Rev. Scott Samba Member
Joined: June 04, 2006 Posts: 770 Location: Philo, Ca.
rebapuck Samba Member
Joined: May 17, 2007 Posts: 1023 Location: Chapel Hill NC
Posted: Sun Feb 16, 2014 11:50 am Post subject: |
Miss VDUB, please show us pix of the interior. _________________ Judy
1966 Camper "Hannah"
1967 SingleCab "Khady" |
holg Samba Member
Joined: May 05, 2009 Posts: 34 Location: Dortmund, Germany
angelface01 Samba Member
Joined: January 25, 2004 Posts: 8 Location: Pottstown, Pennsylvania
Posted: Sun Feb 23, 2014 11:53 am Post subject: Childs Cot |
So I know it has been discussed a couple of times on this forum but looking back, none of the links to pictures work. Does anyone have a picture(s) of the rare and elusive childs cot? Mounting points, location and material info would be great, I can fabricate one if I had at least a picture or two to work from.
THANKS! _________________ Super Sean |
Posted: Sun Feb 23, 2014 9:31 pm Post subject: |
Here's the one in my old '75.
The wooden horizontal piece is held up by two metal pieces that look like shelf standards. Attached to the inner steel frame at the beltline, I guess. Each end of the wood is cut to accept the cot frame. One side is a u-channel. The other end is more of a square notch cut out.
I never could figure out where to store the aluminum poles inside the Puck. One was just a tiny bit too long. Figured that one day, I would cut the longer pole to match the shorter and it would just fit under the rear cushion. Then the forward most notch would have to be doubled up in thickness to compensate. _________________ Judy
Posted: Mon Feb 24, 2014 3:39 am Post subject: |
Thanks so much, those pictures are great and help out A lot. I have the optional rear bumper compartment, I could probably store the cot in there. _________________ Super Sean |
rbound Samba Member
Joined: May 18, 2006 Posts: 6 Location: Los Angeles, CA
Posted: Fri Feb 28, 2014 6:26 pm Post subject: Sliding trailer windows option in Eriba Puck |
I am restoring a 1971 Eriba Puck, it came with one shattered glass and bad seals. I found replacement sliding trailer windows that could be custom made by www.motionwindows.com quoted at $250 per window. They have an option of aluminum frame. Has anyone installed this type? Any feedback or opinions are greatly appreciated. Ross. |
wythac Samba Member
Posted: Sun Mar 02, 2014 7:17 pm Post subject: |
A big thanks to our departed friend Dave Shove from the UK. I got this canvas kit from him a few years back and finally got around to installing it. A bit of a PITA but it went OK.
I had a helluva time getting the canvas to wrap the frame, until I used some of the metal screws that hold the frame to the fiberglass top to "stake" the fabric to the frame near the "T" ends of the frame. then worked my way around with spray glue. Applied some heat to set the glue and then installed the top. I also installed a Westy poptop seal. I was never crazy about seeing the poptop sit on the fiberglass roof. Anyway, it all turned out well, and I have Dave to thank for that. |
folks55 Samba Member
Joined: August 30, 2008 Posts: 894 Location: High Desert Ca
Posted: Sun Mar 09, 2014 9:32 pm Post subject: |
That's a great idea with the Westy seal. |
wythac Samba Member
Posted: Mon Mar 10, 2014 11:30 am Post subject: |
I've tested it with a hose but haven't driven it in a rainstorm yet. Looks like it seals well. Regardless, it is better than no seal at all, but I did have to use a rubber mallet to drive the attachment lip on as far as it would go to allow the latches to engage inside. |
61Falcon Samba Member
Posted: Thu Mar 20, 2014 9:43 am Post subject: Puck Beer Cooler |
Here is my vw that I pull my Puck with. I also tow it with a Subaru and 64 Chevy Impala. And a handmade beer cooler to tow behind my ve bus wagon.
xavi_242 Samba Member
Joined: May 06, 2005 Posts: 1672 Location: Barcelona (SPAIN)
Posted: Mon Mar 24, 2014 9:29 am Post subject: |
cool!!^^^ _________________ 1967 Split SO-42 Dormobile |
Bob M Samba Member
Joined: September 06, 2013 Posts: 10 Location: Knoxville, Tennessee
Posted: Tue Apr 01, 2014 7:46 pm Post subject: Red Trim Strips ?? |
I have a 1968 Puck and am ready to replace the red trim strips that go around the top, middle, and bottom. Does anyone know where I can get these? I have gone to the Alt-Eriba web site, but it was all in German and I had no idea where to start. Are there any sources in the U.S.? Or U.K.? Any help will be greatly appreciated.
Bob _________________ 1968 Eriba Puck |
wythac Samba Member
Posted: Sat Apr 05, 2014 8:47 am Post subject: |
I know it is a chore, but start reading backwards from this page of the thread, and I believe you will find that someone has posted information on where to get that red trim stuff (or something so close to it you can't tell the difference).
Welcome to the tiny trailer club. |
Bob M Samba Member
Posted: Sat Apr 05, 2014 7:00 pm Post subject: Red strips |
Thanks for all the suggestions I've been sent. I was put in touch with trollpuck and he's been able to supply me with everything I need.
Posted: Sun Apr 06, 2014 12:26 am Post subject: |
Trollpuck is the right connection for all that good Puck stuff. Good luck on your rebuild and repair Bob. Post pictures please. |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Fri Apr 11, 2014 2:21 am Post subject: |
This Puck is about 3 miles from my place, I'm trying to track the owner down. _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
Posted: Sat Apr 12, 2014 7:38 pm Post subject: |
Nice find, looks early too |
crukab Samba Chef
Posted: Mon Apr 14, 2014 7:22 pm Post subject: |
Lol |
