eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Mon Sep 05, 2016 9:52 am Post subject: Re: Type 3 Truck - the "other" vw |
dc. I put nutserts in the floor and used a stainless steel hinge. The strips of aluminum are threaded into the engine cover. My engine cover is 1/8th aluminum.
The floor is wine barrel wood, milled down, tongue and grooved. _________________ I think he meant "rare", as in "not well-done" |
dc Samba Member
Joined: April 03, 2004 Posts: 1426 Location: Kitsap Peninsula
Posted: Mon Sep 05, 2016 9:54 am Post subject: Re: Type 3 Truck - the "other" vw |
Peter - thank you- that helps
Eyetzr- beautiful custom wood--- i understand why you went with a custom metal lid under the wood.
I suspected the tabs were left off on the panel---- that makes the engine lid another unique part I'll have to see how to modify mine without messing it up too much. _________________ 1963 Karmann Ghia |
eyetzr Samba Member
Posted: Mon Sep 05, 2016 6:31 pm Post subject: Re: Type 3 Truck - the "other" vw |
Thanks for the props. I had hacked my floor way back and had the carbs through the floor. I did close in the floor hole a bit and fabricated a new 'stock' engine cover. The plan for my car was my idea of a fancy panel van.
I was going to go the truck route, but found Aaron and his panel. I. Do have someone in my hood with a 72 truck. I told him to check your build. _________________ I think he meant "rare", as in "not well-done" |
dc Samba Member
Posted: Mon Sep 05, 2016 6:44 pm Post subject: Re: Type 3 Truck - the "other" vw |
Cool
Hey- what did you do for the metal rails? Did you find them or make them?
I was thinking 1" aluminum, they are not the same profile... _________________ 1963 Karmann Ghia |
eyetzr Samba Member
Posted: Tue Sep 06, 2016 4:41 am Post subject: Re: Type 3 Truck - the "other" vw |
I found some local aluminum extruder that had some. I looked at 1" & 3/4". I found the 3/4" looked simpler(?) and less fussy. I ground the ends on an angle & drilled & countersunk the screws in.
Just google aluminum extrusions & you will find something. Good luck _________________ I think he meant "rare", as in "not well-done" |
Peters Van Samba Member
Joined: March 27, 2014 Posts: 357 Location: Goulburn NSW Australia
Posted: Tue Sep 06, 2016 10:15 pm Post subject: Re: Type 3 Truck - the "other" vw |
the metal strips on the original panelvans are zinc coated.
they are the same as the strips found on the floor and back of the rear seat in some early 60s station wagons. both ford and gm had them here in australia. _________________ 1965 Type 3 Panel Van
1963 EH Holden Station Wagon |
dc Samba Member
Posted: Sun Sep 18, 2016 7:47 pm Post subject: Re: Type 3 Truck - the "other" vw |
Making some progress on the bed wood... this is fun but slow going
Got the lid mostly there-- just needs some sanding on the edges for perfect gaps. The rails are cut and now need to be finished (rounded edges and tapered holes drilled). After it's all mocked up, I will take it apart and stain and seal it. etc. before final assembly
Also got a panel installed in the tail-gate--- will do the same with the sides of the load area/bed. The rust will be treated,etc when the wood is out being stained and sealed...the beat goes on _________________ 1963 Karmann Ghia |
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
Posted: Sun Sep 18, 2016 8:06 pm Post subject: Re: Type 3 Truck - the "other" vw |
dc, your panels look awesome. Look forward to seeing the stain bring the panels to life. That grain is going to look amazing. What are your plans for the wheel well humps? _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
dc Samba Member
Posted: Sun Sep 18, 2016 8:45 pm Post subject: Re: Type 3 Truck - the "other" vw |
Thanks--working with wood is a fun shift from metal
The wheel well humps are pretty beat up- I think will clean them up and paint but not repair or reshape- maybe just cover them with a second skin of some sort... got any ideas? _________________ 1963 Karmann Ghia |
eyetzr Samba Member
Posted: Mon Sep 19, 2016 3:44 am Post subject: Re: Type 3 Truck - the "other" vw |
Wow looks great. The wheel wells could be smoothed over with filler & wrapped in water-resistant vinyl, or smooth out & use some spray on bed liner, it is after all a "bed". Nice work _________________ I think he meant "rare", as in "not well-done" |
MonT3 Samba Member
Posted: Mon Sep 19, 2016 6:41 pm Post subject: Re: Type 3 Truck - the "other" vw |
dc wrote: |
The wheel well humps are pretty beat up- I think will clean them up and paint but not repair or reshape- maybe just cover them with a second skin of some sort... got any ideas? |
I was going to suggest clean the metal up and spray it with some undercoating or the like. As Eyetzr mentioned it is a bed. You could coat the sides thick and thin out application underneath the wood for some added protection. Just a though. Either some roll-on or spray. I wouldn’t worry too much on dents there as it is a truck bed and blacked out would offer a nice contrast to the stained wood when finished. Whatever you decide, I look forward to seeing it. I know you’ve put a lot of time and effort into getting that engine lid square away. Would have been nice to have the grain going the same way as the bed. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
dc Samba Member
Posted: Tue Sep 20, 2016 6:05 am Post subject: Re: Type 3 Truck - the "other" vw |
Yeah- The grain going the wrong way bugs me a bit It wasn't an accident just couldn't find any 1/4" pieces that were wide enough to lay in that direction... It wouldn't be too hard to cut out another piece if it is too annoying to live with.
Now I'm trying to get those mounting holes drilled--- I've practiced on scrap pieces and it's not easy to get the holes nice and clean with a simple hand drill. May have to take them to my local machine shop. _________________ 1963 Karmann Ghia |
eyetzr Samba Member
Posted: Tue Sep 20, 2016 8:29 am Post subject: Re: Type 3 Truck - the "other" vw |
I guess by mounting holes you mean the aluminum strips? I used a hand drill & drilled the holes, then used a countersink to recess the holes. _________________ I think he meant "rare", as in "not well-done" |
MonT3 Samba Member
Posted: Tue Sep 20, 2016 5:31 pm Post subject: Re: Type 3 Truck - the "other" vw |
dc wrote: |
Now I'm trying to get those mounting holes drilled--- I've practiced on scrap pieces and it's not easy to get the holes nice and clean with a simple hand drill. May have to take them to my local machine shop. |
Either way, it's going to look beautiful when done. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
dc Samba Member
Posted: Fri Sep 23, 2016 10:35 pm Post subject: Re: Type 3 Truck - the "other" vw |
Got the holes drilled after finding the proper countersink bit. The lid rails are secured with nuts and bolts - just about all the other holes will use screws (they are just sitting there in the picture).
Now, I have to take it all apart, restore the bed metal, prep the wood AND THEN put it all back together. Whew
Posted: Sat Sep 24, 2016 5:00 am Post subject: Re: Type 3 Truck - the "other" vw |
nice work there..........
might have to get you to do mine for me as im busy with a bathroom reno at the moment........ not much time for the panelvan..........
how did you go with the engine lid ????? did you cut the tabs off ????? _________________ 1965 Type 3 Panel Van
dc Samba Member
Posted: Sat Sep 24, 2016 10:30 am Post subject: Re: Type 3 Truck - the "other" vw |
Yep-
Cut the tabs--- I'll show you some pictures when I get it apart to paint. My lid is not in good shape - rust here and there- but I think it will be ok with some more attention _________________ 1963 Karmann Ghia |
Posted: Sun Sep 25, 2016 12:51 am Post subject: Re: Type 3 Truck - the "other" vw |
engine lids should be easy to find i would imagine ........... _________________ 1965 Type 3 Panel Van
dc Samba Member
Posted: Thu Oct 06, 2016 11:51 am Post subject: Re: Type 3 Truck - the "other" vw |
Getting closer on the bed restoration:
Strip:
Sand and add rails and tabs to mount side panels:
Two coats of RustBullet (love that stuff):
More work to go....BlackShell topcoat... 72 hours of cure, fabricate and intstall side panels. Then, finally, the wood floor will go in. Maybe by the end of the weekend _________________ 1963 Karmann Ghia |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Thu Oct 06, 2016 7:17 pm Post subject: Re: Type 3 Truck - the "other" vw |
Looking goog man looking good. That truck has come a long way since the last time I saw it in person (2012 Invasion). Nice job. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
