Low mount dual zoom exhaust
Endicott jb
Bondo King
Endicott jb is offline
PostPosted: Sun Mar 15, 2009 5:11 pm    Post subject: Low mount dual zoom exhaust Reply with quote
Does anyone have any info on this exhaust? I like the idea and was thinking it could work well with my car. I just don't want to put the money into something that might be garbage.
Josh
OORAH!!
1965 vw beetle(Mayble)
1968 vw beetle(Caroline)
1974 VW Panel Bus
2003 Dodge 2500 5.9 Cummins(Katey)
.|_____|.
(0\_!_/0)
Don't drink and post
http://i540.photobucket.com/albums/gg353/endicott_jb/IMG_20110113_085237.jpg
When life throws you curveballs switch to boomerangs.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Mar 15, 2009 5:14 pm    Post subject: Reply with quote
It's garbage.
A 4 into 1 header will be much better.
Glenn
Member #1009
#BlueSquare
Endicott jb
Bondo King
PostPosted: Sun Mar 15, 2009 5:16 pm    Post subject: Reply with quote
Is this one any better? I just like the look of this type of set up.
Josh
OORAH!!
1974 VW Panel Bus
.|_____|.
(0\_!_/0)
buzzboy
buzzboy is offline
PostPosted: Sun Mar 15, 2009 6:08 pm    Post subject: Reply with quote
This is a much better subject as it attaches to a 4 into 1 style header. I don't know what kind of baffle is in there if at all but I personally really like this style of exhaust and would have used that exact same one if it didn't cause me to loose the inch or two that it does. On a street car though you should have no problems.
Endicott jb
Bondo King
PostPosted: Sun Mar 15, 2009 6:25 pm    Post subject: Reply with quote
Alright cool. That's what I'll probably get.
Josh
OORAH!!
1974 VW Panel Bus
.|_____|.
(0\_!_/0)
jwb973
jwb973 is offline
PostPosted: Wed Mar 18, 2009 9:04 am    Post subject: exhaust Reply with quote
I've got a set of these. Haven't installed them yet. Think they would work good on a stock body, baja, etc. Hopt to install these on a kit car in the next week or so, if they don't fit they're for sale.
Go to waltstoys.com and you can see the car. walt 973, Atlanta area
http://my.att.net/p/s/community.dll?ep=16&groupid=339702&ck=
fastinradford
fastinradford is offline
PostPosted: Wed Mar 18, 2009 9:55 am    Post subject: Reply with quote
It would probably work great if you are the type of person who does not adjust their valves.
wbrown45
wbrown45 is offline
PostPosted: Wed Mar 18, 2009 9:57 pm    Post subject: Reply with quote
From the looks of the collector flange the mufflers should be below the valve covers. It would be tight, but you should be able to access the valves. But the ground clearance would be pretty marginal.
OK Thang
73 KAFER
73 KAFER is offline
PostPosted: Thu Mar 19, 2009 8:27 am    Post subject: Reply with quote
I had the dual set-up a few years ago, It broke right at the three bolt flange....weight of the mufflers. They were on for two years and were jet-hot coated and did not rust thru, just cracked at the flange from vibration and weight of the mufflers. In fact, I had lighter weight alluminum Super-Trapp mufflers on it at the time and still cracked in half.
Mark
1973 Beetle
#3 http://www.thesamba.com/vw/forum/album_page.php?pic_id=775620Kafer-Cup vintage road racer
nobody
nobody is offline
PostPosted: Thu Mar 19, 2009 9:10 am    Post subject: Re: Low mount dual zoom exhaust Reply with quote
I have a set on my trike; easy mount with a good sound. It has been on my trike for years now and still looks and sounds good. My 74 super has a brand name exhaust and doesn't sound near as well. Cool
When my 78 vert gets roadworthy it will have this system. I'm happy with it
vwsb74
vwsb74 is offline
PostPosted: Wed Apr 07, 2010 9:32 pm    Post subject: Reply with quote
hi, can you post some Picts of this exhaust in the car?thanks
74 super beetle
2011 ford explorer traded
2010 mazda 3 hatchback
2014 Honda odyssey
2180cc 48IDA clone
Xr310 cam =171hp@6k rpm sold so as the car😢
Broke96
Broke96 is offline
PostPosted: Thu Apr 08, 2010 1:18 am    Post subject: Reply with quote
I have a set of pipes like the ones in the first pic. They arent my style, but they came with my car, and will stay on for a while. It looked like the exhaust sat a little higher than the stock one, because the bumper mounts were cut up to fit the exhaust. They do sound great though.
1972 super beetle
2004 chrysler concorde
JasonBaker
JasonBaker is offline
PostPosted: Thu Apr 08, 2010 7:06 am    Post subject: Low mount dual zoom exhaust Reply with quote
Use exhaust straps or they will get hot, bend, drag, and fall off.
This is my second set
