Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
Posted: Mon Mar 09, 2015 5:40 pm Post subject: |
Independently driven supercharger, run by a chain linked auxiliary engine, in a noble attempt to reduce the horsepower robbing effect of a large blower on that hemi. They took the charger and mounted it sideways across the front of the engine, blowing in to a custom intake/valley cover. The intake screen on the front of the charger would be where the carbs would normally mount between the intake scoop and the blower. Must have been a nightmare to synchronize the starting and fuel systems. That aux engine resembles ones that I have seen on some jet skis _________________ Jack Staggs
Actual name |
Jacks Samba Member
Posted: Mon Mar 09, 2015 5:43 pm Post subject: |
Aw John, ya beat me to it while I was typing. _________________ Jack Staggs
Actual name |
fabricator john Samba Member
Joined: October 09, 2009 Posts: 510 Location: manassas va. now Venice Fl.
Posted: Mon Mar 09, 2015 5:51 pm Post subject: |
Sorry but saw somthing finally that falls into my realm lol
Fabricator john |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Mar 09, 2015 6:07 pm Post subject: |
Finally! On page 319 I learn something cool! We needn't review trikes again, ever. _________________
EverettB wrote: |
FU#5 |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Mon Mar 09, 2015 6:27 pm Post subject: |
So that hydraulic pump looking thingy just behind the pony's flywheel, is that the fuel pump? Looks like the same style of fuel lines feeding the pony carb. _________________ nothing |
Posted: Mon Mar 09, 2015 6:32 pm Post subject: |
Let's post up some weird race car / motors Fabricator john |
Jacks Samba Member
Jacks Samba Member
Posted: Mon Mar 09, 2015 7:28 pm Post subject: |
drscope wrote: |
Since we're on stuff with less then 4 wheels, here's an easy one.
James Bond might look a little silly in that car. Mickey Rooney might be a better fit.
Dennis, I can't tell which pump is which on the low blower hemi.There is one on the lower right, and one on the upper left of the car. One for fuel & one for oil of some kind.
John? _________________ Jack Staggs
Actual name |
Posted: Mon Mar 09, 2015 7:44 pm Post subject: |
draginwagen wrote: |
Not a whole car but WTF is that?
Figured I would bring the photo over tho this page for easier reference.
Does look like two pump systems in place. Fuel and oil makes sense, but would it really need a belt driven fuel pump? _________________ nothing |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Mar 09, 2015 7:48 pm Post subject: |
Wow SO that compressor has its own 2 cyl engine to run it??? _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Mon Mar 09, 2015 7:54 pm Post subject: |
Pump on the top of the kicker motor appears to have a line going to the main engines oil pan , maybe lubing or evacuating lube from the blower mouned on it's side ,,, the lower pump is fuel and is belt driven you can see the manual cut off valve as nitro engines will diesel cuttin ign won't shut em off ,all hilborn style mechanical injection set ups use belt driven fuel pumps so the pressure and volume follow engine rpm , simple been that way since the beginning and are still that way today on fuelers and sprint cars , just my 2 cents
Fabricator john |
Da TOW'D Samba Member
Joined: December 25, 2005 Posts: 1321 Location: Bella Coma Canada
Posted: Mon Mar 09, 2015 8:24 pm Post subject: |
heck with floppy 3 wheel car/motorcycles
how about this stable looking car- way before PhotoShop
Hank _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy DD
and NUTS |
Posted: Mon Mar 09, 2015 8:43 pm Post subject: |
busdaddy Samba Member
Posted: Mon Mar 09, 2015 10:12 pm Post subject: |
Wouldn't that be a little hard on things like facial hair and lung function? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Mar 09, 2015 10:21 pm Post subject: |
busdaddy wrote: |
Wouldn't that be a little hard on things like facial hair and lung function? |
When one knocks on death's door, one need not concern themselves with things like fresh air and mutton chops. _________________ nothing |
GeorgeL Samba Member
Posted: Mon Mar 09, 2015 11:28 pm Post subject: |
Da TOW'D wrote: |
Hank |
1911 Reeves Octo-Auto, built from an Overland chassis. It failed to attract buyers so Reeves created the Sexto-Auto. It didn't sell either.
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Mon Mar 09, 2015 11:42 pm Post subject: |
I'm looking at the trailer in the back ground. It was popular and common to have open trailers that used channel for the skinny tires to sit in. But look at the pipe/tube used to triangulate things so the channel didn't bow down.
It's on the INside of the channel, so the car would have to have a lot of ground clearance to be able to clear that.
That was also a pretty popular design, but I've never seen one that high one the INside of the channels. Usually they are on the outside. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Tue Mar 10, 2015 8:04 am Post subject: |
GeorgeL wrote: |
Da TOW'D wrote: |
Hank |
nailed it George
looks like it should be on railroad tracks
cheers
'58 SC Ruf
'62 type 3 Notch
and NUTS |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Tue Mar 10, 2015 9:31 am Post subject: |
cdennisg wrote: |
busdaddy wrote: |
When one knocks on death's door, one need not concern themselves with things like fresh air and mutton chops. |
He lived till he was 81. He cheated death many times in his jet cars and tractors. |
Posted: Tue Mar 10, 2015 10:41 am Post subject: |
ToolBox wrote: |
cdennisg wrote: |
busdaddy wrote: |
Sometimes the knock at the door goes unanswered. _________________ nothing |
