How to chop your Beetle by Clark Customs
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8
Glenn73
Glenn73 is offline
PostPosted: Sat Mar 31, 2012 3:53 pm    Post subject: Reply with quote
Where or who supplies or cuts glass for this application?
1973 SB 1776cc
Sat from 93-2008
Work in progress.
kermatt
kermatt is offline
PostPosted: Thu Apr 19, 2012 1:46 am    Post subject: Reply with quote
If I want to take a section out of the rear window, where would you cut it?
kermatt
kermatt is offline
PostPosted: Thu Apr 19, 2012 1:49 am    Post subject: Reply with quote
Glenn, we have a place inn Denver called Sviegals(sp) that will cut glass. Just a fyi, cutting glass isn't an exact science....not every one makes it
kermatt
kermatt is offline
PostPosted: Thu Apr 19, 2012 2:01 am    Post subject: Reply with quote
eurodub
eurodub is offline
PostPosted: Wed May 16, 2012 2:44 am    Post subject: Reply with quote
although not 100% top chop related, i have some questions
i will have to repair a badly damaged bug which has the A pillars near the windshield gone. i should cut them and also replace the roof entirely at the corner of the door.
now... to weld the A pillars near the defroster vents in the dash, how should i approach this? is an outside weld enough? how far does the reinforcement that holds the hinges go upwards in the A pillar next to the windshield?
i think i must leave some space open to weld in the reinforcement first, then cover it off with the outside skin?
Thanks !
June 1952 split
March 1960 euro bus
OriginalZ
OriginalZ is offline
PostPosted: Wed Jun 27, 2012 10:39 am    Post subject: chop a top Reply with quote
Ok, total newb here so go easy.
I have a 68 baja, runs but needs lots of cosmetic work ect.
I have a lead on a 72 roof that is a sun roof. Could this be used? If so would it be lame to put it on a baja?
Joe
BugMan114
BugMan114 is offline
PostPosted: Fri Jun 29, 2012 1:51 pm    Post subject: Reply with quote
It's only as lame as you make it out to be. Your gonnna get both extremes of answers here, from the guy who has radical customs telling u to go for it, to the purists who say it's stupid, and your ruining the car. If you like it then, go for it. It's your car, build it how you want it, not how a crowd of keyboard commando's want.
Tho personally I say go for it Laughing
1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!!
OriginalZ
PostPosted: Fri Jun 29, 2012 3:00 pm    Post subject: Reply with quote
I concur sir. I feel as though the author of this original post has abandoned us. I have many questions that need answering before I can proceed. Will a 72 with the sun roof work. I have also found a 73 hard with a flat Front windshield, will these work on a 68?
BugMan114
PostPosted: Fri Jun 29, 2012 4:33 pm    Post subject: Reply with quote
Theres no reason it wouldn't work. Tho if I were to guess it would prolly be easier to cut the sunroof portion out and graft it in later, as you have to cut the existing roof in several pieces and use the second or even third roofs to fill in the gaps. Once you get the roof chop done, and all welded up you can then cut the hole in the roof and graft the sunroof in. I hope your a good welder, and have a lot of free time. Cool
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
jipple28
jipple28 is offline
PostPosted: Tue Jul 03, 2012 2:18 pm    Post subject: Reply with quote
Question
Inside the front of the ragtop clip there are 3 supports; one in each corner and one in the center.
What did you do with these? Cut them off the clip entirely and add your own later? I assume they are required or at least highly recommended. The center doesn't concern me too much, I just don't want to ruin the corner supports if they can be used again. From this photo it looks like you left the center support on the ragtop clip, just not the corners
I'm at this point with my ragtop donor; lines are traced and ready to be cut.
-JPL
Clark Kustoms
Clark Kustoms is offline
PostPosted: Tue Jul 03, 2012 10:37 pm    Post subject: Reply with quote
I just tacked the corners of this center piece. You could weld it better before you did the outer filler piece, but the factory welds are very weak probably a little over kill. They probably thought ''what if some one sat there?''.
http://www.chrisclarkcustoms.com/t-shirts__posters
http://trailerparklimo.blogspot.com/
chop your volksrod
http://www.thesamba.com/vw/forum/viewtopic.php?t=345410
Split 1
Split 1 is offline
PostPosted: Tue Dec 18, 2012 4:23 am    Post subject: Reply with quote
Clark Kustoms wrote:
I charge $2500.
I wish you were in Australia I would let you loose on mine
renatofuzz
renatofuzz is offline
PostPosted: Thu Jan 31, 2013 4:59 pm    Post subject: the best step by step ever! Reply with quote
Thanks for the great help. I am about to start my first project on a tiny budget. The bug is going to be a course for me. I wish I could have it convertible but it is very hard to have the papers approved here in Brazil.
So I want to have a lower roof and cut it in a cabriolet style. From above the driver up to the motor. Has anyone here gone this far? I ve never found picts like these.
Just in time: Thanks for the great tutorial. Thanks for sharing!!!!
16CV's Premium Member
16CV's is offline
PostPosted: Thu Jan 31, 2013 10:52 pm    Post subject: Reply with quote
Loved this thread ! ! ! . My son has a 64 that was chopped when we bought it . I wish whoever did it had seen this or a similar photo journal ,under the Bondo it was Fugly . We did a very similar thing done here ,we added a sunroof and a Oval rear clip . The issue we had with the clip was that now it was laid down further forward and there was a gap at the back center and tight at the end between the deck lid and the body . We ended up having to cut the body below the grills and extending it out to close the gap . Once done you still have to have your hand on the top of the deck lid when opening it up so it does not chip the paint .
On to the glass question . The person who said that you could sand blast the glass was right that works for the most most part ,but will send fractures into the needed part most times . It is a crude way to do it but it works and quickly at that . But remember that you can only do it to Laminated glass (windshields ) it WILL not work on Tempered glass (side ,door,rear glass ) . This why it is a good idea to law a factory window back in a cut section complete or you end having to use plastic (ugly) .
Having the glass made is a straight forward project really . Once the car is chopped ,make a template of the inside of the Pinchweld flange . This what we call the Daylight opening . So your pattern should fit tightly through the opening ,this is the exact size of your glass to be cut . Once you shorten the rubber the glass should just rope right in . Before you chop a VW or if you the glass out compare the glass to the opening size and they should have the same relationship before and after . I like to put Tempered back in the doors especially if going with one piece windows ,it takes a lot more beating than laminated .
I have made custom glass for a lot of cars ,these jobs are always Time And materials as they take a lot of both . One other side note only 64 and down cars have FLAT glass ,65 and the front glass is semi curved . While it can be cut from a stock window you usually lose 2 or 3 until you get one cut ,again I do this at owners expense .
Stacy
89 Syncro Tristar "Swedish"
www.vanagonsplus.com
Detroit73super
Detroit73super is offline
PostPosted: Fri Feb 01, 2013 1:11 pm    Post subject: Reply with quote
Make a fiberglass template of the stock windshied and then trim as necessary while chopping the top to make sure the geometry isn't off. Especially for a curved fat girl windshield Wink
Choptop 73 Super Build Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=395375
Slammed69vw
Slammed69vw is offline
PostPosted: Thu May 02, 2013 10:35 pm    Post subject: Nor Cal Choppers Reply with quote
Who can chop a roof in nor cal? and can it be done for 1k?
Nytstalker
Nytstalker is offline
PostPosted: Yesterday 6:56 pm    Post subject: Reply with quote
im doing it rightnow to some ovals, im in antioch about 30 mins from you
(O\_!_/O)
Page 8 of 8
