Joined: January 07, 2008 Posts: 1367 Location: Anaheim, California
Posted: Mon May 25, 2009 10:07 am Post subject:
Wow Pickle
I just read through your whole build thread, and thats just amazing. You got that bus to SHINE!
I don't think I would have the patience to do something like that with my bus. I am using it next year as an auto body project at my high school, so I will be doing a complete restoration on my bus. I will be painting it completely over, but stripping off all the paint before. Not like everybody else in auto body (scuff up the paint and get crazy with the spray gun).
Posted: Mon May 25, 2009 10:13 am Post subject:
Oh and I forgot to ask, does anyone know how to get one of those locking gas caps open? I'm asking because the PO lost her key to the gas tank, but she locked it before parking to make sure nobody stole gas. So now I'm stuck with a locked gas cap, and the gas gauge doesn't work.
I don't want to hire a locksmith, and I don't really want to drill out the lock. Is there an easier way or will I have to use power tools? _________________ 1978 Transporter, 2.0L FI
Joined: February 24, 2008 Posts: 935 Location: Gonzales, LA
Posted: Mon May 25, 2009 6:32 pm Post subject:
I know one way (don't ask me why), but it's not fun and it can get ugly...AND it will reduce your trust in them.
1) Take a heavy-duty straight-edge screwdriver
2) place where key goes (needs to fit in at least a little)
3) give it a single sharp blow with a nylon mallet
4) watch cheap locking mechanism literally bust right through the bottom of the cap
You may end up with a few peices down in the tank, so I wouldn't suggest this to someone who just resto'd their tank, but you probably will need to remove and rework your tank anyway.
Like I said, it ain't pretty, but it's cheap and quick. _________________ "Aircooled VWs are like roaches in that if you let one in, they'll soon be nesting all around you in great numbers."
1966 Volvo 120 Amazon "Shaky"
1974 Orange Bus aka "Kombia"
2012 White CC Sport aka "Nim"
2013 Verde Chiaro Green Fiat aka "Fifi"
Joined: July 01, 2007 Posts: 179 Location: Western PA
Posted: Mon May 25, 2009 7:24 pm Post subject:
The screwdriver and mallet method get used often apparently... I found the locking gas cap in my tank.
Also, the slot for the gas cap is now a little bent out of shape and barely holds the replacement gas cap. Would it be possible to accomplish the same thing with something like the 'screw in dent puller'? (screw into key slot and slide tap the lock mechanism out). I don't need to worry about that now, my gas tank had to be replaced because of pin-hole leaks. The filter sock was also broken and I suspect the gas cap lock was responsible for both problems. _________________ Endeavor to persevere.
'72 Westy "Weekender"
Joined: January 14, 2006 Posts: 940 Location: Colorado
Posted: Mon May 25, 2009 9:01 pm Post subject:
Nice find!!! Keep up the good work and welcome to the samba! _________________ '71 Westy
'71 Deluxe - My sons bus
'66 Freedom Camper - Sold
"Love. You can learn all the math in the 'verse... but you take a bus on the road that you don't love... she'll shake you off just as sure as the turn of the worlds. Love keeps her on the road when she ought to fall down... tells you she's hurtin' 'fore she keens. Makes her a home." - Mal
Posted: Thu May 28, 2009 7:27 pm Post subject:
Thanks guys! I just got 2 packages in the mail today, one was two matching tail lights from BUSBOSS, and one was the part I need for my door from mackmix. Thanks guys! I'll put it all together this weekend _________________ 1978 Transporter, 2.0L FI
She starts and runs, but she can't hold an idle. Can anyone help me out with getting her running right? I really want to get my bus registered and smogged.
I didn't actually do anything but borrow and put a new battery in there!
Also, we couldn't put the door on because we couldn't figure out how to take the panel off...could anyone in my area help me out?
Thanks, Max. _________________ 1978 Transporter, 2.0L FI
Posted: Sat May 30, 2009 5:01 pm Post subject:
Oh and I've got tons of blue-ish white smoke from the exhaust. What does that mean? Am I burning oil?
It doesn't look like oil burning...because in like every other car I've ever driven (that's burned oil) the smoke was really blue. I'm not sure, because they were all water cooled. _________________ 1978 Transporter, 2.0L FI
To get that cover off, all you have to do is unscrew it and then tap it up and off. I used a 2x4 as a buffer along the lip, but some people recommend inserting a thin piece of wood into the opening and hitting it so the force is directed to the inside top of the cover ... that's probably a good idea, it just occurred to me that maybe that's why mine is hitting the hinge now _________________ The musings of a wanderer ... who is not wandering, but instead restoring a VW bus:
http://cameronguthrie.blogspot.com
Posted: Sat May 30, 2009 6:16 pm Post subject:
2 quick questions...would valve problems make the bus burn oil or make smoke, and could the no idle problem I have maybe be a plugged fuel filter? It runs if I keep my foot down, but as soon as I let off it just sputters and stalls.
Posted: Sat May 30, 2009 9:15 pm Post subject:
As soon as it starts it just starts to die. There is no steady idle at all. Plus I don't have a tacho. It idled at a normal idle speed (about 800) for 10 seconds the first time I started her up, then she died.
I think what happened was a bunch of crud got sucked into the fuel filter, and I just need to drain clean and reseal the tank.
Also, would valve problems make the car smoke a lot? _________________ 1978 Transporter, 2.0L FI
Joined: February 12, 2004 Posts: 23899 Location: Surrey B.C. Canada, Land of the giant flying moose!
Posted: Sun May 31, 2009 7:19 pm Post subject:
What color smoke? Sounds like a float level issue but unless you put your bus and engine combo in your sig line I'm not going back 3 pages to discover it, possibly others are as lazy as me, food for thought _________________ Rust NEVER sleeps and stock never goes out of style.
Wanted, 68-73 westy OG plaid curtains, singles OK.
All times are Mountain Standard Time/Pacific Daylight Savings Time Goto page Previous1, 2, 3, 4 ... 14, 15, 16Next
Page 3 of 16
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
