Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3574 Location: Sarasota, in my adopted state of Florida
Posted: Wed Jan 07, 2015 1:40 pm Post subject: |
raul arrese wrote: |
Im interested in beehives but I really don't think there are good choices out for our applications . |
Why? I see no reason why they would not make a good street spring. All out race spring? No
Dan |
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1329 Location: miami florida
Posted: Wed Jan 07, 2015 1:46 pm Post subject: |
well I guess you can have some made , but what I really ment is readily available springs with the correct hieghts we need without machining or installing longer valves . _________________ " Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608 |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Wed Jan 07, 2015 5:27 pm Post subject: |
I don't think you are going to get springs made to fit stock standard heads - the register in the head is not going to suit the springs. There are Ford springs that will fit by machining the guide boss and head to fit the spring and take it a little deeper. There is a thread about from Vincent in France who used comp cam springs, but there is a PAC racing spring that looks better to me. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
mark tucker Samba Member
Posted: Wed Jan 07, 2015 5:35 pm Post subject: |
look at the manley catalog(on line) they have a very good size chart of their stuff, you should be able to pick out somethen very close. |
modok Samba Member
Joined: October 30, 2009 Posts: 26740 Location: Colorado Springs
Posted: Wed Jan 07, 2015 6:32 pm Post subject: |
I've posted the part number a half dozen times already of the beehive that fits a stock spring pocket but nobody seems to have any interest since you can only lift about .450 with adequate seat pressure(85 lb).
part number: sbi-160-1436
The GM LS oval wire spring requires at least a type-4 length valve but that should not be a problem. valves cost the same no matter what length.
The reason you need longer valves is retainers........it's dead simple once you realize.
A tiny retainer cannot allow the spring to sit above the keepers like usual VW retainers do.
Could also move the keepers upward using 22r or b2000 valves and that is fine too but please use chrome stem valves, not nitrided! |
Mrblue01 Samba Member
Joined: January 09, 2009 Posts: 18 Location: Westland, MI
Posted: Thu Jan 08, 2015 8:37 am Post subject: |
The springs that PSI sells are designed fit around the stock cylinder head boss without machining (I designed them myself).
The biggest benefit of a beehive spring is that you can use a retainer of a smaller diameter - less weight. A bugpack or berg retainer is roughly 21g... a retainer for the PSI spring is roughly 11g (the same as a full size titanium). Plus the spring itself is lighter (at the moving end) than a cylindrical spring.
The other benefit of a beehive is that the spring rate is changing as the larger coils close up and only the smaller diameter coils are active. This changing rate is also a changing natural frequency. Therefore the spring is less likely to go into a nasty harmonic and lose control of the valve. |
Posted: Thu Jan 08, 2015 8:54 am Post subject: |
Mrblue01 wrote: |
PSI part #?
Dan |
Posted: Thu Jan 08, 2015 9:35 am Post subject: |
D148X (details on page 1 of this thread)
It was designed to replace a single Bugpack HD spring that most racers use in a 1/2 1600 off-road engine. 0.450"ish lift, 6000 rpm. |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1668 Location: Niagara Region, CANADA
Posted: Fri Feb 26, 2016 11:30 am Post subject: |
Mrblue01 wrote: |
No listing for this spring on the PSI site... |
Posted: Tue Mar 29, 2016 10:30 am Post subject: Re: beehive springs. |
Correct, it is not officially in the PSI catalog. It was made as a private custom spring, but has been sold to the public - primarily through R/D Spring (its on their website). They also sell a version of it with less load for applications trying to minimize friction. (Formula Vee, etc) |
