69Ghia-pet Samba Member
Joined: February 23, 2009 Posts: 187 Location: Dallas
Posted: Tue Mar 10, 2009 12:49 pm Post subject: 4" speedometer gauge for a 69 ghia |
I have been hunting for an aftermarket speedometer gauge for a 69 ghia. All I can seem to find is 3 3/8" or 3 3/4". Does anyone know who make them? I think it would look really silly if I have all aftermarket gauges and the old speedometer. I have called Egauges and got no where. Thanks for the help.
Matt [/url] |
dink911 Samba Member
Joined: September 25, 2008 Posts: 110 Location: Dallas, Tx
Posted: Tue Mar 10, 2009 12:54 pm Post subject: gauge size |
you need to find one that is 4 1/4 and if you do post it because I cant find one either. I assume its a ghia only size for the 68-71 years _________________ **********************************
Steven G.
71 Ghia
"When a defining moment comes along, you define the moment... or the moment defines you."
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Tue Mar 10, 2009 1:19 pm Post subject: |
Thanks sactojesse. That excatly what I am looking for. I will start looking for Porsche gauges. Any good retails you know of? Did you put them in your ghia? |
CLKWRK Samba Member
Joined: October 02, 2001 Posts: 566 Location: Toronto
Posted: Tue Mar 10, 2009 1:22 pm Post subject: |
914 speedo diddnt fit my 71, too small
I ended up painting up my stock speedo to match, looked alright
Posted: Tue Mar 10, 2009 1:30 pm Post subject: |
Was it a bitch to take apart? But it looks great! |
Posted: Tue Mar 10, 2009 7:33 pm Post subject: |
Here is a shot of what I did, but I would still like them to match some aftermarket oil temp, oil pressure, and volt gauges
Steven G.
71 Ghia
CLKWRK Samba Member
Posted: Wed Mar 11, 2009 8:32 am Post subject: |
it takes a bit of patience to pry off the chrome ring, and make sure you replace the needle i nthe exact same spot when you reassemble, or it will throw off your calibration.
btw type 3 speedo is the right diameter, you just need to grind off the mount tabs in the back because they mount differently. |
Posted: Fri Apr 03, 2009 11:12 am Post subject: |
CLKWRK- what kind of cd player is that? I am looking for a CD player that will not require any dash modifications. |
CLKWRK Samba Member
Posted: Fri Apr 03, 2009 11:47 am Post subject: |
that is a sony xplod deck, i does not fit in the original hole , I had to mount it from the back with a fancy bracket I made.
I am not using it anymore as I did cut my dash for my 911 gages |
Rainman Samba Member
Posted: Mon Oct 14, 2019 8:10 am Post subject: Re: 4" speedometer gauge for a 69 ghia |
Will a 66 bug speedo fit a 69 Ghia? As far as hole size? I realize the obvious other differences but would it actually fit ? |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8206 Location: San Dimas
