Rear Wheel Tilt
Turtle75
Turtle75 is offline
PostPosted: Sun May 24, 2009 6:54 am    Post subject: Rear Wheel Tilt Reply with quote
Ok, maybe I'm too new to understand, but why put the angle in the rear wheels? Doesn't it just distract from an overall good looking VW? I've been looking through some threads, and I see a lot of really sweet beetles/busses with the tilt thing going on. Every time I see it though, I can't help but think it looks a bit.. goofy? No offense meant.
Can anyone explain this trend to me?
MAYHEM
MAYHEM is offline
PostPosted: Sun May 24, 2009 7:07 am    Post subject: Reply with quote
With a swingaxle rear, when the rear is lowered the tops of the wheels tilt inward. If it is raised, they tilt outward.
Greg
Model Citizen
johnnypan wrote:
I digitize myself in the privacy of my own home.
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Sun May 24, 2009 10:52 am    Post subject: Reply with quote
and it's called 'camber' ..... not 'tilt'...
póg mo thóin
Certified DHS Technician
Samba Member # 24517
Turtle75
Turtle75 is offline
PostPosted: Sun May 24, 2009 11:44 am    Post subject: Reply with quote
Ok. 'Camber'. How do you use that in a sentence? Like, "Oh, I see your rear wheels are cambered?" or "Sweet camber going on back there." ? Confused
MAYHEM
MAYHEM is offline
PostPosted: Sun May 24, 2009 11:47 am    Post subject: Reply with quote
Correct.
Greg
Model Citizen
MLTIGGER2
MLTIGGER2 is offline
PostPosted: Sun May 24, 2009 12:10 pm    Post subject: Reply with quote
From what I understand VW designed the cars with camber so that more of the tire would be on the road. The roads in Germany were crowned pretty severe, maybe so water would run off them better(that is my guess)
When you raise or lower them it just makes the camber worse, but from the factory they had a fair amount of camber
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun May 24, 2009 3:12 pm    Post subject: Reply with quote
No, they did not.
Look at the rear wheel alignment specs on a swing axle car.
Gary: OK. Ima poop.
jmsmilin
Samba's Most Posted
jmsmilin is offline
PostPosted: Sun May 24, 2009 8:28 pm    Post subject: Re: Rear Wheel Tilt Reply with quote
and those with slammed rides do this everytime someone doesnt get it... Rolling Eyes
hell even Jada toys got it right
Der Schmutzige Süden.
(o\ ! /o) | o \/ o | (o)=|=(o) [o\|_|_|/o] \m/
Michael Fischer
Michael Fischer is offline
PostPosted: Mon May 25, 2009 3:04 am    Post subject: Reply with quote
Everyday I have to explain to some dumbass why me wheels are cambered. Rolling Eyes
Hobbes
Hobbes is offline
PostPosted: Tue May 26, 2009 1:58 am    Post subject: Reply with quote
Russ Wolfe wrote:
No, they did not.
Well, according to specs they didn't have much, but I've seen quite a few 'stock' bugs rolling around that have either positive or negative camber. I see a few with positive when there's nobody in the car. Maybe just the lightness from rust holes or something, I don't know.
Either way, Some camber looks sporty, but when you lower a car too much and the camber gets extreme, it's not only really funky looking, but it eats through tires and drums like crazy. Back before I did the trans lift on my car, I would have to get new tires every two months.
«•Lie Down... Good Bug•»
Desertbusman
Desertbusman is offline
PostPosted: Tue May 26, 2009 5:14 pm    Post subject: Reply with quote
Turtle-
Just do a bit of research and learn what an IRS (independant rear suspension) trans is and what a swing axle trans is and how they function. '68 and later has the IRS. With swing axle if you raise or lower the rear the wheels will tilt either out or in. Either way it's bad for the tires and wheels. But if it's more important for someone to have it either raised or lowered than to have proper wheel stance then thats the price to pay. Stock height? Yea, sure. 40 years of wear and tear on the suspension or a fat mother in law in the back seat isn't going to result in stock height.
The best thing that anyone can do for their Bay is get the Volkswagen of America Official Service Manual published by Robert Bentley. Without it the bus is pretty much doomed.
73kombi wrote:
when that red light goes on, you have to make a choice.
Amskeptic wrote:
I am not answering that.
Respectfully,
GoBuyABentley
71 Superbug
71 Westy
Russ Wolfe
PostPosted: Tue May 26, 2009 7:31 pm    Post subject: Reply with quote
Hobbes wrote:
Russ Wolfe wrote:
No, they did not.
Most of what you see on todays stock cars is sag in the rear torsion bars. Cambered the other way, is probably torsion bars set wrong, or someone with coil over, or air shocks.
Gary: OK. Ima poop.
Hobbes
Hobbes is offline
PostPosted: Tue May 26, 2009 8:25 pm    Post subject: Reply with quote
The ones I've seen are probably set wrong, then, given they were old junky bugs that didn't seem to have ANY extra work done to the suspension in terms of coilovers or the like.
Either way, Positive sucks because it's not only bad, it makes the car look goofy.
Bashr52
Bashr52 is offline
PostPosted: Wed May 27, 2009 4:24 pm    Post subject: Reply with quote
Like having your ties bow in so far the rub the body is any better Rolling Eyes
Hobbes
Hobbes is offline
PostPosted: Wed May 27, 2009 9:17 pm    Post subject: Reply with quote
Well no, I mean milder settings. A little positive looks 'right', a little negative looks unnatural and weird, like a cartoon car or something. Especially with skinny tires. Just god-awful.
iVolkswagen
The Modern-Day Hippie
iVolkswagen is offline
PostPosted: Mon Jun 08, 2009 4:28 pm    Post subject: Reply with quote
Well, my right-rear tire blew today, and it reminded me of this topic, haha.
Negative camber causes:
Ran them (daily driven) since December, last year.
TJ
\/OLKSWAGEN
- 1963 Beetle - 1987 Cabriolet
Endicott jb
Bondo King
Endicott jb is offline
PostPosted: Mon Jun 08, 2009 4:36 pm    Post subject: Reply with quote
Desertbusman, The 68 had swing axle unless it was an Autostick. Then it would be an IRS.
Josh
OORAH!!
1965 vw beetle(Mayble)
1968 vw beetle(Caroline)
1974 VW Panel Bus
2003 Dodge 2500 5.9 Cummins(Katey)
.|_____|.
(0\_!_/0)
Don't drink and post
http://i540.photobucket.com/albums/gg353/endicott_jb/IMG_20110113_085237.jpg
When life throws you curveballs switch to boomerangs.
