TheSamba.com Fast Fab
Clear distributor cap questions..opinions
Goto page 1, 2  Next
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
ECRAB3
ECRAB3 is offline
PostPosted: Fri Apr 10, 2009 8:51 am    Post subject: Clear distributor cap questions..opinions Reply with quote
Hi all. I noticed the negative opinions on here regarding the clear type caps whenever it is brought up but I havent really read the reasons why. I heard that they tend to break easier on the tabs, that type of plastic isnt as durable as the maybe solid color types or the old brown caps, I assume. But as far as electrical properties, just by looking at them, im guessing all the balls behind these things are in the post that the plug wires connect to. Maybe that material isnt as good as a conductor as the non clear types or not long enough to connect with the rotor?. What is the reason aside from the plastic breaking easier that makes them so undesireable? And Yes I have one on mine, but I also have a back up for when clear blue one breaks. Just wondering.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Apr 10, 2009 8:58 am    Post subject: Reply with quote
They arc, they are not as well made.
When was the last time you saw a car with a factory clear cap?
Glenn
www.DasVolks.com
Long Island's Aircooled Club
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Fri Apr 10, 2009 8:59 am    Post subject: Reply with quote
Me, I'd just rather stick with OEM quality Bosch or other German-made tune up parts. I saw way too much aftermarket junk when I was a mechanic and I have much more faith in Bosch parts. Before I knew any better when I was much younger, I thought it'd be cool to have one and see what it looked like in there in the dark. Then I saw one, and was underwhelmed. That's a bit of bling that I don't need.
-Andy
joescoolcustoms Premium Member
joescoolcustoms is offline
PostPosted: Fri Apr 10, 2009 9:10 am    Post subject: Reply with quote
When I drag raced, I used one to set up my distributor. I could see the rotor with a timing light to phase in the terminals (locked distributor running a crank trigger). After phasing complete, I switched back to a OEM bake-o-light style cap for the reasons Glenn stated.
1-20-13 The end of an Error.
Therapy helps, but screaming obscenities is cheaper !!
Lo Cash John Wrote:
"I love my country but HATE my president!"
X2 now
bon2198
bon2198 is offline
PostPosted: Fri Apr 10, 2009 10:16 am    Post subject: Reply with quote
i have a clear blue one on mine. haven't noticed any difference in quality/performance. but i do keep a bosch in the car for obvious reasons.
1970 VW Beetle 1776cc MOFOCO w/hydraulic lifters, 042 heads and dual dellorto's
"It's better to be hated for what you are than loved for what you are not"
At the end of the day it's YOUR car so do what YOU want to it.
tuna
tuna is offline
PostPosted: Fri Apr 10, 2009 11:16 am    Post subject: Reply with quote
I actually watched one arc out to the fuel pump on a car.... that's not a good way to keep your VW alive. Keep the clear caps for trailer queens.... use the good Bosch caps for a car that is actually driven. -- Tuna
Click to view image
Type 4: Secrets Revealed
Tom's Type 4 Corner
EMPI Imp Homepage
1970 EMPI Imp
1969 Bug - 2056cc Type 4 powered Cal-Look'r
mharney
mharney is offline
PostPosted: Fri Apr 10, 2009 11:29 am    Post subject: Reply with quote
You can tell people all day that the caps are junk and why, but it's like leading a horse to water. They'll just shrug, use them, and then later you get to hear their new song about how they suck, or you get to hear the old "I been using one for years" from the lucky ones.
They're junk. They're made to look cool. They're not made to perform.
miniman82 Premium Member
Samba Swamp Donkey
miniman82 is offline
PostPosted: Fri Apr 10, 2009 12:19 pm    Post subject: Reply with quote
This topic again? Rolling Eyes
EFI/TURBO BUILD THREAD
Rajay Turbos For Sale!
Bashr52
Bashr52 is offline
PostPosted: Fri Apr 10, 2009 12:36 pm    Post subject: Reply with quote
Yup, and were due for a "how much hp do I have", and "do these electric turbos work".
Samba Swamp Donkey
PostPosted: Fri Apr 10, 2009 1:16 pm    Post subject: Reply with quote
You don't need an electric turbo- if you want to go fast, a Honduh guy told me you need THIS! Said it added 25 hp to his Civic.Laughing
PostPosted: Fri Apr 10, 2009 1:40 pm    Post subject: Reply with quote
That must be what Dodge put up the exhaust pipe on my diesel dualie. Laughing
X2 now
Mr. 010
Glenn is offline
PostPosted: Fri Apr 10, 2009 1:42 pm    Post subject: Reply with quote
Guys... let's stay on topic.
Glenn
www.DasVolks.com
MAYHEM Premium Member
MAYHEM is offline
PostPosted: Fri Apr 10, 2009 1:48 pm    Post subject: Reply with quote
Good call. I had one "back in the day" and never had any problems. Have heard of many having problems though.
Knowledge speaks. Wisdom listens.
Greg
Model Citizen
Eaallred
Eaallred is offline
PostPosted: Fri Apr 10, 2009 2:40 pm    Post subject: Reply with quote
The problem with the plastic caps is they carbon track. It takes a while, but after time you will start mis-firing because of it.
When new, they work the same as a Bosch cap. Just have to change it more often since the bakelite or whatever material the Bosch caps are made from do not carbon track as badly.
Eric Allred
1963 EFI/Crank Fired Drag Bug
Utah's fastest N/A VW
2005-2006-2007-2008-2009
Housework is a snap since I realized..."Hey! I'm a guy!"
ECRAB3
ECRAB3 is offline
PostPosted: Mon Apr 13, 2009 8:30 am    Post subject: Reply with quote
Thanks for the information guys on the arcing. That I had not read on here before. I appreaciate the explanations for sure. Even the inevitable slams about HP , trailer queens and hyper blue blinker fluid Rolling Eyes
Thanks again for the info guys Very Happy
thefladge
thefladge is offline
PostPosted: Mon Apr 13, 2009 4:32 pm    Post subject: Reply with quote
Back in the day (the '80's) I ran a red see-through cap on my Cal-Look Bug. Worked great, no problems, no "carbon tracking", no arcing. Over time, it faded to orange and needed to be replaced as any normal cap would be replaced from age.
I bought a blue cap. The blue one was a piece of junk. The wires would not stay attached to it. All of the wire connections were too big and the wires had nothing to grip to. I used real Bosch caps from then on.
That being said, I purchased a clear cap a week ago. I bought it only to be able to see if my vacuum advance is working smoothly. I have not tried it yet. After I check that, the Bosch cap is going back on.
1957 Vintage Baja Bug.
Full roll cage, gear reduction transaxle with Johnson laydown adapters, Porsche 356 spindles, Ford tie rod ends,
2110cc engine and spare 1641cc engine.
Jake Raby
Jake Raby is offline
PostPosted: Mon Apr 13, 2009 4:47 pm    Post subject: Reply with quote
I figured out these things were junk before the age of 13.... These are right up there with chrome alternator pulleys, dune buggy dual exhausts and stock engines with huge cams...
Jake Raby
www.aircooledtechnology.com
57 Oval (application TBD)
63 Bug "Project X"
66 Bug- Bluebonic Plague (retired)
68 VW Double Cab (W/915 trans)
71 Superbeetle Vert (For Sale)
73 VW Thing (In resto since 1999)
73 Superbeetle (For sale)
73 Superbeetle (Awaiting a 2.4 MassIVe engine)
74 Pinzgauer 710M 4X4
76 Porsche 912E- MassIVe 2056 155K of abuse!
fusername
fusername is offline
PostPosted: Mon Apr 13, 2009 5:02 pm    Post subject: Reply with quote
I never understood how a dizzy cap could not work...
CustomBusBits@Gmail.com
Need something custom bent up? shoot me an email, maybe we can make it work!
WTB: 73-79 Project bus, no rust but that's my only requirement, MISSING engine/glass/trans OK! ANY state!
FORSALE: Thrust cut T4 and 1.9 main bearings
Jake Raby
PostPosted: Mon Apr 13, 2009 5:11 pm    Post subject: Reply with quote
Use one of these and it'll be clearly illustrated in about 3 months.. Or the first time you drive it in a heavy rain storm!
Jake Raby
63 Bug "Project X"
fusername
PostPosted: Mon Apr 13, 2009 5:17 pm    Post subject: Reply with quote
it's tempting to install one just to see how bad it is, that sounds like a good show.
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
Goto page 1, 2  Next
Copyright © 1996-2010, Everett Barnes. All Rights Reserved.   | Archive
