Da TOW'D Samba Member
Joined: December 25, 2005 Posts: 1318 Location: Bella Coma Canada
Posted: Sun Aug 24, 2014 9:41 pm Post subject: |
Our '57 Cdn. Deluxe beetle's odometer turned 100Kms. today
I only drive it down our long side road to visit a friend every once in a while.
I adjusted the valves on its 1600 engine-and changed the oil
checked the transaxle fluid level
rear axle bearings haven't fixed them selves so that is next while it is on the hoist
cheers
hank _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy DD
and NUTS |
casper deuce Samba Member
Joined: August 09, 2013 Posts: 10 Location: Fresno, Ca.
Posted: Thu Aug 28, 2014 9:45 am Post subject: Trying to make my daily driver 1954 look a little better |
When I got the car the deck lid was an eye sore, so I spray painted it and also mounted some egg taillights (from the measurements found in the forum!) and upgraded the bumpers. Still need to spray paint the rear fenders and find (and paint) a pair of heart taillights.
Last edited by casper deuce on Tue Sep 16, 2014 10:52 am; edited 5 times in total |
ratpanel61 Samba Member
Joined: November 04, 2003 Posts: 345 Location: Va Beach, VA
Posted: Fri Sep 05, 2014 11:37 am Post subject: |
Picked up the rest of the parts for the rear end from the powder coaters yesterday and ordered the seat covers and foam from Sewfine today. _________________ - '57 Sunroof Beetle (project)
- '73 THING |
Posted: Fri Sep 12, 2014 8:47 pm Post subject: |
I removed the driver's seat and drilled out all the spot welds and ground the tack welds on the seat track
then moved the track forward two inches and MIG welded the spots back up
the seat now goes back that two inches and bottoms out
I'm 6'4" and it feels better having a little more leg room
cheers
'58 SC Ruf
'62 type 3 Notch
and NUTS |
vdubdavet Samba Member
Joined: July 15, 2014 Posts: 7 Location: springtown tx
Posted: Sun Sep 14, 2014 12:42 am Post subject: |
did a complete brake job just for my generator to go out when i started driving it.. |
Posted: Mon Sep 15, 2014 12:52 pm Post subject: |
So after many attempts to get all 4 gears on the tunnel type transaxle in my '57.
I found the aftermarket urethane coupling didn't line up properly with the front shift rod to get all 4 gears.
but more than likely I didn't drill the hockey stick in the proper spot
so a little "Dremel" work with a diamond bit I opened the alignment hole in the front shift rod and bolted the coupling screw down tight
Four on the floor sure feels good again
cheers
'58 SC Ruf
'62 type 3 Notch
and NUTS |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1896 Location: San Fernando Valley, CA
nvmipis1 Samba Member
Joined: August 25, 2012 Posts: 246 Location: riverside , ca.
Posted: Sun Oct 12, 2014 9:43 am Post subject: |
RestoKäfer Samba Member
Posted: Mon Oct 13, 2014 2:04 am Post subject: |
Put the bottom end together,line bored, thrust cut,crank ground .25,case .5.Bearings bought first could not get std/.25 |
Lars B Samba Member
Posted: Sat Dec 27, 2014 10:00 am Post subject: |
After eight years I remounted the rear body part on my new Channels.
I'm picking up speed now |
hutmo Samba Member
Joined: February 05, 2002 Posts: 36 Location: Pittsburgh, PA
Posted: Mon Dec 29, 2014 10:52 am Post subject: New door handles and rekeyed the ignition |
I found a few NOS door handles. One from Gabe with Keys and a passenger side handle from England.
The handle was brand new with two SG keys. I sent my ignition to Gabe to have him re-key it to match the key code of the new handle.
The passenger side handle came from across the pond and is also very nice.
Now onto the wipers. Any one have some nice 57 correct wipers?
HUTMO _________________ What if the Hokey Pokey really is what it is all about?
Samba Member #1115
Joined Feb 6, 2002 |
Posted: Sat Jan 10, 2015 6:55 pm Post subject: |
I had to accept the fact that my old pan was too far gone so I got a new one. Mid '57 only needs both 1/2's welded in. Got it home, and prepped it for welding tomorrow so it can get to powdercoat in a week or so. _________________ - '57 Sunroof Beetle (project)
- '73 THING |
The Inspector Samba Member
Joined: November 22, 2003 Posts: 87 Location: Kerrville, Texas
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4561 Location: St Charles, MO
Posted: Sat Jan 17, 2015 8:31 pm Post subject: |
Rolled my '55 Deluxe Sunroof "Martha" outside (see avatar photo) and fired her up and let her run for about 15 minutes. They've salted the roads recently, so "Martha" isn't going anywhere other that the driveway for a while...
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
vvdubman Samba Member
Joined: March 01, 2003 Posts: 75 Location: Carthage, NC
Posted: Tue Jan 27, 2015 4:56 pm Post subject: |
re-jetted the carbs, replaced the points and spark plugs, did the timing....and put her back on the road! |
Posted: Tue Jan 27, 2015 5:12 pm Post subject: |
sonicjagstang wrote: |
I got my car home today, sorted through a few parts found inside, installed the missing headlight and stared at it for hours. Not much of an accomplishment I admit but I didn't want to go too far on our first date.
I have standards afterall. In this case it is a deluxe but you get the idea.
Beautiful......want to sell it? |
Westy Steve Samba Member
Posted: Mon Feb 16, 2015 10:28 pm Post subject: |
Got one of the bullet blinkers to work. Been around VWs a long time and never actually saw that before. Cool and cute all at once. _________________ Have nice 914, want nice Bug |
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5274 Location: Taoswest, USA
Posted: Sat Feb 28, 2015 12:54 pm Post subject: |
Just tried to find it...
_________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
Posted: Sat Feb 28, 2015 8:46 pm Post subject: |
Clutch cable |
cvav8or Samba Member
Joined: September 23, 2007 Posts: 45 Location: Whidbey Island, WA
Posted: Sun Mar 15, 2015 4:02 pm Post subject: Took apart the drivers side door |
My windows are almost impossible to wind up and down on my 56 rag. So today I took the panels off, removed the window regulator/actuator, cleaned and greased it even though it was as smooth as butter. The damn windows are hard as hell to move up and down the felt channels. So I silicone sprayed them and they were still extremely hard to move.
So next I removed the inside scraper and they move effortlessly now. Not sure if I have the wrong inside scraper installed or what but I think I'm going to just order and install the German Door rubber kit and redo everything as the rubber looks pretty shoddy anyways and I am a little suspect that the doors were pieced together by the PO.
I also removed, cleaned and reinstalled my exterior door handles as well as adjusted the door striker plates so everything works as it should now.
This week I will receive all the parts necessary to shoe-horn my recently rebuilt 2.0L type 4 motor back into my little 56 rag Now I just need the weather to stay nice up here in Seattle.
