Yellow Van Samba Member
Joined: December 23, 2008 Posts: 163 Location: San Jose, CA
Posted: Sat May 30, 2009 10:13 pm Post subject: |
Ah memories! I purchased an 81 aircooled Vanagon last year and had some of the same vacuum lines unplugged. Vacuum leaks are very bad for the air cooled engine so make sure you get them all. You should also change your fuel lines unless you like engine BBQ's. Mine looked great on the outside but were quite cracked on the inside layer. Also you should probably replace the the fuel injector gaskets. Mine were in terrible shape but you can't tell unless you pull the injectors off. Good luck! |
Themasterof42 Samba Member
Posted: Sun May 31, 2009 12:14 pm Post subject: |
New fuel lines are one the way!
But fuel injector gaskets? How can I tell if mine aren't in good shape? |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Sun May 31, 2009 2:35 pm Post subject: |
Yes..thems the ones. Each injector gets a large one and a small one hence the reason for eight of them |
Posted: Mon Jun 01, 2009 9:02 am Post subject: |
Yes. The large ones actually just hold the injector in place and smaller ones seal the inner nozzle area from the outside air. While your injectors are out, you may want to send them for a professional cleaning to a place like WitchHunter Performance. I sent mine in and 3 out of 4 of my injectors were in such good shape that cleaning was not really needed, but the 4th was found to be broken and leaking. They use their own seals so you won't need to buy them separately if you decide to get them cleaned. |
Posted: Mon Jun 01, 2009 10:03 am Post subject: |
how much does that typically cost? I see on bus depot they have some you can just buy for like 35$ each plus core charge. Would it be more worthwhile to just get the re manufactured ones (I'm guessing not since they probably are a different brand or something and not as good) |
reluctantartist Samba Member
Joined: August 13, 2006 Posts: 1927 Location: Bloomington, IN
Posted: Mon Jun 01, 2009 10:07 am Post subject: |
It is typically $16-18 per injector plus shipping. I think I spent close to $80 total for mine this past January. _________________ 1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them. |
Randy in Maine Samba Member
Posted: Mon Jun 01, 2009 11:38 am Post subject: |
Another similar option is www.cruzinpermance.com They give you a nice "before" and "after" testing report.
About the same price to have it done and they come back with new injecotor seals and hoses.
Money well spent. |
Posted: Tue Jun 02, 2009 8:46 pm Post subject: |
My fuel line replacement kit just showed up from van-cafe! Seems it comes with the fuel injector seals!
Does anyone have any advice on changing these lines. I know I have two different sizes of hose (one shorter wider hose and one really lone hose) Where am I supposed to use the fatty hose? Anyone have any pictures or anything? I'm waiting for my bus depot order to arrive before I really change anything out (getting new filters and stuff)
(kit I bought - http://www.van-cafe.com/home/van/page_499_1323/fuel_line_replacement_kit.html) |
jimeg Samba Member
Posted: Sun Aug 07, 2011 9:52 am Post subject: PCV valve |
I've been working on the vacuum leaks on my 82 AC Westy - and I'm now checking out the PCV valve. There are no emissions testing in my county.
PCV valve
Is it necessary for the diaphragm to function?
How do I check it?
Should the o ring seal into the crankcase pipe be air tight? It is currently very loose - worn o ring I'm assuming.
In this thread reluctanartist sealed the port in the top of the valve - because he said the diaphragm had failed. Should I do this if it is the case mine is bad?
Thanks |
Posted: Mon Aug 08, 2011 12:44 pm Post subject: |
I ended up cutting mine open and repairing the diaphragm. I also put on a new o-ring so it would seal better. I used silicone to seal it back up and a spring clip I made out of a table cloth clip.
