Louis Samba Member
Joined: September 26, 2007 Posts: 416 Location: canada BC
Posted: Sun Mar 01, 2009 4:11 pm Post subject: anyone used clear coat on the engine block? |
just polished my 36hp.looking for a hard , heat resistant clear coating so the magnesium doesnt oxidize.
cheers!! |
Mr. Okrasa  Samba Member
Joined: May 20, 2000 Posts: 304 Location: Newport Heights, Califa.
Posted: Wed Mar 04, 2009 6:53 pm Post subject: DANGER!!! DONT DO IT!!!! |
Polishing a 36hp block will not only make it run hotter, "sealing" the magnesiums "pours" by applying heat resistant paint will only compond the problem even more!!! Why would anybody want to do that UNLESS you can afford to buy a rebuilt 36hp longblock every time you "FRY" your engine......?
I found the best way to dissipate heat from a VW aircooled block is to propler clean the magnesiums surface and then treating it with a chemical treatment as I do below:
http://www.thesamba.com/vw/classifieds/detail.php?id=587241
If you have any other questions/comments, please send me an email at: [email protected]
Hopes this helps..... Cheers! Mr. Okrasa  _________________ 1950 Split Window 356 Coupe / #5369 / Adria Blue Metallic
1951 Split Window 356 Coupe / #10572 / Radium Green Metallic
1952 Split Window 356 Cabriolet / #10188 / Azure Blue
1959 Enzmann Spyder 506 #28
VW www.Okrasa.com
356 www.PreA356.com |
