GeorgeL Samba Member
Posted: Mon Apr 05, 2010 8:41 pm Post subject: |
wythac wrote: |
You are right, George, I was giving them the benefit of the doubt that they would know the not-so "universal" coupler, but I also didn't add that I would ask them " is it perfectly round, or is it a rounded square?".
Round=good, Sorta Round=not so good.
I sent them the same pic that I posted here, which should also help.
Given that shipping it back to them at my cost just means they get to sell it twice, I would be more than happy to shove it in a flat rate envelope and ship it to you. PM me with your address, and when I get this resolved in a day or two I will send it your way. It is really a much better part than the crappy red one, nice rubber. |
PM sent. All the parts we need are out there, they just aren't all in the right places! |
wythac Samba Member
Posted: Tue Apr 06, 2010 9:20 am Post subject: |
Update:
Called WCM. Guy there tells me that the couplers they sell are Brazilian, and all of them (Bus, Bug, Ghia) etc have those rounded square type design. They get them in bulk and package them themselves.
He was going back to check the bin...he said that they had almost 200 of them in stock (I think the 19 I thought I saw on the website was 191) and thanked me for giving them the heads up.
He is shipping me the correct one free of charge, and I expect that they will have their issues with unshipped stock sorted quickly. |
wythac Samba Member
Posted: Wed Apr 07, 2010 9:09 am Post subject: |
Another Update:
Raoul from WCM called me again this morning. Every one of the couplers they had in stock, almost 200, were bus couplers mislabled as those for a bug. He has no idea how many may have gone out that way already, but he said they would make good on any that were mislabeled.
If you are a typical buggy guy, and buy parts well in advance of installation, AND you have bought a coupler from WCM, if I were you I would haul it out of the box and take a look at it, make sure it is the right one. Bus one is bigger.
For anyone ordering one now, they are currently out of stock, but he says that they will have the correct ones in this week. You could order now without worrying about getting the wrong part....they are very aware. |
wythac Samba Member
Posted: Tue Apr 27, 2010 4:38 pm Post subject: |
Took three weeks, and a few phone calls to WCM, but I did get the proper coupler. Way too much effort for a 5.00 part, but worth it in the end.
Below is the one that was sent to me originally, next to the urethane one that gets replaced. You'll see that the part numbers are the same, but the black coupler is much larger in this photo...it is for a bus. They had quite a stock of these mislabled parts, so if you have purchased one of these from WCM and thrown it in a box of parts yet to be used, haul it out and check it on your steering coupler hardware to make sure it fits.
DirtGhost Samba Member
Joined: September 19, 2007 Posts: 547 Location: Greensboro,NC
Endoboy Samba Member
Joined: May 19, 2005 Posts: 502 Location: Allentown, PA
Posted: Thu Apr 29, 2010 6:38 am Post subject: |
Man, after reading all this, I went to check my coupler. It was an OE german one and probably dated from 1964, just like the pan, and it had several small cracks in it. Nothing serious, but why take the chance? I went right out and got a new one (the black rounded-off square one), but haven't checked yet to see if it was mislabeled for size/model.
Really glad I saw this thread, though. If it keeps even one person from having theirs fail, it was a great resource. Thanks, Samba. _________________ 1970 Autodynamics Deserter Series One (gone)
"Americans can always be counted on to do the right thing...after they have exhausted all other possibilities." --- Winston Churchill |
wythac Samba Member
Posted: Thu Apr 29, 2010 7:55 am Post subject: |
Dirt Ghost, isnt that a rag joint up by your steering box and pitman arm? |
Posted: Thu Apr 29, 2010 7:56 am Post subject: |
wythac wrote: |
Good eye. Yes it is but finish joints will all be U-joints. _________________ Orange Boxx Design and Fabrication |
wythac Samba Member
Posted: Thu Apr 29, 2010 8:18 am Post subject: |
I would definitely use U-joints if my steering column were long or not at an identical angle to the steering box. I have a 3" lift and considered using the stock steering column hole in the firewall and a two u-joint jackshaft to complete the connection to the steering box. Ultimately it was simpler, given the limited space, to just relocate the hole in the firewall lower in the body and use a cut down steering shaft (about 2" shorter) with an otherwise stock column and box. |
vindeta Samba Member
Posted: Tue Jun 22, 2010 5:19 am Post subject: |
i have one of those on my car right now...
im going outside grabbing that thing and throwing it as far as i can.
this thread really should be posted somewhere.. im sure theres alot of ppl still using the urethane coupler that dont know about this. _________________ 75 baja in progress!
http://www.azbaja.com/ForumsPro/viewtopic/t=5767.html
build thread^^ |
Elwood Samba Member
Joined: September 25, 2005 Posts: 249 Location: USA, As if theres anywhere else.
Posted: Thu Jun 24, 2010 7:36 pm Post subject: |
I am using only 1 U joint and not the rag joint at all. I can adjust my tierod angle in any direction by chiseleing off the stops.
So bumpsteer can be taken out easily and the column angle is not stock as it would be impossible to determine what that would be. I prefer this setup actually as it gives me alot more flexibility.
i think from now on i will do this in lowered Bugs as well. |
scarybuggy Samba Member
Joined: April 05, 2006 Posts: 495 Location: Northern Neck, Virginia
Posted: Fri Jun 25, 2010 3:38 am Post subject: |
Elwood, does your u-joint fit the stock steering box and steering column? If so, what size is it and where did you pick it up from? It is from a Super Beetle? _________________ Jay
'67 Manx Clone |
Elwood Samba Member
Posted: Sat Jun 26, 2010 9:32 pm Post subject: |
Its a standard 36 spline U-joint I bought from Chirco.
I also bought a short splined stuf and a long spline stub that fits it.
I then took the piece that bolts to the rag joint with the short spline stub on it and drilled out the stub on a lathe. I drilled it to the correct size hole for the stub I bought. 5/8". Inserted the short stub and welded it up. Using it as an adapter to bolt to the steering box. I also drilled those holes out and I am using 5/16" bolts through those.
The long splined stub will go into the steering shaft and be welded one the required length is determined by assembling, tack welding checking and rechecking...
This is gonna be standard procedure for me from now on so I can adjust out the bumpsteer. |
mwcopi Samba Member
Joined: April 28, 2008 Posts: 247 Location: fairmount in
Posted: Sat May 28, 2011 11:40 am Post subject: |
I was out for a drive today and was luckily turning from a stop light and heard a pop and had no steering! No more poly steering bushings for me! It wasn't even two years old! _________________ This space for sale. |
airdreams1 Samba Member
Joined: December 09, 2008 Posts: 43 Location: Star ID
Posted: Fri Jun 08, 2012 11:11 pm Post subject: |
dirtbugger wrote: |
I managed to find that Pic of the coupler on my mates buggy.
It was only months old and as you can see from the condition of all the surrounding hardware, the buggy had never rolled a tyre in the dirt.
I know this is an old post......... But this thing was not even installed correctly! Its no wonder why It failed. Cant blame the product for this one... it should have a washer on both sides of all 4 holes just like the instructions should have said.
It should look something like this:
bit longer.
& if it isnt flat like it should be, adjust things till it is. Dont leave it like this:
Leaving it warped like in the pic above will ruin the OEM rubber ones too. it just takes a bit longer. (I know I lost a nylock & will be replacing it in the morning)
That said Ive never had a problem running them on my Baja. no problems with the motor mounts or trans mounts either. But I ran them with a center trans mount & bell housing strap as well (just to be sure I didnt get any motor hop & brake anything. & never a problem with the shifting coupler or trailing arm bushings.
All was on by baja since Y2K.... & Yes they saw lots of off road use..
Just for the record, I didnt buy the cheep empi crap made in China!
OH, & should mention that the same urethane steering coupler is now on my Samurai.......... Soon to be a Volksuki Bugurai (Samurai chassis with my 66 Baja body) |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Sat Jun 09, 2012 4:19 am Post subject: |
The urethane is not meant to be used in a "ragnut" application, there is no redundancy. The rubber ragnut has nylon fiber in it to hold it together, it will not fail completely like a urethane ragnut. _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92
Dale M. Samba Member
Posted: Sat Jun 09, 2012 6:11 am Post subject: |
airdreams1 wrote: |
dirtbugger wrote: |
bit longer.
Carry spare "rag" joint in tool box...
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Sat Jun 09, 2012 6:50 am Post subject: |
airdreams1 wrote: |
I know this is an old post......... But this thing was not even installed correctly! Its no wonder why It failed. Cant blame the product for this one... it should have a washer on both sides of all 4 holes just like the instructions should have said. & if it isnt flat like it should be, adjust things till it is.
Great idea, remove the flex! In fact just replace it with a solid steel one or better yet attach the shaft directly to the box. Those silly engineers at VW sure screwed that one up. I wonder how they ever figured a flex coupling was necessary.
I know exactly what you mean about the OEM rubber ones eventually being ruined too. I've got a 50 year old one on a steering box in the garage and almost all the rubber is crumbled. Its funny though, the fabric cords are pretty much still intact, they're hella tough and I'm pretty sure it would still get me home without catastrophically failing and allowing me to run into something or someone. |
Posted: Sat Jun 09, 2012 11:05 am Post subject: |
Not trying to argue anything with anyone. Just stating that if not isstalled properly like in pic 2 (that I intentionaly set up that way for the pic) you can & will cause either type of coupler to fail prematurly.
This is probably why the other ones failed like they did. Or could just be the lousy material the Chinese ones were made of. |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Sat Jun 09, 2012 5:07 pm Post subject: |
True that the installation method is important, but the fact is that the urethane steering joints are best used as wall art or as a paper weight. I'll take a factory rag-joint any day over the urethane part...
Urethane in suspension components? Sure, I'd use them.
Urethane in the steering linkage? No thanks.... VW didn't use them from the factory. _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
