Front turn signal wiring help please
JoeLarge
JoeLarge is offline
PostPosted: Sun Apr 14, 2013 8:55 am    Post subject: Front turn signal wiring help please Reply with quote
I am in the process of trying to finish installing a Watson wiring harness the PO started and abandoned. I am working on the front turn signals and I wanted to ask a question about the ground for them as I am totally lost:
I understand the wiring of the other 3 posts, however the ground wire you can see in the picture, where do I need to run it to? (I will be using new wire for this of course) Any help or insight would be appreciated. I did look through the diagrams here on the TheSamba, however I am a bit lost.
1972 Super Beetle restoration with my son
69vduber
69vduber is offline
PostPosted: Sun Apr 14, 2013 9:55 am    Post subject: Reply with quote
Just run a ground from the base of the turn sig with the other wires and attach to a screw inside the trunk area body.
JoeLarge
JoeLarge is offline
PostPosted: Sun Apr 14, 2013 5:52 pm    Post subject: Reply with quote
Thanks for the tip 69vduber, much appreciated! I was considering installing a ground block as I have seen in other cars, to make things easier. I just wanted to be sure I was on the right track with how to ground things before I got too far ahead..
andk5591
andk5591 is offline
PostPosted: Mon Apr 15, 2013 4:36 am    Post subject: Reply with quote
Get yourself a handfull of external tooth washers (like #8 and #10) for any screw to body grounds. It will bite through the paint better and help you get a good solid ground.
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
JoeLarge
JoeLarge is offline
PostPosted: Mon Apr 15, 2013 6:45 am    Post subject: Reply with quote
I checked out some google shots of those external tooth washers, I understand now why you mentioned those...thanks again andk5591!
