my trans is acting wierd
hauss69
hauss69 is offline
PostPosted: Thu Mar 26, 2009 10:13 pm    Post subject: my trans is acting wierd Reply with quote
hi in my beetle it is a 69 stock it came with 1600 single port but when i bought it it had a 1600 daul port in it and when i start it up and take it out of gear and let off the clutch it still pushes forward slightly not a hard push but something im kinda worried about cause i have two other stick shift cars and they dont do that oh and this morning the thing that really got me worried was when i tried to start it it pushe forward like is said above and my starter was turning slow so i turned it off and you can hear something spinning still in the back. i had somethings in mind but i should probably ask.
could the flywheel be to big since it has bigger engine.
could the starter not be disengaging.
could the trans fluid be low or old.
could the the trans be going bad
Jeckler
Jeckler is offline
PostPosted: Fri Mar 27, 2009 6:43 am    Post subject: Reply with quote
If it does it in neutral, it's probably old, thick gear oil.
Andy
'63 Bug rebuild here.
Did you know that sellers can't charge a fee to accept PayPal?
bill may wrote:
I am the crabby old guy.
Knowledge is knowing that a tomato is a fruit.
Wisdom is knowing not to put it in fruit salad.
hucks 72
hucks 72 is offline
PostPosted: Fri Mar 27, 2009 7:14 am    Post subject: Reply with quote
hows your clutch adjustment ,the noise is probably the throwout bearing.
THERE IS NO REPLACEMENT FOR DISPLACEMENT
hauss69
hauss69 is offline
PostPosted: Fri Mar 27, 2009 8:58 am    Post subject: Reply with quote
the gear oil is what i thought and the clutch is real old it stuters about half way out that is on my todo list
