PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Mon Jun 04, 2012 3:12 pm Post subject: |
crazyvwvanman wrote: |
They sell various ones and the fine print shows the differences. For wbx 90 amp alternators I'm pretty sure you need 28mm, with NO resistor.
http://www.ebay.com/itm/Voltage-Regulator-Bosch-Au...35a363b271
Mark
bserret wrote: |
Is that last listed one workable - (The Drdepner one)? The earlier ebay links don't work. The last one doesn't list a Bosch part number 1-197-311-021 in their table. Just wondering if anyone can verify compatibility.
Thanks,
-Brian |
That's the one. It replaces part number 1 197 311 021. I've been using it since 2009 with no problems.
Bosch 1-192-052-015, -016, -020, -021, -024, -025, -027, -029
1-197-311-004, -005, -006, -010, -011, -012, -013, -021 _________________ 89 Westy 2.1 Auto |
VeeDubDaySpa Samba Member
Joined: February 29, 2008 Posts: 368 Location: Bend, OR
Posted: Sun Sep 28, 2014 9:17 pm Post subject: |
PDX-
I just ordered this as I'm going to be running an AGM house battery- just to clarify, you set your voltage to 14.5 (measured at batteries?) then you drive with the lights and heater on to drop the main battery voltage down to 14.2? That way your AGM is still receiving the higher 14.5 volts?
still working well?
Thanks! _________________ North American Hightop Installer/Distributor
Current stock (5)
Hot Water Systems
90 Syncro NAHT Vanagon RHINO
86 "Syncro" Van DIAMOND
87 Syncro Hightop WestyCamper ROCKY (for sale soon)
79 bay window OLIVER |
uncommonvw Samba Member
Joined: July 12, 2004 Posts: 230 Location: Jordan, ON Canada
Posted: Thu Oct 09, 2014 7:17 pm Post subject: |
I just installed an adjustable voltage regulator from the davebarton.com website.
I'm curious as to the voltage I should set it to while at idle? I currently have it set at 14.2V at idle. It jumps to 15.5V at 3000 RPM with no load on the electrical system. Am I supplying too much voltage off idle? I don't want to cook my batteries.
I'm running a stock type starting battery and a deep cycle marine auxiliary battery using the GoWesty isolator kit (which I've been told to replace with a SurePower or Yandina).
The alternator light stays dimly lit while at idle which I had hoped the new regulator would fix. I will check the blue exciter circuit and grounds next. |
Rodknock Samba Member
Joined: April 06, 2006 Posts: 516 Location: Boulder CO
Posted: Fri Oct 10, 2014 7:47 am Post subject: |
I believe I have my adj. VR set at about 14.5 at the starting battery terminals, and it shows about 14.2 at the auxillary battery, so I don't think you have it set too high. I am using the GW kit like yours (works fine BTW) and a marine deep cycle. |
Posted: Fri Oct 10, 2014 8:25 am Post subject: |
I just re-checked the voltage at different locations. I would like to ensure that I'm not over charging my battery.
At idle 850-900 RPM
Starting battery 14.12V
Aux. Battery 13.95-14.06V
Alternator 14.21V
At 3000 RPM (no electrical load) these are the numbers that concern me
Starting battery 16.6V
Aux. Battery 15.82V
Alternator 16.98V
Am I worried over nothing here.
Obviously the alternator is making enough voltage to charge the battery. However, the alternator light is still dimly lit at idle. |
Posted: Sat Oct 11, 2014 4:36 am Post subject: |
Popular vendors sell an Alternator Charge Initiation Kit, for $25 it's a plug and play harness to fix the light being on at start up. I bought one but engine is out so haven't got to test it yet...
I'm no expert on DC power but those numbers seem way too high. Here is something found using a google search:
Charging
The charging voltage is very important. Is the voltage too high (over 14.4 V) water will evaporate, explosive gases will develop, and the battery gets warm or even hot. The battery gets destroyed.
- The correct charging voltage is 13.8 V – 14.4 V and the charging time should be 10 – 16
hours.
- The typical (daily) charging should be 14.2 V - 14.4 V
- During charging the battery must never get hot.
- Continuous-preservation charging: 13.4 V for gelled electrolyte and 13.8 V for flooded cells
After full charge the terminal voltage will drop quickly to 13.2 V and then slowly to 12.6 V.
Perhaps set the regulator to the desired voltage at the 3000 rpm phase? _________________ North American Hightop Installer/Distributor
Current stock (5)
Hot Water Systems
Posted: Sat Oct 11, 2014 6:23 am Post subject: |
Update:
Turns out there was something wrong with my alternator.
I swapped out the alternator with another one and was getting a steady 13.8V at idle with the stock regulator.
Put in the adjustable regulator and was getting 14.2V at idle and 14.5V at 3000 RPM.
Thanks to Jay Brown (thatvwbusguy) and Dave Barton (www.davebarton.com) for explaining what was happening. |
madspaniard Samba Member
Posted: Sat Oct 11, 2014 9:10 am Post subject: |
uncommonvw wrote: |
Put in the adjustable regulator and was getting 14.2V at idle and 14.5V at 3000 RPM. |
Measured at the battery? I still have to install mine, it has been sitting in the garage for too long _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Posted: Sat Oct 11, 2014 10:27 am Post subject: |
uncommonvw wrote: |
Update:
Would Jay and Dave's explanations be helpful to this thread? I'd be interested in knowing what was going on... _________________ North American Hightop Installer/Distributor
Current stock (5)
Hot Water Systems
Posted: Sat Oct 11, 2014 6:14 pm Post subject: |
madspaniard wrote: |
uncommonvw wrote: |
Measured at the battery? I still have to install mine, it has been sitting in the garage for too long |
Yes, these measurements were taken at the starting battery under the passenger seat.
These are the symptoms I was experiencing which led me to purchase the adjustable voltage regulator. You may have experiences different than mine?
I have a 1985 Westfalia with a 1.8L 8V inline conversion. I am running a dual battery set up using a GoWesty battery isolator system.
Some Westfalias have an alternator light that doesn't go out upon start up of the vehicle without revving the engine. Mine is no exception. To remedy this the previous owner installed a push button under the dash to "excite" the alternator without having to rev the engine. Recently the light would stay dimly lit at idle after using the switch. I checked the voltage at idle and was only getting 13.1V which I was told was insufficient to charge both batteries properly. So, I bought and installed the AVR from www.davebarton.com hoping to bump up the voltage and turn the light out. This created a new problem. After installing the adjustable regulator I ended up with 16.8V at 3000 RPM at the starting battery.
Here is how Dave Barton explained the problem I had...
I know you didn't adjust it too much. In my experience you will never
get more than approx. 15v at max adjustment in a good running
alternator. My point was that something other than the adjustable
regulator is causing the high voltage. An alternator with NO
regulator present or one that has been wired for a full field test will do
what yours is doing.
A regulator doesn't know or care what RPM your engine is at. It only
regulates voltage by cutting voltage when it reaches a set level. If
your voltage was stable at idle and suddenly spikes out of control at
3000 RPM, then something in your alternator or wiring is either
turning off the regulator function as RPMs rise or the voltage is spiking
so high that the regulator can't compensate.
This is why I switched the alternator with another one. Checked the voltage at the battery with the stock regulator then switched to the adjustable regulator. |
TommyBoyGomes Samba Member
Joined: May 28, 2005 Posts: 1531 Location: L.A./Dublin, Irl
Posted: Sun Oct 19, 2014 8:23 pm Post subject: |
For those of you who have been using the adjustable voltage regulator now for some time, have you seen any negative long term effects anywhere in the electrical system? Thanks. _________________ 1969 Squareback, 1776cc
1990 Vanagon Multivan |
vanonimous Samba Member
Joined: October 19, 2013 Posts: 362 Location: Burien, Center of the Universe
Posted: Mon Nov 10, 2014 11:16 am Post subject: |
I've used adjustable regulators on other then Vanagon (still Bosch) systems for years now and my experience is I am usually just counteracting a symptom and not addressing the actual problem. Like for example a battery that won't take or hold full charge or to high a resistance on slip rings, failed diode on the bridge, high resistance wiring and such. Still it is OK as temporary solution but on a perfect running charging system it shouldn’t be needed. _________________ If happiness is being a mechanic, owning a Vanagon is nirvana.
Lighting upgrades: https://www.thesamba.com/vw/forum/viewtopic.php?t=578291 |
Posted: Tue Nov 11, 2014 1:31 am Post subject: |
vanonimous wrote: |
I've used adjustable regulators on other then Vanagon (still Bosch) systems for years now and my experience is I am usually just counteracting a symptom and not addressing the actual problem. Like for example a battery that won't take or hold full charge or to high a resistance on slip rings, failed diode on the bridge, high resistance wiring and such. Still it is OK as temporary solution but on a perfect running charging system it shouldn’t be needed. |
Yeah, the only reason I'm interested is because the AGM Aux battery wants a higher charge then the normal output. I'm hoping to find a happy medium between what the aux and wet cell starting battery desire for optimal life. 14.2 is what I've gathered so far to be the best??? _________________ North American Hightop Installer/Distributor
Current stock (5)
Hot Water Systems
noganav Samba Member
Joined: January 06, 2006 Posts: 1236 Location: San Diego CA
Posted: Tue Nov 11, 2014 1:45 pm Post subject: |
I just installed an adjustable voltage regulator, then had an electrical fire at the main terminal of my alternator.
Coincidence? Sort of. I probably only needed the adjustable because I was losing volts to a poor wire in the first place. With some new 6AWG to the starter, I didn't feel the need to put the adjustable back on the new alternator.
I'd say if your system is losing so many volts that you need to worry, look at the condition of the wires first and mess with the alternator second. |
Posted: Sun Nov 16, 2014 12:31 pm Post subject: |
Classic example of counteracting a symptom instead of addressing the problem. I wish I could have my doctor see that perspective.
-> KevbOliver I have never used AGM in parallel with lead acid batteries but they should have the same charging requirements, no? I use standalone AGMs on my bikes and they seem to work great.
Where does your output voltage cut off? Go past 14.5VDC and you'll be boiling off H2O molecules out of a vented lead acid battery it will probably not be good for it. _________________ If happiness is being a mechanic, owning a Vanagon is nirvana.
Posted: Sun Nov 23, 2014 6:07 pm Post subject: |
Just wanted to provide a before and after report of my adjustable regulator install for the archives:
I used the voltage regulator module from aircooled.net, which has alot of nylon/plastic parts instead of the original metal parts that come with the alternator's regulator. It's also physically smaller than the original metal one and there's about a 1/2" gap between the body of alternator and the perimeter of the aircooled.net regulator (vs. about a 1/4" gap on the original one). I'm hoping this isn't an issue?
I have the gowesty auxiliary battery set-up in my van, but everything else including the wiring is all stock VW. Here are the voltages I was getting with each setup:
With original Bosch voltage regulator (non-adjustable):
Main Battery @ idle = 13.99V
Main Battery @ 3000 rpm = 14.01V
Main Battery @ 4000 rpm = 14.02V
Aux Battery @ idle = 13.61V
Aux Battery @ 3000 rpm = 13.66V
Aux Battery @ 4000 rpm = 13.66V
With the adjustable voltage regulator installed (after I adjusted the setting a little bit upwards to get 14.5V at the main battery):
Main Battery @ idle = 14.48V
Main Battery @ 3000 rpm = 14.49V
Main Battery @ 4000 rpm = 14.5V
Aux Battery @ idle = 14.0V
Aux Battery @ 3000 rpm = 14.01V
Aux Battery @ 4000 rpm = 14.01V
I was a little surprised that the voltage didn't change much when the engine was rev'd. Is this normal?
So all in all this adjustable regulator increased the charging voltage batteries by about .4V. While I know that my AGM aux battery would also like to see 14.5-14.7V during charging instead of 14.0V, that's a different project for a different day. _________________ 1969 Squareback, 1776cc
