Clutch cable problem.....
jttosh
jttosh is offline
PostPosted: Fri Jun 05, 2009 1:28 pm    Post subject: Clutch cable problem..... Reply with quote
Just had to change my clutch cable and i put the new one on and i tightened that wing nut by the transmission as far as it would go and i still have no pedal, its on the floor. The last cable i only tightend it half way. What am i doing wrong? Where i put the clutch clevis/pin in is it possible i did something wrong there? I have tried twice to see what i am doing wrong but cant figure it out. Thanks
71 Campmobile
"listening for the secret,searching for the sound"
VDubTech
VDubTech is offline
PostPosted: Fri Jun 05, 2009 1:29 pm    Post subject: Reply with quote
Did you compare the length of the new cable and the old one?
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
jttosh
jttosh is offline
PostPosted: Fri Jun 05, 2009 2:48 pm    Post subject: Reply with quote
It was longer than the old one, are there different lengths for 68-71 72-79? I put an old one on that is holding on by 3 wires and it fits fine. Think it will hold till i have one shipped? Also the clutch engages to quick should i loosen or tighten?
71 Campmobile
busdaddy
busdaddy is offline
PostPosted: Fri Jun 05, 2009 3:01 pm    Post subject: Reply with quote
Tighten, yes there are different cables, 68-mid 72 and 73+.
Wanted, 68-73 westy OG plaid curtains, singles OK.
jttosh
jttosh is offline
PostPosted: Fri Jun 05, 2009 3:04 pm    Post subject: Reply with quote
Thanks
71 Campmobile
fstbckgt
fstbckgt is offline
PostPosted: Fri Jun 05, 2009 7:57 pm    Post subject: Reply with quote
could a improperly adjusted clutch cable cause grinding? my bus is fine at first but after warming up she starts grinding when shifting into 2nd and 3rd,
1973 Deluxe Transporter Sunroof
TOP GEAR ftw
busdaddy
busdaddy is offline
PostPosted: Fri Jun 05, 2009 8:04 pm    Post subject: Reply with quote
Plausible, but worn synchros, a warped disc or a siezing pilot bearing are far more likely, a few turns tighter on the wingnut will answer your question.
SGKent
SGKent is offline
PostPosted: Fri Jun 05, 2009 9:07 pm    Post subject: Reply with quote
Is that before or after this cable was installed? 3 wires won't cut it, they are stretching.
Steve aka Merlin the Wrench
formerly Steve's Racing and Engine Blueprinting. Wrenching since 1967.
bdamico on GF wrote
"When I was your age I'd plan out all sorts of stuff for the future and almost none of them came true. Just wonder if it's worth trying to be a crystal ball. "
fstbckgt
fstbckgt is offline
PostPosted: Sun Jun 07, 2009 1:40 am    Post subject: Reply with quote
thanks, ill put this on my list of things to do
TOP GEAR ftw
