jhicken Samba Member
Joined: October 24, 2003 Posts: 9466 Location: Fallbrook, CA
Posted: Wed Jul 23, 2014 8:54 pm Post subject: |
Does TopLine sell an extension kit?
-jeffrey _________________ Der Kleiner Kampfwagens
jlex Samba Member
Joined: January 23, 2009 Posts: 2902 Location: NW Pennsylvania
Posted: Thu Jul 24, 2014 4:42 am Post subject: |
Glenn wrote: |
The only hard part is getting the roll pin out of the clutch pedal.
Glenn's right. If I didn't have a good vise, it may have been a real pain to drive that pin out. _________________ jlex.
'70 std. "Elsie"
'88 Carrera |
TX-73 Samba Member
Posted: Thu Jul 24, 2014 5:16 am Post subject: |
I just bought the accelerator pedal upgrade and the extended clutch shaft setup from Unique parts. Really quick response, parts look nice, will be interested to see how the whole thing works when done. I think that the new clutch shaft makes it a bit easier to hook up the clutch cable as well if I understood right. _________________ My 1973 Standard Beetle Build SOLD
Click to view image |
pb_foots Samba Member
Joined: April 15, 2010 Posts: 1089 Location: Ben Lomond, CA
Posted: Thu Jul 24, 2014 6:42 am Post subject: |
Yes, the way they attach the clutch cable to the pedal cluster makes it easier to install back into the tunnel.
I installed the bigfoot clutch pedal and accelerator kit a couple weeks ago. Very nice setup. had to get used to the new location of the clutch pedal and the pedal effort seems to be increased a little, (not sure what that's about), but the upgrade was well worth it.
BeejCyr, you're going to need to replace that part with an OEM one for the unique parts kit to work (if you decide to go that route). Check the classifieds here. Not sure you can just buy that piece new, but you can buy the whole pedal assembly from one of the vendors for about a hundred bucks. |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Mon Dec 21, 2015 7:00 pm Post subject: Re: Pedal rebuild kit easy or hard? |
Where can i find the bushings for my brake /clutch, and brake return spring(is that all i would need to rebuilt it)?or a kit ,i have the accelerator rebuilt kit allready..thanks in advance... |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Tue Dec 22, 2015 5:46 am Post subject: Re: Pedal rebuild kit easy or hard? |
Throwing this out there and its probably been mentioned Pedal Werks has a website and has rebuiding services in the classidieds. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Tue Dec 22, 2015 1:10 pm Post subject: Re: Pedal rebuild kit easy or hard? |
andk5591 wrote: |
Throwing this out there and its probably been mentioned Pedal Werks has a website and has rebuiding services in the classidieds. |
thank you for that ,but i prefer hands on till i mess it up |
Posted: Tue Dec 22, 2015 1:14 pm Post subject: Re: Pedal rebuild kit easy or hard? |
Usually I do my own - have never rebushed one, but just take them all apart, clean paint and grease. Sometimes they need a light sanding on the clutch arm shaft. They usually come out pretty well. But I need to get a couple more "cores" since the 2 that I have are pretty much junk. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Tue Dec 22, 2015 4:30 pm Post subject: Re: Pedal rebuild kit easy or hard? |
I wonder who would sell the bushings?or does anyone have exact measurement of bushings to use |
Rob711 Samba Member
Joined: September 05, 2013 Posts: 88 Location: Long island
Posted: Thu Dec 31, 2015 12:44 pm Post subject: Re: Pedal rebuild kit easy or hard? |
Anyone? I know ace hardware has bushings but do we have the dimensions |
Posted: Fri Jan 22, 2016 12:21 pm Post subject: |
Glenn wrote: |
on that clutch pedal closer to the top what is that lil tab for? |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Fri Jan 22, 2016 2:50 pm Post subject: Re: Pedal rebuild kit easy or hard? |
It's supposed to have a two-piece arm that has a rubber stop on it, so your pedal stops on a soft spot before hitting the firewall.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
ToughBug Samba Member
Joined: July 22, 2014 Posts: 354 Location: Carlisle, Pennsylvania
Posted: Fri Jan 22, 2016 6:10 pm Post subject: Re: Pedal rebuild kit easy or hard? |
Following the thread because I'm putting a new pedal assembly in while stuck inside during the storm.
But I might have a mismatched pedal assembly and pedal combination. Both from Jbugs. But the pedal doesn't fit the slot. And the new pedal assembly has a bar (silver section) that seems to stop the motion of the accelerator pedal at some point. The old one didn't have this.
Happy to be wrong. I can trim. And make it fit. Anyone see a the problem? Thanks. Tom (from under the sun drifts). Oh, I have a 73SB.
_________________ 1973 chassis + 1974 body = super beetle saved |
Posted: Fri Jan 22, 2016 7:55 pm Post subject: Re: Pedal rebuild kit easy or hard? |
ToughBug wrote: |
Happy to be wrong. I can trim. And make it fit. Anyone see a the problem? Thanks. Tom (from under the sun drifts). Oh, I have a 73SB. What do you expect from aftermarket ,like you said just shave a lil bit on all ends should be good to go
Posted: Thu Jan 28, 2016 6:36 pm Post subject: Re: Pedal rebuild kit easy or hard? |
I have taken the pedal cluster pin out ,what a pain that was ,resorted to air hammer life is sweet.. |
Ed_R Samba Member
Posted: Wed Aug 30, 2023 11:00 am Post subject: Re: Pedal rebuild kit easy or hard? |
I see this is an old thread:
Two questions, when did VW add the grease fitting to the aluminum casting? (thinking about adding to my pedal asm. - '74 SB)
What is the size of the circlip that holds the brake pedal on the casting?
Thanks! |
