Claude's Buggies Intake with Carbs worth anything?
Forum Index -> Performance / Engines / Transmissions Share: Facebook Twitter
Kustom41
Kustom41 is offline
PostPosted: Wed May 27, 2009 8:38 am    Post subject: Claude's Buggies Intake with Carbs worth anything? Reply with quote
Trying to decide what I am going to do with this dual carb set up intakes and don't know if or what it's worth it has Weber carbs on it now.
Thanks for the help
busman78
busman78 is offline
PostPosted: Wed May 27, 2009 9:05 am    Post subject: Reply with quote
Wow, I have a set that looks just like that except with T4 intakes, what is the Weber model number on the carbs?
Kustom41
Kustom41 is offline
PostPosted: Wed May 27, 2009 9:10 am    Post subject: Reply with quote
Not sure but I will look tonight for you.
sactojesse
sactojesse is offline
PostPosted: Wed May 27, 2009 9:22 am    Post subject: Reply with quote
Judging from the way the manifold base is turned 90 degrees, those are plenum manifolds with some form of Weber progressive carbs. A synchronous throttle two-barrel with a square base, such as a Zenith NDIX or Weber DCN/DCNF, would have one barrel in line with each intake port, rather than having both barrels dump into a plenum shared between the ports.
1966 Karmann-Ghia convertible
Matthew
Matthew is offline
PostPosted: Wed May 27, 2009 4:35 pm    Post subject: Reply with quote
Those are the infamous dual progressive Weber kit that were sold in the early 80's by Claudes Buggies (CB Perf). I worked on an engine in a buggy with this setup on it in the mid 90's and there were no parts available for those carburetors.
I called Weber / Redline and they laughed and said to call CB. I called CB and they had nothing. I ended up using accelerator pump diaphrams for the DFAV series progressive weber and making my own gaskets for the top of the carbs (tedious). When all was finished I syncronized them by ear because the syncrometer won't fit on top of those carbs. After some tinkering, it actually ran very well.
I'd say they are worth little to nothing due to unavailability of service parts.
1965 Beetle sedan
Click to view image
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Wed May 27, 2009 4:43 pm    Post subject: Reply with quote
Bingo!... these come up from time to time in a thread...mostly about the type 4 application for what ever reason. They were smaller "baby progressives" no doubt some old Euro Stock when the most went to FI by the mid 80's they had to do some thing with them.
my seller feedback
rebuilt carb info = for sale
"STFU Polly and go eat a cracker!" 12-21-2012.... can't wait!
sturgeongeneral
sturgeongeneral is offline
PostPosted: Wed May 27, 2009 5:33 pm    Post subject: Reply with quote
I remember them buggers! I would think some of us old school guys would want them for the old school appearance. They actually ran pretty well. As Matthew said, parts are a challenge, but doable. Build 'em now and you will not have to worry about them for a long time. I am into the unusual myself so for old school affect and uniqueness, If I had 'em I would run 'em.
Street legal fiberglass rocket ship
2005 Lotus Elise supercharged
1974 Chevy Corvette
My fiberglass car collection!
In honor of bowtie56jw:Another victim of the nasty "C" Praying for ya Jeff!
My exwife said if I towed home one more bug she would leave me. You know, every once in a while I miss her
FarmerJohn
FarmerJohn is offline
PostPosted: Wed May 27, 2009 6:51 pm    Post subject: Reply with quote
I'm running them on a 1600 type 3 motor in my buggy although no fittings on mine for ballance tube
Linkage was tricky to set up, luckily I had a center pivot from an old type 3 carb motor that I was able to modify
Real happy with the way they run no dead spots and can count the pistons firing , it idles so low
mine have 24 24 cast on the bodies ,through research found out they are webber 30DIC carbs originaly from a fiat 750 & yes tough to get parts for
If you're lookin to get rid of them I might be interested
keifernet
PostPosted: Thu May 28, 2009 11:55 am    Post subject: Reply with quote
Is the spacing on those manifolds the same, could you run 32/36 progressives in their place? I thought I had seen that answered before but could not find it.
my seller feedback
rayjay
rayjay is offline
PostPosted: Thu May 28, 2009 3:19 pm    Post subject: Reply with quote
If they are actually from a Fiat application then it was probably an 850 coupe or spyder. I bet the Fiat specialists will have the rebuild kits. I would run them for sure.
titus116
titus116 is offline
PostPosted: Tue Jun 23, 2009 5:55 pm    Post subject: Reply with quote
Would those fit the 32/36 weber? The carbs in the pic look smaller.
Reply to topic    Forum Index -> Performance / Engines / Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
