how to find top dead center with 1 2 valve cover off
brgnascar
brgnascar is offline
PostPosted: Fri Jul 24, 2009 7:48 pm    Post subject: how to find top dead center with 1 2 valve cover off Reply with quote
distributor is out dont know if this matters or not , im trying to install a new dizzy
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Jul 24, 2009 7:49 pm    Post subject: Reply with quote
Did you read this?
TDC (finding Top Dead Center)
Glenn
Member #1009
#BlueSquare
Mr. 010
Glenn is offline
PostPosted: Fri Jul 24, 2009 8:05 pm    Post subject: Reply with quote
Glenn wrote:
All factory pulleys will have a TDC mark. The question is are you on #1 or #3. To find out remove both valve covers. Put a wrench on the alternator/generator nut and rotate the engine until the TDC mark is in line with the case seam. Then have someone rock the engine back and forth as you observe the valves on #3. If they move then you are on overlap on TDC for #1. If the valves for #1 move then you are on TDC for #3.
Glenn
Member #1009
#BlueSquare
brgnascar
PostPosted: Fri Jul 24, 2009 8:18 pm    Post subject: Reply with quote
glenn , i took 1 & 2 cover off and #1 plug out turned pulley to tdc , screwdriver trick verifies me that # 1 is all the way up , and when i rock the motor 1 & 2 valves do NOT move , is this correct am i now on TDC for # 1 ??? the post you refered me to says that once i reach this point i need to turn the engine another complete revolution to TDC ? is that correct or am i at TDC Now
brgnascar
PostPosted: Fri Jul 24, 2009 10:15 pm    Post subject: Reply with quote
still wont start it tries but still wont any suggestions
Randy in Maine
Randy in Maine is offline
PostPosted: Sat Jul 25, 2009 5:16 am    Post subject: Reply with quote
When you think #1 is at TDC, slide over and look at the valves for #3. When your buddy up top is moving the crankshaft 2" on each side of TDC with a wrench, those valves will be tapping "like fingers on a table" if you are at TDC for #1.
If they are tapping at #1 when you do that, you are at TDC for #3.
brgnascar
PostPosted: Sat Jul 25, 2009 7:38 pm    Post subject: Reply with quote
Thanks for all the replys guys , i got it running this morning , set the svda at 32 full advance . all seems good . next problem , i went out to the garage this evening just to start it again and the battery was dead car has always had a week battery and its been sitting for about a month so the dead battery again didnt surprise me , so i hooked up my battery booster / charger and accidentally put it on 200 amp start , car turns over fine but now i have no spark . is it possible i fried coil or the computronix in dizzy . how can i tell ?? if so can i just put the points set up back in the svda that has been curved for my set up by low bugget or no ?
Randy in Maine
PostPosted: Sun Jul 26, 2009 6:03 am    Post subject: Reply with quote
Try replacing points and re-timing it.
I assume you are getting no reading on the dwell meter?
