked..
I did plan on hooking up supercharger this winter... I wanted to upgrade heads and studs before I did... but now I think I might just get the bigger injectors, reprogram computer, and go for it...
hopefully get started on arms in the next few months... ill post some pics.. _________________ GRIP IT AND RIP IT!!!
Heres my build:
Stingray250 Samba Member
Posted: Mon Jan 13, 2014 3:31 pm Post subject: |
This what happens when you make toooo muchhhh powaaaaa!!!!
Cleaned off second on the mainshaft... back out to Kevin @ KCR for a ERCO mainshaft and hardened gears.... mainshaft is 1000.00 all by itself!
This happened while coming off a normal 1st to 2nd shift then on the boost around 3000rpms... let go @ 5800rpms... made a noise I won't soon forget... my wallet is still cryin!
dexter69 Samba Member
Joined: August 30, 2013 Posts: 61 Location: spring branch tx
Posted: Mon Jan 13, 2014 7:59 pm Post subject: Caddy |
Your the man..........................Dozer is kick-ass too! |
dredward Samba Member
Posted: Fri Jan 17, 2014 8:01 pm Post subject: awsome build! |
This is bar none the best build I've ever seen on the samba!!!!!!!!!!!!!!!!!!!!!!!!!! _________________ Cars owned: 1979/89 scirraco, 1983 gti, 1984 gti, 1986 gti, 1990 gli, 1989 cabriolet(2.0,16v conversion), 1992 gti, 1982 Westy, 1987 syncro Westy(w/ 1.8t conversion stg1 chip), and finally 2004 r32.... |
Posted: Fri Jan 17, 2014 8:05 pm Post subject: |
Yeah... pretty jacked up... running a 002 five rib... super diff 4:57... I'm pretty sure the engine torque ate the main shaft... that lil turbo Ecotec of mine spools super quick makes torque on demand. Calculated 17:3 comp ratio with just 7psi of boost. I've got the gear stack back out to KCR for a hardened ERCO main shaft and Weddle gears. Should hold together. |
ravewolf Samba Member
Joined: January 19, 2014 Posts: 10 Location: Raton,NM
Posted: Tue Jan 21, 2014 5:12 am Post subject: |
Holy crap man. I swear this website is gonna be the death of me. I've read five builds in the last week or so...and wow. But yours...my friend. It takes the cake.
I'm scheming now. I wonder how a 915 would hold up to a Dodge BB400? Probably not well...but...my gears are turning. |
spize909 Samba Member
Joined: February 26, 2010 Posts: 349 Location: Upland CA
Posted: Tue Jan 21, 2014 9:47 pm Post subject: |
Stingray250 wrote: |
Not meaning to hijack but what is the turbo set-up that you are ruuning on your ecotec that spools quick and doesn't lose low-end torque?
I been hearing the way to go for the dunes (that's where my car goes) is supercharger. Turbo has too much lag...... |
Posted: Wed Jan 22, 2014 7:31 pm Post subject: |
Well for starters... I would not recommend adding a Turbo to an internally unmodified/stock Ecotec. The pistons and rods will eventually vaporize and shatter with anything over 5psi of boost. If you plan to turbo your Ecotec... at the minimum... you'll have to have forged pistons, and "H" beam rods... a good set of injectors too... I'd recommend a set out of a Ford GT500... think they are rated @ 42psi at 45 pounds of fuel pressure up from the 26psi factory set... direct bolt on... you'll have to have a tune done also... I'd recommend a "street" tune over a dyno tune... better overall drivability.
My build utilizes Wiseco 10:1 forged pistons, Eagle "H" beam rods, forged crank, APR studs, Cometic head set, stock head, stainless valves, mild porting, stock cams, stock chains, stock block, high pressure springs, high volume fuel pump (255lpm) high volume oil pump, factory GM rod and main bearings...
The turbo actually came off of a old Volvo... Bought a factory Mitsu rebuild kit for 80.00 bucks and had it high speed balanced by 3rd Coast Turbo.
http://www.ebay.com/itm/94-95-96-97-Volvo-850-R-V7...mp;vxp=mtr
I fabbed the "log" style turbo manifold myself... With the factory 10:1 comp ratio and 7 to 9 psi my calculations bring the total comp ratio to around 17.3:1 or there abouts under boost... The TDO4 has literally no lag what so ever... and being that the motor is 10:1 comp off boost, you have pretty good power at cruise anyway.
Most people drop the comp to 8.5:1 when adding the turbo... this creates the lag because of the lower com ratio and lower hp at cruise... it takes the turbo a few seconds to catch up on these motors. My setup is for torque and man does it grunt... think the mainshaft speaks for itself.
Stock internals on the boost!!!!
Posted: Wed Jan 22, 2014 7:47 pm Post subject: |
Sry for getting all up in yer thread Northstar... |
Posted: Sat Jan 25, 2014 7:50 am Post subject: |
very nice stingray. I can't throw that kind of money into my engine...I've priced these ecotec parts and they ain't cheap.....although if I have to do a tear down it'll have to go back together right. I've heard running 5-6 lbs boost on the stock engines is fine but the lag would kill me with the kind of driving I do. I'm mostly with quads, not other cars so our duning isn't real fast.
and yeah, sorry for the treadjack.
That is a very nice "baja bug". |
Posted: Wed Feb 05, 2014 10:59 pm Post subject: |
I can't get enough of this one! _________________ Cars owned: 1979/89 scirraco, 1983 gti, 1984 gti, 1986 gti, 1990 gli, 1989 cabriolet(2.0,16v conversion), 1992 gti, 1982 Westy, 1987 syncro Westy(w/ 1.8t conversion stg1 chip), and finally 2004 r32.... |
Posted: Mon Feb 24, 2014 1:04 pm Post subject: |
that's some damaged goods...
speaking of... I ripped a trailing arm last year breaking inner heim joint.. snapping heim this year not arm..
was gonna totally rebuild rear arms.. but with lack of money this year to do the ugrades I wanted... mid hub, bypass shock and total arm rebuild with uniball ect...
ive decided to do a quick fix on old arm.. again...
im going to reinforce the pivot brackets.. use 3/4 bolt instead of 5/8..
weld tube with derlin bushings on inner pivot instead of heim joint..
then im upgrading outer heim to stronger aurora heims .. the old ones were ballistic heims made by Midwest control products..??
looking at 600 total rather than 4 to 5000... to get back on the road
I just don't have the cash and want to use the car this year!! ordered all the parts.. ill post some pics on upgrade.. hopefully It will hold up... gotta be better!! _________________ GRIP IT AND RIP IT!!!
Heres my build:
Glamis Addict Samba Member
Joined: March 21, 2010 Posts: 99 Location: Riverside,Ca.
Posted: Thu Mar 06, 2014 7:16 pm Post subject: |
Hondub wrote: |
What ever happened with the supercharger? |
+1
North Star lets see something!
I talked to Endo last night,no trip to the big G this spring?Bummer:( _________________ AKA RDP's Gelcoater |
