Deluxe Clock Question
FlusteredBust
FlusteredBust is offline
PostPosted: Thu May 14, 2009 6:32 am    Post subject: Deluxe Clock Question Reply with quote
I am attempting to revive my deluxe clock (1960) and I have been reading all of the clock related threads for information. When I took the clock apart, the solder joint between the electro-magnet that winds the clock and the power supply was broken, and the wire that feeds that part of the clock (there is a separate light wire too) was fried all the way back to the steering column where it disappears into the wiring harness. Looking at the clock repair tutorial in the FAQ an obvious improvement was made in later clocks. The solder connection in the newer design breaks the connection when it fries saving your wiring. In my clock, even if the solder melts, there is still a physical connection. To protect my new wire, I intend to add an inline fuse. Does anyone have any recommendations as to what size and type of fuse I should use? I am considering a fast-acting 5A inline fuse.
Thanks
Culito
11010101
Culito is offline
PostPosted: Thu May 14, 2009 6:50 pm    Post subject: Reply with quote
I'm sure that clock doesn't draw that much...anywhere from two to five amps should be fine to protect your wiring.
Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
DannoT
DannoT is offline
PostPosted: Mon Jan 25, 2010 9:03 pm    Post subject: Broken clock Reply with quote
Ok so after much procrastination i have gotten around to fixing my bus's clock after taking it apart and adding machine quality clock oil every thing runs smoothly but when hooked to electricity it doesnt run. T clarify when i pull back the winding spring and reliece it all the cogs and springs work and even turns the hands of the clock but fails to rewind the spring on its own i have thouroly cleaned it but still no success. I do not know what the problem is and i do not know how the electic motor rewinds the clock. any suggestions on how to procede?
This arm is what i suspect winds the clock but i dont know
the fuse is whole and connected
the whole clock
VolksFire
VolksFire is offline
PostPosted: Mon Jan 25, 2010 9:09 pm    Post subject: Reply with quote
clean the contact points. a fine file or fine sand paper. then hook it up to power. it should contact and windup. ive done many clocks. its always the points, usually.
Jahnai Pearson - VW Restoration Technician
60 Double Door Panel
63 Double Cab
63 Single Cab
67 SO42 Westfalia
73 Thing
76 Kombi
82 Westfalia Deluxe
82 Quantum Coupe
85 Quantum Sedan
85 Quantum Syncro Wagon
96 Golf GL
DannoT
DannoT is offline
PostPosted: Mon Jan 25, 2010 9:16 pm    Post subject: Reply with quote
Thanks Ill give it a try
DannoT
DannoT is offline
PostPosted: Mon Jan 25, 2010 9:46 pm    Post subject: Reply with quote
Ok i cleaned out my contacts and hooked it up and still nothing im thinking it could be a wireing problem but im no electrician. I ran my voltage meeter to the ground and hot wire while un hooked up and got .38 volts which seems odd to me then i checked the wires while hooked to the clock and got 0 volts which suggests to me a short but i am no expert. Do any of these # make sense to any one?
BarryL Premium Member
BarryL is offline
PostPosted: Tue Jan 26, 2010 8:20 am    Post subject: Reply with quote
Do you know how to check the resistance of the electro-magnet or Ohm it?
///Mink
///Mink is offline
PostPosted: Tue Jan 26, 2010 8:34 am    Post subject: Reply with quote
Your fusible link is likely burned out. This is a Ghia clock, but the idea is the same.
DannoT
DannoT is offline
PostPosted: Tue Jan 26, 2010 4:19 pm    Post subject: Reply with quote
Off to the far left of the image is the battery post bracket with the post out
Ok the fuse is fine but the negative post does come out and do to a lack of knowledge in the workings of clocks i do not know if this is bad and also there is nothing beneath the post so i assumed the entire clock was the ground but when hooked to a 12 volt battery i get a 0 volt reading between the clock battery and positive post.
Shaun Murray
Shaun Murray is offline
PostPosted: Sat Nov 03, 2012 11:22 am    Post subject: Reply with quote
My clock didn't work in my 66' deluxe so I installed this working VDO clock from a '59? Mercedes. It really doesn't look too bad, fit perfect width-wise, has a small gap at the top. I've converted my bus to 12V and this is a 12V clock. Would a '59 Mercedes have been 12V?
My original clock appears to be in really nice condition. I doubt it's worn excessively because the bus was parked/abadoned/left for dead in '78.
So what's the trick to removing the clock back cover? I'd like to check the fuse and oil it to try to get it working again.
tstracy39
tstracy39 is offline
PostPosted: Sun Nov 04, 2012 5:58 pm    Post subject: Reply with quote
Use a pair of vise grips to crush the blue anti tamper cover that's over one of the three nuts on the back of the plastic housing, tear it off, then unscrew the three nuts and the cover just lifts off directly. The mechanism looks identical to that of a 1967 to 1971 (12 Volt) Karmann Ghia clock, and having taken apart about a dozen of those I would bet that you can remove the 12 Volt solenoid and breaker points from a Ghia clock and swap them onto the Splitbus clock mechanism. That's assuming you can find a working Ghia clock (they are almost always broken). I have never gotten my hands on a deluxe splitbus clock due to the price being so prohibitive, so I'm unable to try this out myself.
Check my classifieds for kewl gauges:
http://www.thesamba.com/vw/classifieds/search.php?username=tstracy39
I like your fork.
Shaun Murray
PostPosted: Mon Nov 05, 2012 7:58 am    Post subject: Reply with quote
Thanks, I didn't want to mess with that blue retainer, was afraid I'd break something that I couldn't replace. Once I removed it and found that last nut the back slid right off. I gave the gears a little shot of WD-40, rolled the winder wheel manually with my thumb and it started working! Hooked up power and it winds by itself and works great. Thanks again.
I'm gonna send you a PM.
tstracy39
PostPosted: Mon Nov 05, 2012 1:12 pm    Post subject: Reply with quote
Don't use WD-40, it's hygroscopic (attracts water) and in the long run will cause the steel components to rust. Use 3-in-1 oil. They will have it in the tools section at Lowes.
I like your fork.
quartermilecamel
quartermilecamel is offline
PostPosted: Mon Nov 05, 2012 1:32 pm    Post subject: Reply with quote
If wd40 attracts water then how come it displaces moisture. Spraying it on a carbon trace on a coil stopped the arching.
Waiting for santa to drop off funky green. I can wish can't I????
tstracy39
PostPosted: Mon Nov 05, 2012 11:27 pm    Post subject: Reply with quote
Here we go again. So I did a bit of research and it turns out WD-40 isn't in fact hygroscopic however it doesn't directly displace water it just breaks the surface tension/adhesion quality of water so it can move off of the object easily. The problem with using WD-40 on a clock mechanism is that it evaporates relatively rapidly, neccessitating frequent re-lubing. If it's used on something like a firearm that's regularly cleaned about twice a week it works well at preventing rust, but on something that's going to be sealed up for years at a time it doesn't provide any long-term lubrication or rust preventative properties and it will dissolve any oil that does have such properties that would have been previously applied to a clock mechanism. About two years ago I fixed up a half dozen seized up Karmann Ghia clocks before a swap meet. I used 3 in 1 oil. None of the clocks sold, and shortly thereafter I boxed them up and I didn't unpack them until two years later, which was about a month ago. All the clocks still work. If anyone has achieved similar results using a different product please feel free to elaborate on it here.
I like your fork.
Jack Frisch
Jack Frisch is offline
PostPosted: Fri Jul 25, 2014 11:01 am    Post subject: Reply with quote
Who is the repairing these clocks these days?
I need my repaired
Jack
1958 Beetle orig. 6 volt 36 hp engine, body & pan, Black w/red/off white inter., Orig. VW wood roof rack and orig. rear luggage rack.
1967 13 Window Walk-thru Deluxe Bus, stock 1500 engine, Titan Red/Grey, Platinum Mesh interior, orig. & stock
1966 GT350H Shelby Orig. low mileage car
2002 PT Cruiser Limited Edition, stock, auto, loaded
View user's profile Send private message Send e-mail Visit poster's website AIM Address Facebook Gallery Classifieds Feedback
James Dwan
James Dwan is offline
PostPosted: Fri Jul 25, 2014 12:14 pm    Post subject: Reply with quote
I had mine done by Orange Empire Speedometer. It looks fantastic. The guy is a bit lax in the communication dept. and this caused a great deal of consternation but the work is excellent.
DAC
TCB
'59 23 Window Deluxe
'73/'77 Westfakia
'78 SuperVert
"Many dreams come true, and some have silver linings.
I live for my dreams and a pocket full of gold. Acapulco gold!" Robert Plant
Jack Frisch
PostPosted: Fri Jul 25, 2014 12:34 pm    Post subject: Reply with quote
Thanks James!!!
PostPosted: Fri Jul 25, 2014 5:53 pm    Post subject: Reply with quote
I have seen people mention Susan as well.
I have seen her selling redone clocks in the past:
http://www.thesamba.com/vw/classifieds/search.php?username=Patrick
Check their feedback for clock feedback
Jack Frisch
PostPosted: Fri Jul 25, 2014 7:39 pm    Post subject: Reply with quote
Susan no longer restores the clocks
