neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Mon Oct 28, 2013 5:23 pm Post subject: EMPI disc brakes |
I'm just starting on the EMPI four-wheel disc installation, and found this thread. Some good tips, for sure.
I also searched on youtube and located a video from EMPI that provides some tips:
http://www.youtube.com/watch?v=2rustBbto50
I'll post my updates in the Late Beetle forum, as mine will be a 4-bolt installation, although I do have '66-and earlier short axles. _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
StevieC Samba Member
Joined: January 01, 2014 Posts: 412 Location: Anza Borrego
Posted: Fri Apr 11, 2014 7:43 pm Post subject: |
are the spindles/calipers the same on the 5 lug and 4 lug versions
I have 4 lug and I'd like to swap out the 4 lug rotors for 5 wide rotors, would that work? |
67Cabrio Samba Member
Joined: March 30, 2014 Posts: 31 Location: Everett, Wa
Posted: Sat Aug 16, 2014 10:09 pm Post subject: |
Just assembled a EMPI wide 5 front disc kit, with drop spindles. Ordered them from Carters Aircooled a few months ago, and everything went together perfectly. Don't remember the measurements, but in my kit the interference on the bearings races and bores were perfect. Just have to figure out how the speedometer cable thing is going to work, otherwise quite happy on the fit, finish, and overall product. Have yet to install on the car however. |
steve n Samba Member
Joined: August 17, 2005 Posts: 141 Location: Petaluma, California
Posted: Sun Aug 17, 2014 5:09 am Post subject: Disc Brakes |
I have CB performance on the front of my 64 Bug, drums still on the rear. I am very happy with the set up. Stops on a dime, ok, a nickel. If I were to do brakes again "Airkewled" has the "Bad-Ass Brakes" and they seem to be...Bad Ass. If I ever leave the drum set up on my 61 it would be Airkewled. |
pilotricky Samba Member
Posted: Mon Sep 01, 2014 8:03 am Post subject: |
Here is a problem with my EMPI rear disc brakes. I have the four hole rotors at all four wheels. I am now in the process of putting in all the brake lines...all went well until I get to the lines to the rear calipers. The threaded hole for the brake line in the rear calipers is the wrong thread! It is a coarse thread...all the other lines, and front calipers is the same as stock VW. I cannot connect the brake line to the rear calipers because of the thread difference, (too coarse of thread). I don't know why it would be different? Now what? Any ideas od his? Adapter? Custom line? or? Thanks. |
dcarlson12 Samba Member
Joined: May 04, 2014 Posts: 71 Location: Surrey, BC, Canada
Posted: Wed Jul 06, 2016 12:59 pm Post subject: Re: EMPI VS. CB Disc Brake Conversion Kits |
Sorry no answer for pilotricky.
What ever happened to Motomazzo?
Also, I see AC offers this kit:
http://www.socalautoparts.com/product_info.php/ind...05-p-13591
This would suit my wife's 66 Bug.
My concern is that it doesn't use a dual circuit master cylinder.
I thought it is necessary/best to use a dual circuit and have a residual pressure valve on the rear drum brake circuit. i.e this applies regardless of what brand of disk (or is it disc?) brakes one uses on the front when keeping the original drums on the rear.
Thks,
Dwight _________________ The 'caretaker' of my wife's 66 bug; her dream car. |
Dogend Samba Member
Posted: Mon Oct 09, 2017 1:34 pm Post subject: Re: EMPI VS. CB Disc Brake Conversion Kits |
FYI
The EMPI disc brake conversion (four wheels) - with Parking Brake for my type-1 VW, weighs 68 lbs more then the stock drum set up. |
Onceler Samba Member
Posted: Sat Oct 28, 2017 9:15 pm Post subject: Re: EMPI VS. CB Disc Brake Conversion Kits |
Just finished installing my empi disc brakes on all 4 wheels from carcraft. Nothing out of the ordinary just the simple tweaks as mentioned. So far I'm pleased, but won't be on the road for several months. _________________ 1972 Karmann Ghia |
Flat4BRM Samba Member
Joined: February 26, 2018 Posts: 22 Location: California
Posted: Sun Sep 22, 2019 2:29 pm Post subject: Re: EMPI VS. CB Disc Brake Conversion Kits |
Interesting thread...albeit an old thread (hopefully someone out there can help)...
I'm considering purchasing an EMPI wide-5 front disk brake conversion kit for a '63 Type 1 I've been working on. I have a couple of questions regarding fitment (although they may have been answered / alluded to already):
1) Will my stock VW 15" solid wheels bolt up to the rotors with no caliper clearance problems?
2) I hear of issues with the stock speedometer dust cap not working with the EMPI kit...anyone have an EMPI part # available for this fix?
3) I already installed CB Performance 2.5" dropped spindles (drum brake style)...would the EMPI disk brake kit bolt up to these spindles?
And finally...
4) With the CB dropped spindles and disk brake kit (remember, EMPI claims a "zero-offset"), realistically how much of an increase in track width could I expect from this installation?
Again, hopefully someone out there would read this post and resurrect the thread...any help would be greatly appreciated. _________________ - Most car projects are like stray dogs..you want to keep them all and never let any of them go.
- Built, not bought.
- Street is neat...support your local street rodders!
1966 L41 113 | 1965 L456 151 | 1963 L380 113 | 1954 L227 113 | 1949 L51 11A |
apozzo Samba Member
Posted: Thu May 21, 2020 8:43 am Post subject: Re: EMPI VS. CB Disc Brake Conversion Kits |
Hi Guys....I'm Stefano and I'm from Italy.
Could you help me?.....I'm going crazy with this conversion kit!
I want to ask you a question about the thread of the two calipers mounting holes on the calipers brackets! I've attached a picture to explane which holes I refer to! In my kit there are 4 mounting bolts (same lenght) that are M9x1.25, 13mm outer diameter and 55mm lenght. The problem is that the thread on this bolts has many play in the mounting holes on the brackets and this is not normal !!!! The holes on the caliper brackets seem to be around M10 thread! What do you think about? I could built handmade mounting bolts but I want to undestand what's wrong with my kit !!! Another question......could anyone attach the installation instructions?
Really thank you
Stefano (from italy)
Mdemaria Samba Member
Joined: April 23, 2017 Posts: 11 Location: Hilton Head Island
Posted: Wed Jul 27, 2022 6:16 am Post subject: Re: EMPI VS. CB Disc Brake Conversion Kits |
DO NOT buy from So cal auto. AC industries brake conversion kits are terrible. MAJOR CASTING ISSUES!!!!!!Trust me I learned the hard way!!! |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Wed Jul 27, 2022 8:28 am Post subject: Re: EMPI VS. CB Disc Brake Conversion Kits |
Mdemaria wrote: |
Can you elaborate? Mine are just fine. _________________ If you`re going to do something, do it right. |
toxicavenger70 Samba Member
Posted: Wed Jul 27, 2022 2:27 pm Post subject: Re: EMPI VS. CB Disc Brake Conversion Kits |
Bryan67 wrote: |
Mdemaria wrote: |
Can you elaborate? Mine are just fine. |
Same, mine were fine. To bad when there was an issue their service was not fine. |
alindeman1989 Samba Member
Joined: April 18, 2005 Posts: 657 Location: Newark, Ca
Posted: Wed Jul 27, 2022 2:41 pm Post subject: Re: EMPI VS. CB Disc Brake Conversion Kits |
Mdemaria wrote: |
I would also like elaboration, I was planning on getting their rear wide 5 zero offset kit for my 67 when it comes back in stock. Ive heard nothing but good things about it. _________________ 2180 powered 1974 super( sleeping since 2011)
1967 beetle(new project) |
ZEKE65 Samba Member
Joined: December 16, 2018 Posts: 334 Location: Right Coast, Florida
Posted: Thu Jul 28, 2022 8:04 am Post subject: Re: EMPI VS. CB Disc Brake Conversion Kits |
My AC Industries disc brake kits worked well, except for the fact that I had to install a washer between the rear caliper brackets, and the mounting brackets which replace the drum backing plates. Otherwise the caliper bracket would lightly rub the outside of the rotor. I used a 10.9 alloy washer. _________________ 1965 VW Sedan, 1968 C10 Step BB, 99 C5 |
74 Thing Samba Member
Posted: Thu Jul 28, 2022 8:25 am Post subject: Re: EMPI VS. CB Disc Brake Conversion Kits |
Mdemaria wrote: |
Just look at that persons profile and all of his posts. The majority are that exact same post on multiple threads. |
Posted: Thu Jul 28, 2022 10:15 am Post subject: Re: EMPI VS. CB Disc Brake Conversion Kits |
ZEKE65 wrote: |
My AC Industries disc brake kits worked well, except for the fact that I had to install a washer between the rear caliper brackets, and the mounting brackets which replace the drum backing plates. Otherwise the caliper bracket would lightly rub the outside of the rotor. I used a 10.9 alloy washer. |
Do you have a pic of this? _________________ 2180 powered 1974 super( sleeping since 2011)
ZEKE65 Samba Member
Posted: Thu Jul 28, 2022 12:54 pm Post subject: Re: EMPI VS. CB Disc Brake Conversion Kits |
If you look at this picture, the cadmium colored piece is the caliper bracket. It slides over the edge of the rotor disc, and bolts to the black back plate bracket which replaces the stock backing plate. I had to add a washer where the caliper bracket bolts to the black bracket, which spaced the caliper bracket outward.
Posted: Thu Jul 28, 2022 1:34 pm Post subject: Re: EMPI VS. CB Disc Brake Conversion Kits |
alindeman1989 wrote: |
Mdemaria wrote: |
I would also like elaboration, I was planning on getting their rear wide 5 zero offset kit for my 67 when it comes back in stock. Ive heard nothing but good things about it. |
It is a good kit, but So Cal's service is not that great. I recommend getting the kit from someone else like AA Performance. |
