wyobus Samba Member
Joined: February 08, 2006 Posts: 10 Location: Wyoming
Posted: Sat Apr 30, 2016 6:46 am Post subject: Re: Show off your engine bay! - Post your pics!! |
Single port with empi end castings to allow the use of the 34pict3. Now I have problems with oil bath filter rubbing the fan shroud. The manifold doesn't sit level. |
vamram Samba Member
Posted: Sat Apr 30, 2016 7:57 am Post subject: Re: Show off your engine bay! - Post your pics!! |
wyobus wrote: |
What's that contraption to the left of the distributor? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Sat Apr 30, 2016 8:06 am Post subject: Re: Show off your engine bay! - Post your pics!! |
wyobus wrote: |
EMPI Can you notch the support more, where the bolt goes through the case? And, what is the contraption to the left of the distributor? |
Brian Samba Moderator
Posted: Sat Apr 30, 2016 11:46 am Post subject: Re: Show off your engine bay! - Post your pics!! |
So wait, is the center section EMPI as well? Are the end castings pulling the manifold forward?
Sweet oil filter
_________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
wyobus Samba Member
Posted: Sat Apr 30, 2016 5:13 pm Post subject: Re: Show off your engine bay! - Post your pics!! |
Yes, it's crap empi end castings . The center section is good Oem VW. I opened up the slot on the center intake manifold in hopes to allow the flange to sit level, that helped. I think the cheap empi castings simply don't match the center section. I had to slightly bend the heat risers to match the exhaust also. The contraption to the left of the distributor is a canton meca oil filter. |
Posted: Sat Apr 30, 2016 5:35 pm Post subject: Re: Show off your engine bay! - Post your pics!! |
Interesting. I wonder now if SP manifolds sit closer to the shroud than DP ones? Or if it's just the SP end castings that are too far forward. Do you have a real SP manifold to compare it to? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
enjoyther1de Samba Member
Joined: December 19, 2010 Posts: 1279 Location: chino,ca
Posted: Sat Apr 30, 2016 5:50 pm Post subject: Re: Show off your engine bay! - Post your pics!! |
Here's my mess.
_________________ HBB took me to BBV. |
wyobus Samba Member
Posted: Sat Apr 30, 2016 5:59 pm Post subject: Re: Show off your engine bay! - Post your pics!! |
Well, my next thought was to revert back to an original sp manifold and use a 30pict3. I think I'll try the paper filter housing next. I used the sp heads because I couldn't find a decent pair of dp. The 1600 runs really good with these sp heads and the 34pict3! |
wyobus Samba Member
Posted: Sat Apr 30, 2016 6:07 pm Post subject: Re: Show off your engine bay! - Post your pics!! |
I like what's done with the intake enjoyther1de! Where's the filter? |
Posted: Sat Apr 30, 2016 6:26 pm Post subject: Re: Show off your engine bay! - Post your pics!! |
Filters here
Under the vw emblem.
flat4olsen Samba Member
Joined: February 20, 2014 Posts: 339 Location: Denmark, Europe
Posted: Mon May 09, 2016 2:23 am Post subject: Re: Show off your engine bay! - Post your pics!! |
Goldbug3318 Samba Member
Joined: September 06, 2014 Posts: 210 Location: Jacksonville, FL
Posted: Mon May 09, 2016 3:35 am Post subject: Re: Show off your engine bay! - Post your pics!! |
Cleaned it a bit this weekend: _________________ 1971 Super Beetle 1302S
1641 DP, lowered, 914's, etc...
1990 Ford Mustang Coupe
2008 Ford Mustang Coupe
2003 Chevy Corvette |
Zundfolge1432 Samba Member
Posted: Mon May 09, 2016 4:17 am Post subject: Re: Show off your engine bay! - Post your pics!! |
Pretty huh?
yellowbug03 Samba Member
Joined: June 25, 2007 Posts: 24 Location: Anderson, Indiana
Posted: Tue May 10, 2016 10:14 am Post subject: Re: Show off your engine bay! - Post your pics!! |
wolfburger1303 Samba Member
Posted: Fri Jun 03, 2016 6:23 am Post subject: Re: Show off your engine bay! - Post your pics!! |
Here is mine
wcfvw69 Samba Purist
Posted: Fri Jun 03, 2016 6:50 am Post subject: Re: Show off your engine bay! - Post your pics!! |
1970 bay with 71' dual port engine in place. _________________ Contact me at [email protected]
The Samba member since 2004.
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3987 Location: Antioch, California, a block from the hood
1968KdFWagen Samba Member
Posted: Wed Jun 08, 2016 4:03 pm Post subject: Re: Show off your engine bay! - Post your pics!! |
Just got mine put back into the Beetle. I am going to get a 356 Knecht air filter until I get dual single port carbs.
I need to fix the seal, any suggestions?
This is what I started with 3 years ago
_________________ Ian
"Insanity is doing the same thing, over and over again, and expecting a different result."
1968 Type 1 - Royal Red --- Built: September, 1967
1600 Single Port Engine - F1950480 (VW Exchange) Made January 16th, 1970
113-905-205K
30 PICT-1
Fahrgest.-Nr. 118096544 |
Posted: Mon Aug 08, 2016 3:52 pm Post subject: Re: Show off your engine bay! - Post your pics!! |
Brian wrote: |
Interesting. I wonder now if SP manifolds sit closer to the shroud than DP ones? Or if it's just the SP end castings that are too far forward. Do you have a real SP manifold to compare it to? |
RE: Me
A single port manifold will be too far forward to use a 34pict3. But stock sp end castings will line up with a dp center section just fine. Just have to make custom boots.
Finally finished my 2007cc. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
vamram Samba Member
Posted: Mon Aug 08, 2016 4:45 pm Post subject: Re: Show off your engine bay! - Post your pics!! |
Brian wrote: |
Brian wrote: |
RE: Me
Finally finished my 2007cc. |
That's a single port with a dual port manifold?? What did u make the boots from? How's it run? _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
