ccdirtyone Samba Member
Posted: Sat Nov 20, 2010 1:39 pm Post subject: 1969 Turn signals don't work |
Well I am looking for some help, how many hot wires go to the turn signal? I am trying to get my baja turn signals to work. The emergency flashers work but not the turn.
Please help! ccdirtyone |
kjvforme Samba Member
Joined: September 11, 2009 Posts: 222 Location: Oregon
Posted: Sat Nov 20, 2010 1:53 pm Post subject: |
Should be one and it's black with white and green stripe going to terminal 54BL on the directional switch. You say your relay is clicking when in emergency? I would make sure the wire coming off of the relay, the 49a terminal is hooked up, should have a cable adapter below it and a blue wire that goes to the same terminal. Double check fuse 2 and fuse 9 to make sure they'are still good.
If you need help locally try joining and contacting these guys in your area for assistance. http://www.mcvw.org/ |
Posted: Sat Nov 20, 2010 3:39 pm Post subject: |
Thanks for the info. I will try to search the wires a little more. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Sat Nov 20, 2010 10:55 pm Post subject: |
The emergency flasher relay setup in 1969 would choose between two different power sources, one for flashers and one for turn signals. Turn signals only get power with the ignition key on, that's the black wire going to from the first fuse on the left over to terminal 15 on the flasher switch. Terminal 30 on the switch gets its power from fuse 9.
I'd check and make sure that when your e-flasher switch is "off" that it's connecting terminal "+" (49) over to terminal 15.
Since VW never issued a proper wiring diagram after mid 68 when they changed the flasher relay, a while back I combined/redrew a couple of other diagrams into the one found here:
http://www.thesamba.com/vw/archives/info/wiring/bug_68_69_usa.jpg
Hope that helps some!
-Andy |
Posted: Sun Nov 21, 2010 11:01 am Post subject: |
Thanks guys for the help . I hate wiring!
I started tracing wires and now the damn thing wouldn't start. so back to square one. Do you guy know of a good place to get a whole new wiring harness for the 69'-70' years.
Please bare with me everyone this is not my first vw but it is so jacked up from the PO that it is hard to find a starting point. |
Posted: Sun Nov 21, 2010 11:57 am Post subject: try again sorry |
[/img] |
Posted: Sun Nov 21, 2010 3:01 pm Post subject: |
Ugh - well that's certainly not the VW flasher relay. And lots of changes to the wiring. Hard to say what all is right and what is wrong in there. |
