009 Distributer
Forum Index -> International Share: Facebook Twitter
The gospel bus
The gospel bus is offline
PostPosted: Tue Aug 18, 2009 4:28 pm    Post subject: 009 Distributer Reply with quote
Ok, I have an 009 dist. I read on a website that #1 should be at 7:30. PO set it at 5:00ish. I have set the timing and idle and the flat spot is very slight, but according to the website i was at my dist is installed incorrectly.
Does it need to be at 7:30 and if so how do i get it there, and reset the timing and all.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Aug 18, 2009 4:30 pm    Post subject: Reply with quote
It depends if the distributor driveshaft was installed correctly. As long as the rotor points to the #1 mark when #1 is at TDC, it doesn't matter where on the "o'clock" it winds up.
Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club
The gospel bus
PostPosted: Tue Aug 18, 2009 4:55 pm    Post subject: Reply with quote
And it does. When I adjust the valves 1 is at 1 position on dist. So I am ok then?
Mr. 010
Glenn is offline
PostPosted: Tue Aug 18, 2009 5:21 pm    Post subject: Reply with quote
You're OK.
Glenn
HBB/RW
www.DasVolks.com
Reply to topic    Forum Index -> International All times are Mountain Standard Time/Pacific Daylight Savings Time
