evanwilliams4u Samba Member
Joined: December 16, 2008 Posts: 88 Location: California
Posted: Tue Mar 24, 2009 6:53 pm Post subject: Atwood Hydroflame 8012 furnace into kitchenette (with pics) |
Well after reading about this topic for some time I finally got around to installing an Atwood Hydroflame 8012 propane furnace into the spare tire area of my Westy's kitchenette. Here are the pics with explanation for anyone else who may want to attempt the job.
Install location without the spare tire:
Furnace ready to be installed:
Furnace sitting in location, notice how the vent would hit the exterior body-panel support on the far end. I needed to raise the furnace ~2" to clear the support (I did not want to cut that away). Also, the sheet metal screws on the left had to be removed in order to get the furnace to slide further back. Otherwise it fits like a glove.
I made 2 risers out of wood, the one on the right is for the front of the furnace while the one on the left would go under the middle.
Here's the risers installed:
The rear furnace vent now clears the horizontal support. I used a marker to mark where the 2 top corners of the vent met the wall, I then drilled through to the outside. These 2 points gave me a guide, allowing me to grind the away the opening from the outside of the Bus.
A perfect fit!
Here's the vent fully installed. I pre-drilled the holes for the screws. One ended up on the seam between 2 body panels but caused no problems.
Now to prepare the gas connection. A trip to Home Depot got me a 3/8" tee and 2 flexible gas lines. The short one runs to the existing stove, the long one runs to the new furnace. All gas connections are 3/8 inch.
In the cabinet below the sink I drilled a 1" hole for the gas line to run behind the cabinet over to the spare tire (now the furnace) location.
Here are my gas and electricity connections. The gray gas line is the original Westy line that used to run directly to the stove fitting, now it's teed and runs to the stove and to the furnace (through the hole in the rear of the cabinet). I tapped into my sink's water pump wire for power. I have installed an aux battery that the sink pump already uses so no need to worry about running the main (starting) battery dead while using the furnace. I ran the power wire through the same hole as the gas.
I installed the thermostat above the furnace near the stove knobs. 2 wires run to the thermostat: 12v power and a connection to the furnace (I should have used more colors than just red but I only had red and don't plan on selling my bus so future owners will have nothing to track down). I drilled holes in the front of the kitchenette for the wires, which descend on the right--I will attach them to the top with a staple gun. I spliced into the power wire that I ran to the furnace. You can also see the yellow gas line running to the furnace in the back.
Here's a pic of the furnace completely installed and operating. I plan on making a hinged door and painting the furnace vent black to complete the install.
Since I just did most of this today I've had little experience actually using the furnace in the field, but it does work really nice in the driveway! It's very quiet--I don't actually hear the fan, just the sound of wind coming from the front. The clearance requirements in the installation manual say 0" all the way around and the casing does stay cool to the touch, so using the space above for storage should be fine.
For a more experienced review see this thread (which gave me lots of courage--thanks 50rocket88!):
http://www.thesamba.com/vw/forum/viewtopic.php?t=344182
I bought the furnace off eBay for $330 including taxes and shipping. It's new and under 2 year warranty from the manufacturer. The thermostat was $22 from a local RV shop and the parts from Home Depot were about $35. So it cost about $400 total. Installation was not difficult but it was time consuming. Lots of tight spaces and measuring everything twice--especially the exterior cut. It probably took me around 8 hours to get this far, including the time I spent thinking things over.
I'll post pics of the completely finished product (with the door etc.) when I finish it up. I hope this helps someone with their install.
Cheers. _________________ 1978 Stock Westfalia Deluxe |
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8544 Location: Las Vegas
Posted: Tue Mar 24, 2009 6:58 pm Post subject: |
Heat! Just in time for Spring!!
Just kidding...nice job. _________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
50rocket88 Samba Member
Posted: Tue Mar 24, 2009 7:10 pm Post subject: |
Nice... I installed the same furnace in my 71'. Just to let you know.. I've been using it everyday for about 1/2 hour drive going on 2 months... and I'm still on my original tank of propane. (stock westy tank 2.4 gallons) Also it'll smell a little funny for a few days, but that goes away. I also realized that I needed to paint the exposed bare metal surfaces that were left from cutting out the exterior vent... or else they would rust very soon. I just used some etch primer and some standard primer then rustoleum spray paint. Nice job!!!! You'll love the heater, and you can't beat the price... vs. that Propex system! |
Posted: Tue Mar 24, 2009 7:19 pm Post subject: |
EZ Gruv wrote: |
Just kidding...nice job. |
Tell me about it... nothing like sweating a bunch... while installing a furnace!
But it will come in handy for high-mountain camping or over on the damp coast. The wife loves it too! _________________ 1978 Stock Westfalia Deluxe |
regis101 Samba Member
Joined: July 28, 2005 Posts: 2078 Location: Livermore, Ca
Posted: Tue Mar 24, 2009 7:49 pm Post subject: |
So it can be used while driving. That's good. How's the noise level? _________________ Peace, Regis |
blue72beetle Samba Member
Joined: April 23, 2008 Posts: 846 Location: Fort Wayne, IN
Posted: Tue Mar 24, 2009 8:09 pm Post subject: |
Small sacrifice for the greater gain. The later Westy's already have two cut outs on that side. One more isn't bad. Just my opinion.
Good question, though. _________________ Peace, Regis
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Tue Mar 24, 2009 8:10 pm Post subject: |
No, but there are already holes in the side of the van from Westfalia Hacking into it. |
Posted: Tue Mar 24, 2009 8:18 pm Post subject: |
I'm looking at the pictures. The collar that you install from the outside, does that slide into the unit to set the depth? Does the heat come through the grille from the center ~6 x ~6 square opening, basically in the center? The rest would be return? The burner intake and exhaust is from/to the outside? _________________ Peace, Regis |
TRN9 Samba Member
Joined: September 29, 2006 Posts: 308 Location: Where its rainy
Posted: Tue Mar 24, 2009 8:57 pm Post subject: |
How long will your AUX. Batt. run the fan? _________________ '72 Panel ~ B-Bus
Camper Special Club Member
Posted: Tue Mar 24, 2009 9:41 pm Post subject: |
regis101 wrote: |
I'm looking at the pictures. The collar that you install from the outside, does that slide into the unit to set the depth? Does the heat come through the grille from the center ~6 x ~6 square opening, basically in the center? The rest would be return? The burner intake and exhaust is from/to the outside? |
The collar is about 6" deep and can slide about 4" into the furnace before it hits a stop. You are correct on all your other observations.
TRN9:
The furnace draws 1.8 amps, my aux batt is a deep cycle rated at 85 amp hours, so I figure the furnace could run for about 40 hours before the battery is totally dead. _________________ 1978 Stock Westfalia Deluxe |
theizzardking Samba Member
Posted: Wed Mar 25, 2009 10:07 am Post subject: |
hey great looking install, i was just looking at buying this, was there a reason you didn't go with the smaller units atwood offers?
https://americanrvcompany.3dcartstores.com/Atwood_c_184.html
as well as a company called suburban looks to have some nice units. i'd just like to know why you chose this one as it's a bit bigger and awkward than some of the other units that are only like $40-50 bucks more....
really good write up finally somethign that looks like a good replacement for my bungee corded heater buddy. _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
'71 westie "the wanderer" |
Posted: Wed Mar 25, 2009 1:24 pm Post subject: |
theizzardking wrote: |
as well as a company called suburban looks to have some nice units. i'd just like to know why you chose this one as it's a bit bigger and awkward than some of the other units that are only like $40-50 bucks more.... |
If you're referring to the ones with the white panel, I think they are actually for full sized RVs. The white panel is a door that is supposed to be outside the RV for install/maintenance access and there is no metal vent for the interior; you'd have to use ducts. I chose the Atwood 8012 because of its very low amp draw (1.8 amps) and good BTU output. _________________ 1978 Stock Westfalia Deluxe |
White99z Samba Member
Joined: August 17, 2008 Posts: 735 Location: Bus hunting in the USA!!!
Posted: Wed Mar 25, 2009 8:14 pm Post subject: |
evanwilliams4u wrote: |
If you're referring to the ones with the white panel, I think they are actually for full sized RVs. The white panel is a door that is supposed to be outside the RV for install/maintenance access and there is no metal vent for the interior; you'd have to use ducts. I chose the Atwood 8012 because of its very low amp draw (1.8 amps) and good BTU output. |
I just might have to get one of these!!! |
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Wed Mar 25, 2009 8:27 pm Post subject: |
thats nice..
im sure you'll let us know how it works on the next cold night |
Posted: Wed Mar 25, 2009 11:13 pm Post subject: |
norcalvw wrote: |
thats nice..
I hope to go camping this upcoming week and will certainly post back as to how well the furnace works. After testing it in the driveway I have no doubt that it will work great with the top down--it appears to be capable of maintaining 90F in most any outside temp. I'm more curious to see how well it works with the top up and with the heat loss through the canvas.
I'm currently finishing up the installation and will post pictures of the completed project (mostly cabinetry) when done. If there are any other questions about the furnace just ask. _________________ 1978 Stock Westfalia Deluxe |
Posted: Mon Apr 06, 2009 9:40 am Post subject: |
I just got back from a week of camping along the northern California coast and had a chance to use the furnace, so here's my initial report. The furnace works well while driving, even at high speeds and with strong crosswinds. While camping it will keep the bus very warm (like up in the 90s F if you want); it will be super warm with the pop-top down and warm but drafty with the top up. It will hold a steady range within about 5 degrees before turning on and off, which is not the best but my thermostat is located directly above the furnace and may adversely influence its cycles--I've adjusted the anticipator to its lowest setting as well.
I did have some technical troubles with the furnace that required an RV repair man to come out to the campground, that was a major bummer after doing so much work to get a new furnace installed. I thought the control board was faulty but it turns out that the "sail switch" was sticking. He just sprayed some WD-40 on it and bent it away from the case slightly and it worked fine from then on. Atwood covers the parts/labor, but not the $45 service call fee so I would recommend doing a trial run at home and let the furnace run in a non-moving van for at least a couple hours before hitting the road for a full trip.
Also, I ran out of propane by the end of the week, but had plenty of battery power to spare. The furnace was on about 10 hours a day (though not running that whole time obviously) and it was probably in the low 40s F overnight. 2 nights I had the top up (a friend was sleeping up there) and that made the furnace run a lot more, though it heater the upper bunk well according to my friend. _________________ 1978 Stock Westfalia Deluxe |
Lionhart94010 Samba Member
Joined: January 04, 2005 Posts: 1417 Location: SF Bay Area / Silicon Valley / So Cal
Posted: Mon Apr 06, 2009 12:44 pm Post subject: |
Nice write up, thanks for sharing :0)
It seems like the Atwood furnaces may be a good alternative to the old factory installed BN4 & BA6 heaters, Atwood seems to have a good selection of sizes etc…
http://www.rvstuffusa.com/heatingac.html _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm |
dneubaum Samba Member
Posted: Sat Jul 25, 2009 8:07 pm Post subject: Atwood Everest furnace |
I installed an Atwood Everest Furnace in my '85 Westy about a year ago and it seems to be working great. I finally got a write-up posted here on "The Samba" for folks if interested.
Technical -> Manuals -> Heating and A/C section of the site here:
http://www.thesamba.com/vw/archives/manuals/heater_ac.php
Hope it helps folks if they decide to go this route.
Cheers,
Dan |
Posted: Wed Dec 23, 2009 3:08 pm Post subject: |
Nice writeup for a Vanagon Westy install dneubaum. It's a great furnace for these small campers and installing one is really not too hard either... if you don't mind cutting a new hole in your car..... _________________ 1978 Stock Westfalia Deluxe |
