benjaminjoseph Samba Member
Posted: Fri Jul 31, 2009 2:56 pm Post subject: Anti-pulse valve |
Anybody know which way the arrow on an anti pulse valve should face, toward the distributor or toward the carb?? |
Randy in Maine Samba Member
Posted: Fri Jul 31, 2009 3:51 pm Post subject: |
Can you post a picture of this anti-pulse valve? |
Posted: Fri Jul 31, 2009 6:26 pm Post subject: |
oops...
Last edited by benjaminjoseph on Fri Jul 31, 2009 7:56 pm; edited 3 times in total |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jul 31, 2009 6:29 pm Post subject: |
Close, but you need to insert the URL that ends in JPG between those 2 bracketed areas. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jul 31, 2009 7:01 pm Post subject: picture |
oops..
Last edited by benjaminjoseph on Fri Jul 31, 2009 7:57 pm; edited 3 times in total |
Posted: Fri Jul 31, 2009 7:49 pm Post subject: anti pulse valve |
Posted: Fri Jul 31, 2009 8:10 pm Post subject: |
Well that's the crazyest thing I've seen today, not a VW part, some sort of gas saving technology robbed from aliens perhaps?
I'd remove it.
Sure it's an advance line and not a fuel line? maybe a check valve? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Fri Jul 31, 2009 9:19 pm Post subject: |
concur - if it is between the dist port on the carb and the dist remove it. That is not a VW part. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
SGKent Samba Member
Posted: Fri Jul 31, 2009 11:38 pm Post subject: |
thread on these "mate"
http://www.volkszone.com/VZi/archive/index.php/t-145883.html
'Anti-Pulse' Valve >> Vacuum
Vacuum Advance 'Anit-pulse' distributor valve. Original equipment on Current Vehicles. Brass main casting. Designed to 'smooth the vacuum signal' from the inlet manifold, resulting in a more accurate ignition advance.
Weight: 100grams
Diameter: 13mm (1/2")
Depth: 25mm (1")
Part no APV001 (anti-pulse valve 4mm tails
£16.98 incl VAT
http://www.scarbro-racing.co.uk/fuelregulators.html
Or http://www.dellorto.co.uk/merchandise/products_det...ctionID=71
Vacuum distributor anti-pulse valve, helps to smooth the vacuum signal from the manifold to the distributor.
note: arrow points away from the distributor i.e. in the direction of the flow of vacuum.
Posted: Sat Aug 01, 2009 12:05 am Post subject: Anti- pulse valve |
It's actually a new aftermarket part called an antipulse valve it is manufactured by Europro over in the UK. I know what it is I bought it, I was just wondering if anybody has played with 'em. I've set up and rejetted dual Webber ICT's for my baywindow. It is purring away now just fine after a bit of experimentation. I've had a few ICT bus people recomend the anti-pulse valve to give a extra smooth ride, it works to even out the the vacume signal to a vacume advance when the signal begins right off of idle and also when it ends at about half throttle. Turn's out the arrow should face the carb (the direction of vacume), although can't say the improvement is major, only barely noticable. And yes that is a fuel line being used as a vacume hose, what ya gona do the Webber ICT vac port is huge...... thanks Merlin missed your post before writting most of this jibberish, ya hit the nail on the head. |
Posted: Sat Aug 01, 2009 8:53 am Post subject: |
Decades ago many cars used 1/8 OD metal tubing for the vacuum advance line. Pretty tiny inside diameter. I suspect it preformed pretty much the same function except that it wasn't directional in anyway. I presume that the anti pulse valve is some kind of a metered check valve that will dump vacuum quickly if you punch thereby killing the vacuum advance and preventing knocking. |
Lil Lulu Samba Member
Joined: December 08, 2007 Posts: 1745 Location: Mouth of the Columbia
Posted: Sat Aug 01, 2009 9:16 am Post subject: |
I'm preparing to install a CS in my 72 with dual Webers. The requirement dictate from Jake is: vacuum must come from both carburetors to obtain the proper vac signature for the 205p. The early Spanish Weber pair that I got from ACE only has one carrying the vac port, so Jake requires that a simple can that provides a void (empty can) be adapted to the units for the proper advance without the pulsing. I think this may be the application for this valve. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles |
