miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Mon Jul 06, 2009 5:15 pm Post subject: |
It's like dual cannons, with mufflers. Bet it works about as well. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
66Rredvert Samba Member
Posted: Mon Jul 06, 2009 8:26 pm Post subject: |
I saw this at the VW Classic It's looks great but on the test car the front of the rear fenders was all scratched up where the exhust gunk would settle when in use not my cup of tea |
PZL66 Samba Member
craigman Samba Member
Posted: Sat Nov 14, 2009 11:32 pm Post subject: |
That sounds like poo poo! |
LeviMan2001 Samba Post Whore
spyvsspy Samba Member
Joined: August 22, 2006 Posts: 1022 Location: inside the barrel...
Posted: Sun Nov 15, 2009 11:07 am Post subject: |
That setup looks like something that I would definitely pass on. Probably garbage. _________________ It is what it is. |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Sun Nov 15, 2009 12:13 pm Post subject: |
LeviMan2001 wrote: |
Besides the sound (which I like ) is there really any performance problems with this set up? |
Yeah, on each bank, your exhaust pulses are out of phase...one exhaust pulse arrives 180 degrees after the first, the next arrives 540 degrees later.
A regular merged header phases the exhaust pulses 180 degrees apart from each other; even pairing exhaust pulses between cylinders 1 and 3, and cylinders 2 and 4 would still keep the exhaust in phase, 360 degrees apart.
It's analogous to the problems created by dual single-throat carburettors, like Kadrons and ICTs...in which case, if you're running these carbs, you've finally got an exhaust system that matches _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Tue Nov 17, 2009 6:38 am Post subject: |
I just threw up in my mouth...
Jeez does that sound horrible!
(and I swear I hear a head leak too!) _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
fastinradford Samba Member
Joined: June 08, 2008 Posts: 2895 Location: Athens Ohio
Posted: Tue Nov 17, 2009 9:14 am Post subject: |
Stripped66 wrote: |
It's analogous to the problems created by dual single-throat carburettors, like Kadrons and ICTs...in which case, if you're running these carbs, you've finally got an exhaust system that matches |
unless your running a sp motor with dual singles. _________________ 95 jetta 5spd, (first waterpumper vw)
the nice 74 Ghia, (of course the fiance drives that one).
My mk1 jetta 1.6d
"It'd still be like my grandads old broom though, original, only 3 new heads and two new handles" -Marv [UK] |
Posted: Tue Nov 17, 2009 9:53 am Post subject: |
fastinradford wrote: |
unless your running a sp motor with dual singles. |
A single-port with dual-singles is similar to a dual-port with dual singles...the difference is the location where the single runner diverges into two runners. In any case, you've got a single carb that experiences its intake pulses out of phase. _________________
66brm wrote: |
Bodacious wrote: |
vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Tue Nov 17, 2009 10:34 am Post subject: |
You guys are pretty hard on GDown. You have crushed those guys. Youve taken thier header and beat thier own heads with it.
But I too associate the sound to those little buggie style cars that show up at the drag races and has 4 seperate pipes going in all directions. You really only hear one pipe when it happens to fire off. Makes you want to reach over and put the plug wire back on as a favor. |
bugnut68 Samba Member
Joined: June 10, 2003 Posts: 4180 Location: Eugene, OR
Posted: Tue Nov 17, 2009 11:09 am Post subject: |
I harbor no ill will toward G-Down, this exhaust just isn't my flavor. I know they were posting up on the Cal Look Forum or another site awhile back, insinuating that the dyno figures would prove this system design superior to other merged systems, and that "back pressure is a myth." That last part is a direct or darn near direct quote.
I haven't seen any dyno graphs to date, but would be interested to see how things turn out. |
Alister Samba Member
Joined: April 23, 2009 Posts: 225 Location: Mountain Home, Idaho
Posted: Tue Nov 17, 2009 11:42 am Post subject: |
Sounds like a riced Subaru - like it has a misfire. (Can anyone explain why Subies sound like crap, when they have the same engine layout as the ACVWs?)
Can't help but think that system weighs twice what the merged systems do, easily, while the merged headers are well-proven performers. And I'm not fond of drilling holes in my trailing arms, either.
No thanks. Unless they offer one with cylinders #1&3, 2&4 paired, so it doesn't sound like a Subaru or old Honda CB-K series bike (400, 550, 750, etc). 'Course, then it would sound like an old BMW or Triumph... _________________ '75 1303A - "Debbie"
64,999,987 firearms owners killed no one yesterday. |
Posted: Tue Nov 17, 2009 12:36 pm Post subject: |
I think Subarus sound a lot cooler than in-line fours, myself... |
Posted: Tue Nov 17, 2009 3:24 pm Post subject: |
I myself love the look of the exhaust coming out in front of the rear wheels.
What if we help them equalize the design and make it smooth. |
special-k Samba Member
Joined: September 26, 2008 Posts: 178 Location: Ontario Canada
Posted: Tue Nov 17, 2009 4:02 pm Post subject: |
Would crossing the front cylinders to the opposite side of the car help at all? I like the front exit also but am not crazy about the sound either. |
Posted: Tue Nov 17, 2009 4:10 pm Post subject: |
Modifying that exhaust to work better is equal to polishing a turd. _________________ It is what it is. |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Tue Nov 17, 2009 4:42 pm Post subject: |
spyvsspy wrote: |
Modifying that exhaust to work better is equal to polishing a turd. |
oh yes.... the voice of experience.... _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
Posted: Tue Nov 17, 2009 5:06 pm Post subject: |
Experienced enough not to waste a dime on that so called exhaust/turd. _________________ It is what it is. |
Posted: Tue Nov 17, 2009 5:15 pm Post subject: |
I watch the folks here go from needing help with basic maintenance to full blown experts on all things vw in a short time... Kind of funny... even more ironic was the public outcry very similar to this about A-1 exhausts when they were new... viscious circles fueled by polly... _________________
