jensvw Samba Member
Posted: Mon Mar 28, 2011 8:34 pm Post subject: Back Firing from Exhaust and Carbs? |
I'm trying to get my friends bug going. it has a 1641cc dual 40's mild 110 cam, i believe stock heads, stock manual fuel pump. I shot the timing and synchronized the carb's, But when revving the motor to about 200-300 it starts to back fire out of the passenger side carbs and exhaust. Would it be a fuel pump situation or just bad firing? Please info me on this. Thanks! _________________ All throttle...no bottle. |
mharney Samba Member
Posted: Mon Mar 28, 2011 8:36 pm Post subject: |
Dual 40 WHATs? |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Mon Mar 28, 2011 8:39 pm Post subject: |
Lean and or poor linkage geometry. One carb is leading the other and possibly a/f mixture screws not set properly. Pull the plugs and read em. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
jensvw Samba Member
Posted: Mon Mar 28, 2011 9:21 pm Post subject: |
Weber's _________________ All throttle...no bottle. |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Mon Mar 28, 2011 9:26 pm Post subject: |
Are the plug wires routed correctly? Are the carbs synchronized? What jets are in the carbs? _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
jensvw Samba Member
Posted: Mon Mar 28, 2011 11:01 pm Post subject: |
Yes,sync the Carbs balanced on both sides as well as the timing. _________________ All throttle...no bottle. |
