What is this ENGINE?
vwracernnc
vwracernnc is offline
PostPosted: Sat Jun 06, 2009 9:51 am    Post subject: What is this ENGINE? Reply with quote
I run across this old block and was wondering if someone knew what is is?
I am thinking it is a reman case?
Under the Altenator stand was a pop rivited tag:
5545 AD-462761
Under the tag was stamped:
B 216671 X
On the Sump plate was Stamped:
043 101 102A
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Sat Jun 06, 2009 11:22 am    Post subject: Reply with quote
Yep, remanufactured, and more than once!!
That engine was rebuilt by Vege Motoren in the Netherlands, imported and marketed in the USA by ATK engines.
That previous engine number, that X on the end means that one was remanufactured by VW at some point before Vege reman'd it again.
Vege usually builds good stock engines, we sold a few of them to customers when I was a mechanic. Looks like ATK only sells dual ports now though. They used to do more than that.
I don't know why they rivet on a new tag, but they do. I've never taken one of those tags off before. But I bet yours looked like this one:
When we sold them, they came in boxes that looked like this:
1975 street rail
1975 street rail is offline
PostPosted: Mon Jun 22, 2009 8:56 pm    Post subject: Reply with quote
I just bought one of these engines PN # 5545 AD- 454643. It was in a 75 standard FI beetle that someone had converted to a carbed engine. It was complete except for the carb, distributor and some tin. It spins over free with no rough spots. (Sat for a long time!) It looks as if the head on the drivers side was replaced at some point in time as it is cleaner and the pushrod tubes show less rust than the passenger side. One thing I noticed is the head on the driver side has a small round port (About 1/2 inch in diameter) sticking straight upward. It is located toward the flywheel side of the engine. The PO cut a notch in the engine tin to accomodate this port. Does anyone know what it is for? I have several 1600 DP engines and this is the only one that has this port.
I picked this engine up for $65.00 to stick in my rail with the hope that it will run out OK with a litle bit of work Confused . I wish I knew more about the case. It looks like it has the case savers installed. I assume it is an AD case from 71-72 model year based on the #454643??? Can anyone out there shead any more light on this ?
Thanks a bunch
Jim
neil92064
neil92064 is offline
PostPosted: Tue Jun 23, 2009 8:44 am    Post subject: Reply with quote
RE - head on the driver side has a small round port (About 1/2 inch in diameter) sticking straight upward.
Connection for a 1/2 ID tube - goes to a collector box to vent fumes - or back into air cleaner - [/img]
72 914. 1911cc, 2 x 40IDF's, Viper Blue
81 928
98 Land Rover Discovery ( 914 recovery vehicle!)
06 Range Rover - to recover any of the above 3!
1975 street rail
PostPosted: Tue Jun 23, 2009 10:27 am    Post subject: Reply with quote
Thanks! Do you know what years used this set up? I'm trying to get an idea what year model the head is aproximately.
Thanks again,
Jim
The Android
PostPosted: Tue Jun 23, 2009 10:43 am    Post subject: Reply with quote
If you search for "Vege" or "ATK" you'll find others here who have had these, some of them popped off that riveted on tag, only to find the number underneath not to match at all. So assuming its an AD case, hard one to call that is. I'd go by other indications - you said case savers, is it 10mm studs? (8mm studs came with case savers factory) Dual relief? Beyond that, you'd have to base rebuild decisions on what is inside the case (flat or dished cam, bearing sizes, stuff like that)
That head, I've seen type 4 heads with a vent on top but I'm trying to remember if I've seen any type 1s. What's the part/casting number inside the rocker chamber on that one?
neil92064
PostPosted: Tue Jun 23, 2009 3:42 pm    Post subject: Reply with quote
Earlier Type 4 heads ( I have a 72 - 914) had that on both sides - not sure when they stopped it though -
81 928
Endicott jb
Bondo King
Endicott jb is offline
PostPosted: Tue Jun 23, 2009 6:54 pm    Post subject: Reply with quote
I had a 75 type 1 that had this small port. It was for a head temp sender though. Not a vent tube.
Josh
OORAH!!
1965 vw beetle(Mayble)
1968 vw beetle(Caroline)
1974 VW Panel Bus
2003 Dodge 2500 5.9 Cummins(Katey)
.|_____|.
(0\_!_/0)
Don't drink and post
http://i540.photobucket.com/albums/gg353/endicott_jb/IMG_20110113_085237.jpg
When life throws you curveballs switch to boomerangs.
