Wolfsburg West Okrasa heads/kit
Page: Previous  1, 2, 3 ... 16, 17, 18, 19  Next
Braukuche
Braukuche is offline
PostPosted: Sat Nov 19, 2011 6:47 pm    Post subject: Reply with quote
rtroy wrote:
Flavio wrote:
rtroy
If you are refering to the WW (Wolfsgurg West) Okrasa Heads kit, yes, the short head studs are included and needed.
I understand that this is the first part of Braukuche question ? And... he is right about the reason beeing to provide clearence for the Okrasa intakes.
I'v not talk or tryed to help about the measure of the shims under the cylinders.... because I've not yet personal experience about it.
Below you can see:
The studs:
http://www.wolfsburgwest.com/wolfsburg_new/engine/25-36hp/WW_dual_port_hdwr.cfm
The kit parts:
http://www.wolfsburgwest.com/wolfsburg_new/engine/25-36hp/WW_dual_port_kit.cfm
Sorry, I over quoted: I had intended to delete the portion about studs and was only speaking, of course, about spacers.
I have not gone through the kit completely, so I have not noticed the studs.
As for the shims, I know the Okrasa kit included them, but yes, I will measure and then figure what I need, make sense.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
rtroy
rtroy is offline
PostPosted: Sat Nov 19, 2011 7:15 pm    Post subject: Reply with quote
Sorry, that's a mistake; you use "the" as if there was only one "Okrasa kit." In fact, there were quite a few different offerings. The shims were ONLY included in the "kits" that also included a longer stroke crankshaft.
RT
Richard
Karmann Ghia and Porsche 356 enthusiast
Founder, The Karmann Ghia Club of N. America
Braukuche
PostPosted: Sat Nov 19, 2011 9:18 pm    Post subject: Reply with quote
RT
I think most people understood the context Richard, but thanks for pointing it out.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
GüteAndTite
Early Convertible Güru
GüteAndTite is offline
PostPosted: Sat Nov 19, 2011 10:22 pm    Post subject: Reply with quote
tommy-turtle wrote:
After what seemed forever they are done. Very Happy
Shocked
Shocked
Thank You Ray for putting up with all the complaining, griping, the internet keyboard fighters for all the CRAP that people CLAIM is theirs. You put up the money and the time to get it done and for that I thank you.
Thank you for the manifolds, exhaust, the pulley, rockers and when the supercharger comes out I will be in line for that also. Besides a few other companies out there making stuff for 36hp thank you. Thank you for making the stuff in the USA (even though the cars are from Germany)
(RAY when the web sight comes up with all the stuff, you better be ready to ship it all around the world. Rolling Eyes )
these are gorgeous, when do you plan on selling these?
Official 58-60 "Early Big Window" Convertible Thread & Registry
http://www.thesamba.com/vw/forum/viewtopic.php?t=426481
F&S Saxomat Automatic Clutch System Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=462533
61-67 Delanair Air conditioning Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=457944&highlight=air+conditioning
PUNCTUATION CHANGES THE WORLD: "I need to help my uncle, Jack, off a horse" is way better than, "I need to help my uncle jack off a horse"
Flavio
Flavio is offline
PostPosted: Sun Nov 20, 2011 3:57 am    Post subject: Reply with quote
No problem. I was just trying to clarify what I've said.
In fact, when I've recieved the kit, I was wondering what would be the purpose of those studs....
I've found the reason, later, in the assembling process.
Thanks for sharing the formula.
I've recorded it, because maybe in the near future, I'll try to upgrade the engine with the 69 mm crank and a different cam.
55reasons
Samba Swamp Cooler
55reasons is offline
PostPosted: Sat Jan 07, 2012 7:16 pm    Post subject: Reply with quote
Question.
Throttle return (back to idle after stepping on the gas)
RHD car.
I added a long spring from the fan shroud to the carb as a temp fix.
Does anyone know a better way to do this, or a spring (part number) to use for this purpose?
*Edit; also, the vw engine shop that prepped it for me says the engine would not turn with the WW supplied "OT" pulley. Crazy as far as I am concerned unless it rubs somewhere, but did anyone have a similar issue?
oval56
oval56 is offline
PostPosted: Sun Jan 08, 2012 3:26 am    Post subject: Reply with quote
i had the same experience with this pulley two times... the diameter is to thick on the oil grooves, the result is a damaged case if you run the pulley.
www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com
Flavio
Flavio is offline
PostPosted: Sun Jan 08, 2012 3:28 am    Post subject: Reply with quote
Hi
If you have the WW Okrasa kit (original version), there is a long spring for the throttle return as you can see in the pic.
Regardind the OT pulley and assuming that your's is similar to mine, I've asked a machinist to remove just "less than a hair" from the part where the grooves are, because it was rubbing a litle in the case hole interior.
Also, because the generator pulley was not an original one, I've to fit a 2 mm spacer in order to have the OT pulley a litle bit out and in perfect line with the generator pulley.
The throttle spring
As you can see the fan belt is not vertical as it should be (this pic was before installing the spacer)
If I remember well, I bought the spacer from CB Performance, but others have them also.
Hope this helps
55reasons
Samba Swamp Cooler
PostPosted: Sun Jan 08, 2012 1:52 pm    Post subject: Reply with quote
Thanks.
I didn't get the spring with my kit. I will hit up WW to send me one.
Good to know about the OT pulley. I'll get that worked out too.
Thanks for the replies and the photos! Much appreciated!
rtroy
rtroy is offline
PostPosted: Sun Jan 08, 2012 7:58 pm    Post subject: Reply with quote
I'll take it on faith that there's an oversize oil return thread on the new OT pulley; this is a BLESSING.
That the oil return threads are oversize - as was offered from the factory - means that they'll work on ALL engines, you just have to fit it to the case properly. (This isn't any kind of problem for a well-equipped workshop - the usual way is to trim down the OD on the return thread.) I'm GLAD they did this, just don't be silly and toss it in there without measuring and making sure the clearance is OK - you might come out looking less than well informed! -smile- It should be as close as can be without touching.
(Note that if you run an engine with wiped out bearings, the oil return threads can machine the case and cause trouble with oil sealing following a rebuild. That's why the factory made pulleys available with an over-size thread. You can usually spot the probem with simple visual inspection. Once you need an oversize pulley, Good Luck finding one in this day and age. Having the new OT pulley provide this feature is A Really Nice Thing.)
Regards,
Richard
leeezard7
leeezard7 is offline
PostPosted: Sun Jan 22, 2012 6:21 pm    Post subject: Reply with quote
new to the 36hp world but not new to vw's or porsches. ASE certified porsche mechanic and machinist for over 20yrs. love the little bugs too. i have a machine shop at home for my evening entertainment. current project is a 1952 splitwindow beetle threefold ragtop car. body is done waiting for paint. irs/balljoint/4 whl disc brake/porsche fuchs pan is done waiting for motor and body. already purchased and am buidling a 36hp cased 1759cc. porsche forged 74 counter weighted crank, porsche forged rods, porsche forged 87 pistons and cylinders, porsche regrind 1500s hotcam, forged straight cut cam/crank gears, original okrasa heads im machining to accept 37x33 ss valves, port and polish. my 1.15 ratio rockers for 36hp, dual 48ida's, 009/pertronix, pertronix flamecoil, porsche 12v gen, my ot pulley remake, and my custom ss merged header with porsche carrera style twin megaphone zoomies.
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Mon Jan 23, 2012 8:45 am    Post subject: Reply with quote
leeezard7 wrote:
new to the 36hp world but not new to vw's or porsches. ASE certified porsche mechanic and machinist for over 20yrs. love the little bugs too. i have a machine shop at home for my evening entertainment. current project is a 1952 splitwindow beetle threefold ragtop car. body is done waiting for paint. irs/balljoint/4 whl disc brake/porsche fuchs pan is done waiting for motor and body. already purchased and am buidling a 36hp cased 1759cc. porsche forged 74 counter weighted crank, porsche forged rods, porsche forged 87 pistons and cylinders, webcam grind 1500s hotcam, forged straight cut cam/crank gears, original okrasa heads im machining to accept 40x35.3 ss valves, port and polish. my 1.15 ratio rockers for 36hp, dual 48idf's, 009/pertronix, pertronix flamecoil, porsche 12v gen, my ot pulley remake, and my custom ss merged header with porsche carrera style twin megaphone zoomies.
Please post pics of the valve seats and the valves in the head.
"no more hacking my sig line"
john morris
john morris is offline
PostPosted: Mon Jan 23, 2012 6:44 pm    Post subject: Wolfsburg West Okrasa heads/kit Reply with quote
I would like to thank everyone that has contributed to this thread, I really appreciate all the hard work, effort and money!
Can we get some gas mileage estimates from those with the kit installed. Please add whether it is in a bug, bus, ghia, and what other mods have been done.
thanks!
leeezard7
PostPosted: Tue Jan 24, 2012 11:11 pm    Post subject: Reply with quote
after using a mic and some measurements 37x33 or 38x32 is all i can squeeze in. thanks.
grueni
grueni is offline
PostPosted: Wed Jan 25, 2012 5:14 am    Post subject: Reply with quote
hehe, wishes was the first thought of thinking.
fist messuring and then posting Wink
but also with the 87mm pistons you are on the most extrem way that is still possible to handle in the head with alot of work on heads and head studs. i hope you will not use it as daily driver.
good luck with the build
1960 1584cc turbocharged, 35,5/32 (11,117s 1/4mile )
leeezard7
PostPosted: Wed Jan 25, 2012 11:47 pm    Post subject: Reply with quote
it will be a wkend warrior car. thanks gruni
55reasons
Samba Swamp Cooler
PostPosted: Thu Jan 26, 2012 12:07 am    Post subject: Reply with quote
first run. nice and sllloowwwww.
No need to watch past the 25 sec mark.
NUG637
NUG637 is offline
PostPosted: Sun Jul 22, 2012 2:22 am    Post subject: Reply with quote
hey guys, ive just done over 1000k's on my rebuilt okrasa engine and I'm still learning alot as i go (first ever engine rebuild on my own). The only thing other the the heads and carbiis that isn't stock is the okrasa spec cam i bought off mr okrasa. Its been running great other then a few things as mentioned below....
under acceleration i have to tap the accelerator first before I'm about to take off. if i just try to take off without the initial tap/pump its coff's back up through the carb, or feels as if its about to stall, other then that she hums along great even up over 80mph
and same with reverse, if its flat ground i can reverse ok but with a slight incline i have to keep bringing up the revs and tapping the accelerator as otherwise it keeps wanting to stall....?
I'm thinking it may be a timing issues and I've always just blamed the 009 thats in it, am saving for a glen ring 010 but I'm not entirely sure this might be the cause? my timing is currently set to 10 degrees at idle.
I'm hoping some of the more experienced people on here might tune in and give me a few pointers on what to do....
the reason i bring this up is I'm getting ready to take this engine on its maiden voyage (1500km round trip) to a 3 day show in another state, and as I'm used to how it drives now I'm just wondering if i can get it accelerating and reversing any better.
thanks in advance for any input
Mr. Okrasa Premium Member
Original Old Speed
Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Mr. Okrasa is offline
PostPosted: Sun Jul 22, 2012 10:44 am    Post subject: Reply with quote
Have you seen this below? It could be one of your problems:
http://www.thesamba.com/vw/classifieds/detail.php?id=1306307
http://www.thesamba.com/vw/classifieds/detail.php?id=1316478
Cheers! Mr. Okrasa Cool
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint Wink
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com
NUG637
NUG637 is offline
PostPosted: Mon Jul 23, 2012 11:41 pm    Post subject: Reply with quote
you nearly had me convinced my carbies were buggered, then i relised my linkages where abit off... it was pumping fuel on the drivers side way before it would pump on the passenger....
runs like a dream now Wink
rookie error Embarassed
Page 17 of 19
