oval53/split52 Samba Member
Posted: Thu Jul 23, 2009 8:56 am Post subject: My express engine |
Just managed to fit my Express engine in my 51. Had lots of trouble and spent lots of time getting it roadworthy so I missed Hessisch..
Still I am in need of correct black spark plug wires, a good cleaning and a Knecht cyclone filter, but thats details.
Anyway - where can I get in contact with a good supplier of Solex jets?
Boonies Samba Member
Joined: November 30, 2005 Posts: 816 Location: Chicago
Posted: Thu Jul 23, 2009 1:14 pm Post subject: |
You could talk to Mr.Okrasa he will more than likely have what you need.
Also is the a OG 1500 super valve clearance badge on top of your "383"? _________________ The Old Speed Shack |
loor Samba Member
Joined: November 20, 2008 Posts: 79 Location: germany, southern
Posted: Thu Jul 23, 2009 1:50 pm Post subject: |
hey,
very nice, you don't see too much expresser around congrats!
jets are distributed by ruddies in berlin germany
http://www.ruddies-berlin.de/SOLEXduesen.htm
takes some time until he answers
cheers lorenz |
Posted: Thu Jul 23, 2009 2:10 pm Post subject: |
Boonies wrote: |
Also is the a OG 1500 super valve clearance badge on top of your "383"? |
Thanks - both of you.
The badge is repro made by Brezelwerks. |
Posted: Thu Jul 23, 2009 2:20 pm Post subject: |
Looks great either which way! _________________ The Old Speed Shack |
Peter_Plade Samba Member
Joined: January 09, 2005 Posts: 551 Location: Denmark
Posted: Fri Jul 24, 2009 11:41 am Post subject: |
Looking forward to check it out at SCC!
Is it running good?
When I had my Express on the dyno, the dyno guy had some very very small drills so that he could small jets bigger. It was that he made my main air jets the correct size.
By the way I´ve send you a pm _________________ http://vw-bluehats.blogspot.com/ |
Posted: Sun Jul 26, 2009 3:15 pm Post subject: |
I tested the engine today, and it will need some adjustments before everything is ok. I tried to adjust the emulsion pin several times with out any luck. I also discovered that the Express manual i've got is missing a page.
Since the engine is an almost 100% original 36hp, i was hoping that the original "recipe" in the Express manual could help me. Anyone?
The one I've got is also in swedish so I have some problems understanding everyting without a drawing.
Sparkplugs are very black, and it seems like the engine is capable of more if i change the jets, venturies or emulsion tube holder. The emulsion tube holder should have reservoar 5,5, it was originally 5,0.
PeterPlade: Have you changed your venturies, emulsion tubes, or emulsion tube holders? Or have you only changed the jets in your carbs????
Peter_Plade wrote: |
Is it running good?
By the way I´ve send you a pm |
Posted: Mon Jul 27, 2009 1:04 am Post subject: |
oval53/split52 wrote: |
Is it running good?
Hi I have the same manual as you and I can send you scan of it, I´m pretty sure that I have all the pages in my, but it´s also swedish. Read it 10 times in a row and you understand most of it, that was what I did
I only changed the jets, but with the setup from the papers it ran way to rich and was almost drowning sometimes.
I´m running a 100 main jet and a 180 main air jet maybe that can help you?
I haven´t tried with other venturis. _________________ http://vw-bluehats.blogspot.com/ |
Bengt H Samba Member
Joined: September 11, 2005 Posts: 332 Location: Sweden
Posted: Mon Jul 27, 2009 1:55 pm Post subject: |
Hi guys, I think you got the manual from me, if something is missing I can send you a new one.
In my express i have: 5,5 emulsion holder
23 mm venturi
175 main air jet
125 main jet
I also have a reground cam ( 7,6mm lift, no other data on it) and a litle more compression. It pumps out 41hp |
Posted: Tue Jul 28, 2009 1:00 am Post subject: |
Bengt H wrote: |
23 mm venturi
175 main air jet
125 main jet
Hi again
Yes did get manual from you Bengt at some years back.
I do also run with the 5,5 emulision holder.
But I think it´s funny that our main jets are so far apart, not that it matters since both our cars is run in on a dyno they both get the fuel/air mixture they should. _________________ http://vw-bluehats.blogspot.com/ |
Posted: Tue Jul 28, 2009 9:00 am Post subject: |
Great information guys
Tommorrow I'll recieve different Solex jets. After that I have to get it dynoed as you guys have done.
Maybe the different jetting is caused by using different distributors?
Bengts engine is maybe the closest to mine - i have flycut my heads 1,2mm and I am also using BRS 383 distributor. |
Posted: Tue Jul 28, 2009 10:38 am Post subject: |
My heads was cut 2mm´s if I remember correctly, anyway it was meassured so that compression ratio was set to 8-1.
And as you know I have the 010 distributor, and mr okrasa cam in mine.
Good luck on the dyno! _________________ http://vw-bluehats.blogspot.com/ |
Posted: Tue Jul 28, 2009 1:10 pm Post subject: |
Good luck on the dyno! |
What venturies do you use Peter? Is it stock? |
Posted: Tue Jul 28, 2009 1:18 pm Post subject: |
Bengt H wrote: |
23 mm venturi
175 main air jet
125 main jet
I've figured out everything in the manual, but one thing: What is actually a Emulsionsrör (or hovudspreder) in Swedish?
I see the emulsion holder should be 5,5, but what is emulsionrör?? Is it venturies? In your manual it says it the hovudspreder/emulsionrör should be set to 0(zero). |
vw-vintage Samba Member
Posted: Tue Jul 28, 2009 2:28 pm Post subject: EXPRESS...................................... |
fred |
Posted: Wed Jul 29, 2009 9:45 am Post subject: Re: EXPRESS...................................... |
Thanks alot Fred!
I am learning alot here. This is my first real engine project.
Some parts are now bought and some others was made during the day.
It now performs alot better
Still need to syncro and dyno it.
vw-vintage wrote: |
fred |
Posted: Wed Jul 29, 2009 1:08 pm Post subject: Re: EXPRESS...................................... |
Good to see that you coming through the problems |
RichardinNZ Samba Member
Joined: September 16, 2011 Posts: 280 Location: Auckland, New Zealand
Posted: Sun Oct 28, 2012 2:11 am Post subject: |
Any updates from anyone on this and jet sizes etc? Just got my heads back; skimmed 2mm (going to check their cc tomorrow) and now with 33mm intake valves. Standard cam.
Should I start with the jets etc recommended by Express?
Thanks
Richard _________________ Richard
'58 Beetle; NZ Assembled
Dual Carb 36hp
My Car https://www.thesamba.com/vw/forum/album_page.php?pic_id=1750253 |
