Rear seat belts for a double cab? Solutions needed.
jtauxe
jtauxe is offline
PostPosted: Mon May 11, 2009 7:55 am    Post subject: Rear seat belts for a double cab? Solutions needed. Reply with quote
Has anyone managed to fit seat belts into the rear seat of a double cab? I was looking at one this weekend (a '78 ), and it seems that the rear seats never had belts. I suppose that as a truck this was not required in its country of origin.
In examining the body behind the rear seat, I really didn't see anything to mount lap belts to, though curiously the shoulder mount points are there in the pillars, fitted with little plastic blanks. The only idea I have yet had is to weld in some sort of angle iron spanning the width of the bus behind the seat...
Then there is the problem of the shoulder mount for the middle position of the rear seat. I consider shoulder belts mandatory in the back, since the pony wall behind the front seats would be the target for the face of anyone sitting in the back seat with only a lap belt.
So - looking for ideas, here! Idea Question
John
"The bus came by and I got on. That's when it all began..." - Garcia/Weir/Kreutzman
Long gone: 1969 and '78 CE Transporters, Westies: 71, 76, 77, 76, 77, 71, 73, 77
For sale: 1974 Westy Automatic
Current projects: 1975 Single Cab, 1978 RHD Double Cab 2.0-L FI
http://vw.tauxe.net
busdaddy
busdaddy is online now
PostPosted: Mon May 11, 2009 8:13 am    Post subject: Reply with quote
All bay DC's have seat belt mounts, they are hiding on the bottom of the crossmember at the lower edge of the rear bulkhead. As for a center shoulder harness? Start eyeing some current Mvans and SUV's for that solution.
Wanted, 68-73 westy OG plaid curtains, singles OK.
jtauxe
jtauxe is offline
PostPosted: Mon May 11, 2009 9:38 am    Post subject: Reply with quote
Ah - on the bottom! Ha - I couldn't see under there, and didn't feel around. That would be great -- I'll have to locate these next time I check it out. Thanks!
Are these standard seat belt bolt mounts?
A remaining problem is how to mount a retraction reel down there...
And, of course the middle seat shoulder harness. Modern vehicles (like our Honda Odyssey and the Subaru Outback) have the retraction reel built into the overhead. The roof metal is just too thin on the double cab to support that. Maybe somewhere down on the crossbar, though a high mount point is still needed. Perhaps immediately below the window?
John
http://vw.tauxe.net
naynay
naynay is offline
PostPosted: Mon May 11, 2009 2:29 pm    Post subject: Reply with quote
I had my DC for 12 years- and never managed to figure that out....now I know. Of course I didn't know about the Samba until I was trying to sell the Doka!
74 Rivi
"Do not let what you cannot do interfere with what you Can do." - John Wooden
jtauxe
jtauxe is offline
PostPosted: Sun May 24, 2009 1:10 pm    Post subject: Reply with quote
OK. Well, now that I have the bus... this one has nothing of the kind. I expect I'll have to fabricate something with a piece of beefy angle-iron across the back or something. I'll have to find a capable body welder... this is not going to be easy. But what's the point of a double-cab if you can't sit in the back (and for me, there is no sitting anywhere without belts).
John
http://vw.tauxe.net
hcdmueller
hcdmueller is offline
PostPosted: Sun May 24, 2009 1:43 pm    Post subject: Reply with quote
As far as I can tell the back seat on the double cab was supposed to have non retracting seat belts. The center belt looks like it was supposed to be a lap belt only. I have seen kits that mount at any angle. It was from Just Kampers if I remember correctly. Here is a link to Ratwells site on the DC truck.
http://www.ratwell.com/technical/Pickups.html
jtauxe
jtauxe is offline
PostPosted: Sun May 24, 2009 2:11 pm    Post subject: Reply with quote
Oops - I misspoke. Busdaddy, you are right! The belt mounts are not on the bottom of the crossmember, they are bit further back, in the zig-zag of supports for the front foot or so of the bed. And there are six of them -- enough for three people. Excellent! Razz
And I obviously didn't realize that R Atwell has this covered here:
http://www.ratwell.com/technical/Pickups.html#seatbelts
Now, the only remaining problem is where to mount the retractor reels on the sides, and figure out if there is any way at all to have a center shoulder belt. Maybe I give up on retractables in the rear, and just use standard 3-point belts.
John
http://vw.tauxe.net
jtauxe
jtauxe is offline
PostPosted: Tue Apr 24, 2012 10:52 am    Post subject: Reply with quote
Long overdue update:
With the fabrication of some L-brackets, I did manage to install retractor reels for the side seats in the back of the DC, but the middle seat is lap only.
So - two retractable shoulder belts and one lap belt in the back. Pretty good, and it works well.
John
http://vw.tauxe.net
70Crew
70Crew is offline
PostPosted: Thu May 17, 2012 5:51 pm    Post subject: Reply with quote
It would be great if you could post a couple photos of those brackets with the retractable belts mounted on them.
westy66
westy66 is offline
PostPosted: Sat May 19, 2012 11:21 am    Post subject: Reply with quote
i got some nice non-retractable lap belts from NAPA for about $25. bolted right up, easy-breezy!
