aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Thu Apr 02, 2009 2:19 pm Post subject: Torque Master/Meister/Buddy what ever you call it |
I bought one of these marvelous tools and have used it for both flywheels and bug brake drum nuts. What I want to know is has anyone been able to get it to work on a bay window bus 46 mm drum nut? If so, pics please!
Posted: Fri Jun 17, 2011 1:41 pm Post subject: |
bump _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Fri Jun 17, 2011 1:50 pm Post subject: |
i have wanted to buy one, but i guess there has been a run of junk one's. 3 places i have called said they won't sell me one because of this anyway, can't help you but the old pipe trick is tried and true. i have a ingersoll TNT 1/2 drive impact that has yet to fail in this department. (i am, however using a hose with 5/8 ID _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Jun 17, 2011 2:28 pm Post subject: |
I also have an industrial IR 1/2 inch impact and an IR two stage corpressor that can pump 150 psi. This does the trick for me. The Torque Meister is something I also have and use occationally. I just think it would be cool if did bus axle nuts. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8544 Location: Las Vegas
Posted: Fri Jun 17, 2011 2:31 pm Post subject: |
I have one, and have used it on our bug. It works great, worth every penny.
I've never used it on a bus though. _________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
Posted: Fri Jun 17, 2011 2:52 pm Post subject: |
There are a couple guys on here that like to make tools. I bought a steering wheel puller from one. That's the kind of dude that could modify this to work on a bus. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
bugger101 Samba Member
Joined: September 04, 2010 Posts: 1559 Location: orlando
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3305 Location: Australia
Posted: Fri Jun 17, 2011 3:19 pm Post subject: |
Aeromech, your patience before bumping is exemplary.
Could someone please tell me what that thing does? I have never heard of one. I know it looks like a window regulator from some cars but that obviously isn't it. What does it do? _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
SGKent Samba Member
Posted: Fri Jun 17, 2011 3:34 pm Post subject: |
I thought the hammer units where one puts a breaker bar on it and then whacks it were supposed to work well. Something is needed cause when we took apart our 1977 I broke a 1" Craftsman breaker bar jumping up and down on it trying to break the driver's side nut free. I finally had to dremel through it enough to chisel a split into it. I also have a very high impact IR and that did nothing even at 125 psi. I figure we exceeded 1000 foot pounds of torque on that nut and it didn't budge. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Jun 17, 2011 3:47 pm Post subject: |
RatCamper wrote: |
Could someone please tell me what that thing does? I have never heard of one. I know it looks like a window regulator from some cars but that obviously isn't it. What does it do? |
Hahaha, yeah... I forgot about that post until I did a search today and it popped up. Here's a youtube video showing it at work:
http://www.youtube.com/watch?v=66PeguKXnds
You turn one piece around and then can do the flywheel gland nut. This is what I use to torque them. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Fri Jun 17, 2011 4:41 pm Post subject: |
all you would really need to do is duplicate the arm, and weld a socket on it. i think some good measurments, a piece of plate steel and a drill press and you could make it a couple hours _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Jun 17, 2011 4:48 pm Post subject: |
That's what I'm saying. I think one of those fabricator guys could whip up an accessory pretty quickly and maybe make a couple bucks. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Fri Jun 17, 2011 4:50 pm Post subject: |
as soon as i get my hands on one, i'll fab one up for ya. i should try again to purchase one. perhaps the bad batch is out of the system _________________
Jake Raby wrote: |
Brian wrote: |
El_Güero Samba Member
Posted: Fri Jun 17, 2011 5:29 pm Post subject: |
SGKent wrote: |
I thought the hammer units where one puts a breaker bar on it and then whacks it were supposed to work well. Something is needed cause when we took apart our 1977 I broke a 1" Craftsman breaker bar jumping up and down on it trying to break the driver's side nut free. I finally had to dremel through it enough to chisel a split into it. I also have a very high impact IR and that did nothing even at 125 psi. I figure we exceeded 1000 foot pounds of torque on that nut and it didn't budge. |
Sarge, last year i was faced with this exact same thing, i had my kid brother helping me on this one, we took the bus to a truck tyre shop to get the nut out with a 1" imparc IR and 150 PSI, no luck. So then i turn to him and say: "we got two options, ethier we start to cut our way trough with a chissel or we come down on this with heat", i went south and got a butane torch staring right at the nut sourrunding it with a blue flame, when time is right, wd-40 goes in action turning into a very fine mist almost mysticall, right then we put the 3/4 socket wrench in and stand on it, my brother laugh his face of saying i had allready ruined the rim coating, melted the wheel hub seals, and who knows what, right then the nut turned and i had the whole assembly off in 30 minutes, no tools broken, no bangging with chissels, no one hurt, and just cosmetic damage and a melted seal.... air and impact only gets you so far is my experience with super tight frozen nuts. _________________ "Sé que en algún lugar sus dedos pelean con un tornillo" (Remembering Carlos Amat)
"Si quiero estar encabronado
hazte a un lado...cabrón!" |
Posted: Fri Jun 17, 2011 6:19 pm Post subject: |
Wow, I've never run into one THAT tight. Knock on wood. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Desertbusman Samba Member
Posted: Fri Jun 17, 2011 9:37 pm Post subject: |
The wonderful fantastic $9 whacker tool, a breaker bar, a piece of pipe and a sledge does marvelous things. I did one axle nut and a 10 ft. pipe wasn't doing the job with it's massive torque. But standing as far out on the pipe as you can and reach back and give the Whacker Tool a real sharp chrisp whack with a sledge and it done. Not a wham but a whack _________________ 71 Superbug
71 Westy |
jeffsbugs Samba Member
Joined: May 02, 2011 Posts: 293 Location: Nanaimo, British Columbia, Canada
Posted: Fri Jun 17, 2011 9:47 pm Post subject: |
Desertbusman wrote: |
The wonderful fantastic $9 whacker tool, a breaker bar, a piece of pipe and a sledge does marvelous things. I did one axle nut and a 10 ft. pipe wasn't doing the job with it's massive torque. But standing as far out on the pipe as you can and reach back and give the Whacker Tool a real sharp chrisp whack with a sledge and it done. Not a wham but a whack |
X2!
They work great.
Until you get too old, or..,...your too stupid to use one.
J |
SGKent Samba Member
Posted: Fri Jun 17, 2011 9:49 pm Post subject: |
El_Güero wrote: |
SGKent wrote: |
Sarge, last year i was faced with this exact same thing, i had my kid brother helping me on this one, we took the bus to a truck tyre shop to get the nut out with a 1" imparc IR and 150 PSI, no luck. So then i turn to him and say: "we got two options, ethier we start to cut our way trough with a chissel or we come down on this with heat", i went south and got a butane torch staring right at the nut sourrunding it with a blue flame, when time is right, wd-40 goes in action turning into a very fine mist almost mysticall, right then we put the 3/4 socket wrench in and stand on it, my brother laugh his face of saying i had allready ruined the rim coating, melted the wheel hub seals, and who knows what, right then the nut turned and i had the whole assembly off in 30 minutes, no tools broken, no bangging with chissels, no one hurt, and just cosmetic damage and a melted seal.... air and impact only gets you so far is my experience with super tight frozen nuts. |
yes it is amazing what heat will do including destroy the temper of the metal. I remember trying to drill hardened rivets out once on a T4 Jeep trans. Titanium drill bit bounced. Hit it with a little heat, let it cool and a cheap steel bit went thru it like butter. Didn't even melt the grease farther out on the piece. I think we will keep heat off our axles. They were heat hardened at the factory and we like them that way especially when driving on winding roads with cliffs to the side. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Jun 18, 2011 8:24 am Post subject: |
I have those whackers tools for bug and bus but after years of swinging a heavy hammer and barely missing hitting the side of the bus I prefer something safer. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Tcash Samba Member
Posted: Thu Nov 27, 2014 8:42 am Post subject: |
Weld a 36mm nut onto a 46mm socket. |
