dogsbody Samba Member
Joined: November 21, 2004 Posts: 21 Location: Victoria, B.C.
Posted: Fri Apr 22, 2011 4:02 pm Post subject: 65 Kombi axle spindle bearing clamp nut? |
Can anyone confirm the thread pitch for a 65 Bus? These are 18mm diameter threads. I am pretty sure from measuring using tools in my shop that the thread is an M18X1.0 (left hand).
The reason why I ask is I am working on my brakes, and the out-half of driver’s side axle spindle thread is in poor shape. I cannot find a die nut to chase the threads, and I really don’t want to disassemble of my front beam right now, as I haven’t found a used replacement spindle.
I’ve noticed wheel bearing clamp nuts for beetle and similar VWs, and I was told by one person in my local VW club that they had used a clampable lock nut on their Kombi... is there clamp nut that would fit my 65 Bus?
These are what I could find on-line:
VWC-131-405-669 - WHEEL BRG CLAMP NUT LEFT BEETLE 66-79 GHIA 66-74 TYPE 3 66-74 THING 73-74
http://www.cip1.ca/ProductDetails.asp?ProductCode=VWC%2D131%2D405%2D669
I wonder if these would fit my 65 Kombi?
I also found these, not sure of their diameter nor thread pitch but it looks like there is a left and a right:
ACC-C10-4210 - SPINDLE LOCKING NUTS FOR KING PIN FRONT END BEETLE / GHIA 49-65
http://www.cip1.ca/ProductDetails.asp?ProductCode=ACC%2DC10%2D4210
any insight appreciated! _________________ Drew
65 Kombi
73 Hi-Top automatic (for sale)
83.5 Vanagon Westy
Sorry for driving so close in front of you... |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24671 Location: Olympia Wash Rinse & Repeat
Posted: Sat Apr 23, 2011 9:16 am Post subject: |
Thanks for the link... I searched with no luck.
The link mentions using clamp nut from a Bay, but cannot find these in any on-line vendor catalogue. I’ll try and look at a Bay axle to see if my threads are the same or not. _________________ Drew
65 Kombi
83.5 Vanagon Westy
rizzag Now Wut?
Joined: April 19, 2001 Posts: 3116 Location: Keizer, OR
Posted: Sat Apr 23, 2011 11:47 am Post subject: |
Thanks rizzag! _________________ Drew
65 Kombi
83.5 Vanagon Westy
Posted: Sat Apr 23, 2011 1:45 pm Post subject: |
good links... I guess my VW lingo isn't the best for interweb searches!
Thanks again everone _________________ Drew
65 Kombi
83.5 Vanagon Westy
bus guy Samba Member
Joined: November 13, 2002 Posts: 785 Location: Southsea, UK South Coast
Posted: Sun Apr 24, 2011 3:23 am Post subject: |
Any local VW garage or junkyard should have them. As far as I am aware, they are not available new. |
Split 66' Samba Member
Joined: October 07, 2010 Posts: 1248 Location: Bay Area, California
campingbox Samba Member
Joined: November 14, 2000 Posts: 10192 Location: Petaluma, CA
Posted: Fri Jan 23, 2015 8:51 pm Post subject: |
I have original nuts and lock plates if you are in need. |
Posted: Fri Jan 23, 2015 10:37 pm Post subject: |
campingbox wrote: |
Would you have the clamp-style Bay ones? _________________ "OG = Original German" -- TheSamba.com dictionary |
Posted: Fri Jan 23, 2015 10:40 pm Post subject: |
Split 66' wrote: |
campingbox wrote: |
Would you have the clamp-style Bay ones? |
Oh, heavens no. I cant imagine puting bay window parts on a split window bus. |
Longboardluv Samba Member
Joined: September 23, 2014 Posts: 934 Location: Austin TX
Clara Samba Member
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2190 Location: UK (South)
Posted: Fri Feb 24, 2017 11:10 am Post subject: Re: 65 Kombi axle spindle bearing clamp nut? |
Not sure if they're any cheaper than the one you posted a link to, but Viscous Fan wrenches are nice and thin and have a cranked end so you can get at that back nut. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Fri Feb 24, 2017 1:27 pm Post subject: Re: 65 Kombi axle spindle bearing clamp nut? |
thanks for the info guys! I just got this $17. Will be good to have on board |
