Chrisf302 Samba Member
Joined: August 06, 2017 Posts: 3 Location: Wilmington Delaware
Posted: Sun Aug 06, 2017 7:22 pm Post subject: Wiper motor/ 12v conversion |
Hey guys,
I'm sure this is a topic that has literally been beaten to death. In fact I've read a great deal of them I'm sure. I'm new to VW's as I just recently purchased my first one. I'm into classic cars but mostly big early to let 50's American cars. I'm working on the 12vconversion on a 1965 bug. The only part that I'm stumped on at the moment is the wiper motor. Only because I do not wanna waste time and money buying the wrong parts. The wiper motor in my bug says avog. I see folks talking about SWF motors and Bosch motors. I see quick change parts for the Bosch motors but I can't seem to find information on avog. Maybe that's because avog is a SWF or a Bosch. I'm not sure so I figured I'd ask guys who know, even if I do look like a dummy. Thanks again guys. |
Snydr Samba Member
Joined: July 07, 2011 Posts: 467 Location: Gig Harbor, WA
glutamodo The Android
Joined: July 13, 2004 Posts: 26315 Location: Douglas, WY
Posted: Sun Aug 06, 2017 9:43 pm Post subject: Re: Wiper motor/ 12v conversion |
I have to say, I don't call having heard of "avog" before.
I "converted" my 62 to 12V long before any of the current options, back then all you could do is add some kind of extra high-wattage resistor(s) to effectively reduce the voltage by half. Later, since I was using a two speed wiper switch, I added another resistor to make my setup into two speeds:
I believe the resistances I have in my 62 are
Resistor #1 - 1.7 ohms;
Resistor #2 - 1.3 ohms; (but I use an adjustable hi-watt resistor so I can alter that at need) _________________ Andy T.
Snowbro Samba Member
jeffinohio Samba Member
Joined: February 02, 2017 Posts: 197 Location: Scio Ohio
Posted: Mon Aug 07, 2017 5:58 am Post subject: Re: Wiper motor/ 12v conversion |
Wolfsburg West has a drop in armature to replace the one in your wiper motor.Makes it 12 volt.No voltage drop needed.If I am not mistaken,voltage drops can generate a good amount of heat. _________________ 64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus |
Posted: Mon Aug 07, 2017 6:49 am Post subject: Re: Wiper motor/ 12v conversion |
I have no idea what 'avog' means on his wiper motor, but if it's not SWF, that armature is not an option. _________________ Andy T.
bluebus86 Banned
Posted: Mon Aug 07, 2017 12:00 pm Post subject: Re: Wiper motor/ 12v conversion |
It says avog on the top of the motor. I searched em and some have come up on eBay. I'm familiar with the inserts and the various parts used to do the conversion. I'm familiar with how those work and how to do it. I'm just not sure what part to order because like stated above you use different parts for different motors. The Bosch kit is differnt for the SWF kit. |
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Mon Aug 07, 2017 1:25 pm Post subject: Re: Wiper motor/ 12v conversion |
I run one similar, works great plus mine was less than 4 dollars
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Mon Aug 07, 2017 1:26 pm Post subject: Re: Wiper motor/ 12v conversion |
Gonna give you the best advice I was ever given when I started working on these cars. Don't overthink things.
I prefer doing the armature replacement on SWF wiper motors. Never heard of Avog but after a quick look, it seems they were used on really early cars..
You have a couple options. IF you can buy a replacement 12V armature for your motor, do that, but I doubt you will find one. Your car can also use a later wiper assy. You can source one for a 67 or newer standard bug and replace the whole wiper assembly. IF you are going to drive in the rain, you should take the assy out anyway and replace any needed bushings etc anyway and clean and lube (or replace) the wiper shafts and shaft grommets.
If you want to keep what you have and keep it real simple, then get the proper voltage reduction device as was mentioned earlier - install between the hot lead and the wuper motor and call it a day. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Mon Aug 07, 2017 7:27 pm Post subject: Re: Wiper motor/ 12v conversion |
Thank you man. That is what I thought enitially when I looked em up. It seemed as though the motor was off of an warlier bug from the 50's. At first I thought about just getting an essembly from a 67 bug off of eBay and making that work. But if there was an easier cheaper way I'd do that. I also didn't want to have to order several different conversion kits for the motor if I didn't need too. I've rebuilt gm wiper motors many times. I appreciate the help and advice and info. Thanks guys. |
VW Habit Samba Member
Joined: April 23, 2010 Posts: 146 Location: San Clemente, CA
Posted: Tue Aug 08, 2017 9:07 am Post subject: Re: Wiper motor/ 12v conversion |
On my '65 I used a '69 wiper assembly and motor with a '67 switch (so it matches the other knobs). For the wiring, I followed the stock '67 diagram. Now I have two speed wipers that work like a charm. |
Posted: Thu Aug 10, 2017 6:50 pm Post subject: Re: Wiper motor/ 12v conversion |
I would try to find someone locally that may have one. Hoarders tend to have a zillion wiper assemblies in tubs or crates.....But I am not a hoarder since I only have 1 tub and 1 crate of them. _________________ D-Dubya Manx clone - 63 Short pan,1914.
smokey503 Samba Member
Joined: October 01, 2010 Posts: 713 Location: Ridgefield Washington
Posted: Mon Oct 02, 2017 1:04 pm Post subject: Re: Wiper motor/ 12v conversion |
Didn't want to start a new thread.
The po did the 12v conversion. My wipers did work.
Just checked them and nothing.
It does have the 6-12v converter which looks like a tiny amp.
I was looking around to see why and noticed the small converter is really hot. _________________ If a car travels the speed of light, would the headlights work? |
bluebus86 Banned
Posted: Mon Oct 02, 2017 1:44 pm Post subject: Re: Wiper motor/ 12v conversion |
smokey503 wrote: |
I was looking around to see why and noticed the small converter is really hot. |
It could be hot for many reasons.
1...Resistance type of converter do heat up a good deal normally. Transistorized current limiting types dont get near as hot.
2... There could be a poor connection to the device, bad crimp on wire or such that is heating up itself and the converter.
3. The converter has fried, shot, kaput.
and anyrate do not leave this on if it is heating up a lot
Seeing as the wipers have just failed, my hunch is #2 or 3 if transistor type, if resistance type, that heat is telling me the wiper, working or stuck is drawing juice so the wiper might be stuck. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Wed Oct 04, 2017 4:55 am Post subject: Re: Wiper motor/ 12v conversion |
You could try the nifty little current limiter on my site. Just 4 components from Radio Shack etc. and a bit of soldering. It gets just a little warm. Its a current limiter set to the amps used by the 6v wiper motor so the wiper is actually working on 12v but cant overspeed.
www.vw-resource.com/wiper1.html _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
cb1990s Samba Member
Posted: Sun Jan 26, 2020 11:25 am Post subject: Re: Wiper motor/ 12v conversion |
Just found this - how did you wire it up? It has two in and two out. |
