davebuckholts Samba Member
Joined: February 06, 2004 Posts: 2173 Location: South GA
my65vert Samba Member
Joined: November 09, 2003 Posts: 6186 Location: Middleburg, Florida
Posted: Tue Jun 09, 2009 11:20 am Post subject: |
I sent him an extra set that I had. _________________ OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment. |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
Posted: Wed Jun 10, 2009 9:37 am Post subject: |
Quick update on seat belts, and covering the cushions.
I didn't want to install seat belts at the gas tank level so I went lower as indicated by the pics. If you plan to sit anyone with a waist larger than 14", you need to get the longer middle seat belts from WW. They are too long, but the shorts are too short.
I have all my foam in place and cut to fit. I found the foam at Ikea in the form of a fold out bed mattress they had in the "as is" section of the store. By the way, everyone was talking about hot knifes and electric knifes to cut the foam. I found that if you scored your line top and bottom with a sharp razor blade down an inch or so, a 9" serrated bread knife worked great. Not perfect, but wont be noticable with the covering. Looks like 6 yards of material to complete the covers. Should be done in the next week, and I will post up completion. If you make a the bed less wide, you could get away with less, traditional fabric, vinyl is less then the width, so had to go long to go wide. |
Posted: Mon Jun 22, 2009 10:48 pm Post subject: |
Cushions are covered. Home made curtains as well, wife did my upholstery.
WTerlinden Samba Member
Posted: Tue Jun 23, 2009 8:07 am Post subject: |
Hi Dean!
Great dokumentation!
Am I allowed to use your Images in my blog?
I would like to translate your Posting to german having a dokumentation about this bed.
Thanks!
Willy _________________ Kind regards, Willy
My blog:
http://www.dutch-coast-customs.de |
Posted: Tue Jun 23, 2009 10:25 am Post subject: |
Willy,
Help yourself. Let me know if you want direct images or any other info.
Dean |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
Posted: Sat Nov 28, 2009 6:30 pm Post subject: |
Thanks for sharing. Nice metal work. |
ThatVWGuy Samba Member
Posted: Tue Oct 19, 2010 5:46 pm Post subject: |
I didn’t see it mentioned elsewhere but I used 1” thick plywood when I made my full width bed. It eliminated any bow in the plywood. Depending on the size of the folks in the bed and their level of "restlessness" I would strongly suggest it. (I had to go to a specialty lumber store to find it.) |
Posted: Tue Oct 19, 2010 8:18 pm Post subject: |
EDragnDean wrote: |
Good point. You could use 1 inch, can't hurt. I used 3/4 with cross supports to increase rigidity and eliminate warp, etc. 3/4 is holding up fine. |
Thought about that but the supports intrude into the under seat storage space. Not much but it effects the size of container you can put under there. |
Solan Samba Member
Joined: March 26, 2009 Posts: 41 Location: Bergen, Norway
Posted: Thu May 12, 2011 4:27 am Post subject: |
I'm sorry if I mess up this thread, and maybe the answer is somewhere here on theSamba, but does anyone have a drawing with metric measurements for cutting and installing a full width rock&roll bed in a split camper? My hinge supplier only got me an "inch drawing" for a 3/4 width r&r bed...
Links or pdf's greatly appreciated!
Cheers from Bergen, Norway
Svein _________________ '65 11W Microbus
'52 Beetle ragtop |
